Home » Modeling » EMF » Problem 2: eInverseAdd() null pointer exceptions in 1.1
Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377699] |
Thu, 05 June 2003 15:37  |
Henrietta Slack Messages: 63 Registered: July 2009 |
Member |
I've just upgraded to the latest EMF 1.1, recreated my models and run
straight into null pointer exceptions. It happens in the call to
eDynamicInverseAdd() after its failed to get its settings (sorry I've lost
the stack trace for the moment).
I've gone back to 1.02 for now where I'm working quite happily; do you
think this is likely to be a bug in 1.1?
Henrietta
P.S. Any idea why AClass gets a basicAdd() and BClass gets
eDynamicInverseAdd()? That looks wrong to me. I've boiled this example
out of a lot of code but I'm certain the classes and relationships are
defined in the same way.
* @model
public interface ContainerClass extends EObject {
* @model type="AClass" opposite="containerClass"
EList getAClasses();
* @model type="BClass" opposite="containerClass"
EList getBClasses();
* @model
public interface AClass extends EObject {
* @model opposite="aClasses"
LillyModel getLillyModel();
* @model
public interface BClass extends EObject {
* @model opposite="bClasses"
--------< Gen'd ContainerClass implementation >----------
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public NotificationChain eInverseAdd(InternalEObject otherEnd, int
featureID, Class baseClass, NotificationChain msgs)
if (featureID >= 0)
switch (eDerivedStructuralFeatureID(featureID, baseClass))
case MyPackage.CONTAINER_CLASS__A_CLASSES :
return ((InternalEList) getAClasses()).basicAdd(otherEnd, msgs);
default :
return eDynamicInverseAdd(otherEnd, featureID, baseClass, msgs);
if (eContainer != null)
msgs = eBasicRemoveFromContainer(msgs);
return eBasicSetContainer(otherEnd, featureID, msgs);
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377803 is a reply to message #377699] |
Mon, 09 June 2003 01:05   |
Frank Budinsky Messages: 478 Registered: July 2009 |
Henrietta,
The call to eDynamicInverseAdd() indicates a codegen problem. Did you regen you're
model in 1.1?
The three model classes you show don't match. If they're supposed to work together
then ContainerClass would need to be named LillyModel and the opposite tags on
getAClasses() and getBClasses() would need to say opposite="lillyModel".
Frank.
> Henrietta
> * @model
> * @model
> * @model
> * @generated
> if (featureID >= 0)
> default :
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377822 is a reply to message #377803] |
Mon, 09 June 2003 23:18   |
Member |
I beg your pardon, Frank, that\'s just my manual find and replace gone
awry. I did do a complete rebuild (removed all model and autogen\'d files
and created a new model) in 1.1. It looks like a codegen problem to me
and I should have written:
* @model
* @model opposite=\"aClasses\"
ContainerClass getContainerClass();
* @model
* @model opposite=\"bClasses\"
Frank Budinsky wrote:
> Henrietta,
you\'re
> model in 1.1?
> The three model classes you show don\'t match. If they\'re supposed to work
together
on
> getAClasses() and getBClasses() would need to say opposite=\"lillyModel\".
> Frank.
> Henrietta wrote:
> > I\'ve just upgraded to the latest EMF 1.1, recreated my models and run
> > eDynamicInverseAdd() after its failed to get its settings (sorry I\'ve lost
> > I\'ve gone back to 1.02 for now where I\'m working quite happily; do you
> > Thanks,
> > Henrietta
> > eDynamicInverseAdd()? That looks wrong to me. I\'ve boiled this example
> > out of a lot of code but I\'m certain the classes and relationships are
> > * @model
> > * @model type=\"AClass\" opposite=\"containerClass\"
> > * @model type=\"BClass\" opposite=\"containerClass\"
> > * @model
> > * @model
> > --------< Gen\'d ContainerClass implementation >----------
> > * @generated
> > if (featureID >= 0)
msgs);
> > default :
msgs);
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377832 is a reply to message #377822] |
Tue, 10 June 2003 13:37   |
Henrietta,
Is this still a problem. If so, could you please provide all the applicable classes
once again and explain exactly what isn't working.
Frank.
> * @model
> * @model
> > Henrietta,
> you\'re
> > model in 1.1?
> together
> on
> > Frank.
> > > Thanks,
> > > Henrietta
> > > * @model
> > > * @model
> > > * @model
> > > * @generated
> > > if (featureID >= 0)
> msgs);
> > > default :
> msgs);
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377836 is a reply to message #377832] |
Tue, 10 June 2003 15:37   |
Member |
I tried incorporating the change required for my first problem and
upgraded to 1.1 again with no success. The problem _seems_ to be in the
eInverseAdd() generated in ContainerClassImpl.java. It _looks as though_
a case statement is missing for CONTAINER_CLASS_B_CLASSES and it blows up
in the eDynamicInverseAdd() with a NullPointerException. (Shouldn't it be
doing a basicAdd() on the BClass list?). I've flipped backwards and
forwards between 1.02 and 1.1 three times now using the same code base and
regenerated the models from scratch and it's always consistent - 1.02
works, 1.1 falls over. Here's the code:
* @generated
if (featureID >= 0)
case ModelPackage.CONTAINER_CLASS_A_CLASSES :
default :
Although it looks wrong (to me) it is exactly the same code that 1.0.2
generates and that works (well, it doesn't give me a
NullPointerException). This goes on to call eDynamicInverseAdd() in
EObjectImpl.java which picks up the null from eSettings():
public NotificationChain eDynamicInverseAdd(InternalEObject otherEnd, int
featureID, Class inverseClass, NotificationChain msgs)
EStructuralFeature.Internal feature =
(EStructuralFeature.Internal)eClass().getEAllStructuralFeatu res().get(featureID);
return
feature.getSettingDelegate().dynamicInverseAdd
(this, eSettings(), featureID - eStaticFeatureCount(), otherEnd,
msgs);
And then on to dynamicInverseAdd() in InternalSettingDelegateMany (an
inner class of EStructuralFeatureImpl):
public NotificationChain dynamicInverseAdd
(InternalEObject owner, EStructuralFeature.Internal.DynamicValueHolder
settings, int index, InternalEObject otherEnd, NotificationChain
notifications)
// -------- So we fail with settings as null here ------------
Object setting = settings.dynamicGet(index);
if (setting == null)
settings.dynamicSet(index, setting = createDynamicSetting(owner));
return ((InternalEList)setting).basicAdd(otherEnd, notifications);
To reiterate, here's what the three interfaces involved look like:
* @model
* @model
* @model
Let me know if you need anything more.
Henrietta
> Henrietta,
classes
> Frank.
> > * @model
> > * @model
> > > Henrietta,
regen
> > you\'re
> > > model in 1.1?
work
> > together
tags
> > on
> > > Frank.
lost
you
> > > > Thanks,
> > > > Henrietta
example
> > > > * @model
> > > > * @model
> > > > * @model
> > > > * @generated
> > > > if (featureID >= 0)
> > msgs);
> > > > default :
baseClass,
> > msgs);
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377838 is a reply to message #377832] |
Tue, 10 June 2003 16:19   |
Member |
The generated method eInverseRemove() gets it right and does a
basicRemove() on the BClass list. Surely this should be symmetric with
eInverseAdd() and it's the missing case statement that's causing my
problem? I thought so, and when I add the case statement manually ...
case ModelPackage.CONTAINER_CLASS__B_CLASSES :
return ((InternalEList) getBClasses()).basicAdd(otherEnd, msgs);
... to my eInverseAdd() it fixes the problem (until I regenerate). So at
least I have a work around for the short term. Now why did it _appear_ to
work in 1.02 ...
* @generated
public NotificationChain eInverseRemove(InternalEObject otherEnd, int
if (featureID >= 0)
case ModelPackage.CONTAINER_CLASS__A_CLASSES:
return ((InternalEList)getAClasses()).basicRemove(otherEnd, msgs);
case ModelPackage.CONTAINER_CLASS__B_CLASSES:
return ((InternalEList)getBClasses()).basicRemove(otherEnd, msgs);
default:
return eDynamicInverseRemove(otherEnd, featureID, baseClass, msgs);
return eBasicSetContainer(null, featureID, msgs);
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377839 is a reply to message #377836] |
Tue, 10 June 2003 16:28   |
Ed Merks Messages: 29329 Registered: July 2009 |
--------------A7868DDD177D694C355E129F
Content-Type: text/plain; charset=us-ascii
Henrietta,
When I generate from your examples below I get this implemention with a case that handles bClasses:
public NotificationChain eInverseAdd(InternalEObject otherEnd, int featureID, Class
baseClass, NotificationChain msgs) {
if (featureID >= 0) {
switch (eDerivedStructuralFeatureID(featureID, baseClass)) {
case Sample1Package.CONTAINER_CLASS__ACLASSES:
return ((InternalEList)getAClasses()).basicAdd(otherEnd, msgs);
case Sample1Package.CONTAINER_CLASS__BCLASSES:
return ((InternalEList)getBClasses()).basicAdd(otherEnd, msgs);
default:
I'm quite confused about why you would see something different that this. There must be something
that you are doing that we aren't, or vice versa, but I haven't a clue. Perhaps you should attach
the exact input files you are using...
> * @generated
> if (featureID >= 0)
> default :
> return
> msgs);
> notifications)
> * @model
> * @model
> * @model
> Henrietta
> > Henrietta,
> classes
> > Thanks,
> > Frank.
> > > * @model
> > > * @model
> > > > Henrietta,
> regen
> > > you\'re
> > > > model in 1.1?
> work
> > > together
> tags
> > > on
> > > > Frank.
> lost
> you
> > > > > Thanks,
> > > > > Henrietta
> example
> > > > > * @model
> > > > > * @model
> > > > > * @model
> > > > > * @generated
> > > > > if (featureID >= 0)
> > > msgs);
> > > > > default :
> baseClass,
> > > msgs);
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Henrietta,
<p>When I generate from your examples below I get this implemention with
<blockquote><tt> public NotificationChain eInverseAdd(InternalEObject
otherEnd, int featureID, Class baseClass, NotificationChain msgs) {</tt>
<br><tt> if (featureID >= 0) {</tt>
<br><tt> switch (eDerivedStructuralFeatureID(featureID, baseClass))
{</tt>
<br><tt> case Sample1Package.CONTAINER_CLASS__ACLASSES:</tt>
<br><tt> return ((InternalEList)getAClasses()).basicAdd(otherEnd,
msgs);</tt>
<br><b><tt> case Sample1Package.CONTAINER_CLASS__BCLASSES:</tt></b>
<br><b><tt> return ((InternalEList)getBClasses()).basicAdd(otherEnd,
msgs);</tt></b>
<br><tt> default:</tt>
<br><tt> return eDynamicInverseAdd(otherEnd, featureID,
baseClass, msgs);</tt>
<br><tt> }</tt>
<br><tt> }</tt>
<br><tt> if (eContainer != null)</tt>
<br><tt> msgs = eBasicRemoveFromContainer(msgs);</tt>
<br><tt> return eBasicSetContainer(otherEnd, featureID, msgs);</tt>
<br><tt> }</tt></blockquote>
There must be something that you are doing that we aren't, or vice versa,
but I haven't a clue. Perhaps you should attach the exact input files
you are using...
<br>
<p>Henrietta wrote:
<blockquote TYPE=CITE>I tried incorporating the change required for my
first problem and
<br>upgraded to 1.1 again with no success. The problem _seems_ to
be in the
<br>eInverseAdd() generated in ContainerClassImpl.java. It _looks
as though_
<br>a case statement is missing for CONTAINER_CLASS_B_CLASSES and it blows
up
<br>in the eDynamicInverseAdd() with a NullPointerException. (Shouldn't
it be
<br>doing a basicAdd() on the BClass list?). I've flipped backwards
and
<br>forwards between 1.02 and 1.1 three times now using the same code base
and
<br>regenerated the models from scratch and it's always consistent - 1.02
<br>works, 1.1 falls over. Here's the code:
<p>/**
<br> * <!-- begin-user-doc -->
<br> * <!-- end-user-doc -->
<br> * @generated
<br> */
<br>public NotificationChain eInverseAdd(InternalEObject otherEnd, int
<br>featureID, Class baseClass, NotificationChain msgs)
<br>{
<br> if (featureID >= 0)
<br> {
<br>
<br>
<br>
<br>
<br>
default :
<br>
<br>
<br>
<br> if (eContainer != null)
<br>
<br> return eBasicSetContainer(otherEnd,
featureID, msgs);
<br>}
<p>Although it looks wrong (to me) it is exactly the same code that 1.0.2
<br>generates and that works (well, it doesn't give me a
<br>NullPointerException). This goes on to call eDynamicInverseAdd()
in
<br>EObjectImpl.java which picks up the null from eSettings():
<p>public NotificationChain eDynamicInverseAdd(InternalEObject otherEnd,
int
<br>featureID, Class inverseClass, NotificationChain msgs)
<br>{
<br> EStructuralFeature.Internal feature =
<br> (EStructuralFeature.Internal)eClass().getEAllStructuralFeatu res().get(featureID);
<br> return
<br> feature.getSettingDelegate().dynamicInverseAdd
<br> (this, eSettings(), featureID - eStaticFeatureCount(),
otherEnd,
<br>msgs);
<br>}
<p>And then on to dynamicInverseAdd() in InternalSettingDelegateMany (an
<br>inner class of EStructuralFeatureImpl):
<p>public NotificationChain dynamicInverseAdd
<br> (InternalEObject owner, EStructuralFeature.Internal.DynamicValueHolder
<br>settings, int index, InternalEObject otherEnd, NotificationChain
<br>notifications)
<br>{
<br> // -------- So we fail with settings as null here ------------
<br> Object setting = settings.dynamicGet(index);
<br> if (setting == null)
<br> {
<br> settings.dynamicSet(index, setting = createDynamicSetting(owner));
<br> }
<br> return ((InternalEList)setting).basicAdd(otherEnd, notifications);
<br>}
<p>To reiterate, here's what the three interfaces involved look like:
<p>/**
<br> * @model
<br> */
<br>public interface ContainerClass extends EObject {
<br> /**
<br> * @model type="AClass"
<br> */
<br> EList getAClasses();
<p> /**
<br> * @model type="BClass"
<br> */
<br> EList getBClasses();
<br>}
<p>/**
<br> * @model
<br> */
<br>public interface AClass extends EObject {
<br> /**
<br> * @model opposite="aClasses"
<br> */
<br> ContainerClass getContainerClass();
<br>}
<p>/**
<br> * @model
<br> */
<br>public interface BClass extends EObject {
<br> /**
<br> * @model opposite="bClasses"
<br> */
<br>}
<p>Let me know if you need anything more.
<br>Thanks,
<br>Henrietta
<p>Frank Budinsky wrote:
<p>> Henrietta,
<p>> Is this still a problem. If so, could you please provide all the applicable
<br>classes
<br>> once again and explain exactly what isn't working.
<p>> Thanks,
<br>> Frank.
<p>> Henrietta wrote:
<p>> > I beg your pardon, Frank, that\'s just my manual find and replace
gone
<br>> > awry. I did do a complete rebuild (removed all model and
autogen\'d files
<br>> > and created a new model) in 1.1. It looks like a codegen
problem to me
<br>> > and I should have written:
<br>> >
<br>> > /**
<br>> > * @model
<br>> > */
<br>> > public interface AClass extends EObject {
<br>> > /**
<br>> > * @model
<br>> > */
<br>> > ContainerClass
<br>> > }
<br>> >
<br>> > /**
<br>> > * @model
<br>> > */
<br>> > public interface BClass extends EObject {
<br>> > /**
<br>> > * @model
<br>> > */
<br>> > }
<br>> >
<br>> > Frank Budinsky wrote:
<br>> >
<br>> > > Henrietta,
<br>> >
<br>> > > The call to eDynamicInverseAdd() indicates a codegen problem.
Did you
<br>regen
<br>> > you\'re
<br>> > > model in 1.1?
<br>> >
<br>> > > The three model classes you show don\'t match. If they\'re supposed
to
<br>work
<br>> > together
<br>> > > then ContainerClass would need to be named LillyModel and
the opposite
<br>tags
<br>> > on
<br>> > > getAClasses() and getBClasses() would need to say
<br>opposite=\"lillyModel\".
<br>> >
<br>> > > Frank.
<br>> >
<br>> > > Henrietta wrote:
<br>> >
<br>> > > > I\'ve just upgraded to the latest EMF 1.1, recreated my models
and run
<br>> > > > straight into null pointer exceptions. It happens in
the call to
<br>> > > > eDynamicInverseAdd() after its failed to get its settings (sorry
I\'ve
<br>lost
<br>> > > > the stack trace for the moment).
<br>> > > >
<br>> > > > I\'ve gone back to 1.02 for now where I\'m working quite happily;
do
<br>you
<br>> > > > think this is likely to be a bug in 1.1?
<br>> > > >
<br>> > > > Thanks,
<br>> > > > Henrietta
<br>> > > >
<br>> > > > P.S. Any idea why AClass gets a basicAdd() and BClass gets
<br>> > > > eDynamicInverseAdd()? That looks wrong to me. I\'ve
boiled this
<br>example
<br>> > > > out of a lot of code but I\'m certain the classes and relationships
are
<br>> > > > defined in the same way.
<br>> > > >
<br>> > > > /**
<br>> > > > * @model
<br>> > > > */
<br>> > > > public interface ContainerClass extends EObject {
<br>> > > > /**
<br>> > > > */
<br>> > > > EList getAClasses();
<br>> > > >
<br>> > > > /**
<br>> > > > */
<br>> > > > EList getBClasses();
<br>> > > > }
<br>> > > >
<br>> > > > /**
<br>> > > > */
<br>> > > > public interface AClass extends EObject {
<br>> > > > /**
<br>> > > > */
<br>> > > > LillyModel
getLillyModel();
<br>> > > > }
<br>> > > >
<br>> > > > /**
<br>> > > > */
<br>> > > > public interface BClass extends EObject {
<br>> > > > /**
<br>> > > > */
getLillyModel();
<br>> > > > }
<br>> > > >
<br>> > > > --------< Gen\'d ContainerClass implementation >----------
<br>> > > >
<br>> > > > /**
<br>> > > > * <!-- begin-user-doc -->
<br>> > > > * <!-- end-user-doc -->
<br>> > > > * @generated
<br>> > > > */
<br>> > > > public NotificationChain eInverseAdd(InternalEObject otherEnd,
int
<br>> > > > featureID, Class baseClass, NotificationChain msgs)
<br>> > > > {
<br>> > > > if (featureID
>= 0)
<br>> > > > {
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>getAClasses()).basicAdd(otherEnd,
<br>> > msgs);
<br>> > > >
default :
<br>> > > >
<br>baseClass,
<br>> > msgs);
<br>> > > >
<br>> > > > }
<br>> > > > if (eContainer
!= null)
<br>> > > >
<br>> > > > return eBasicSetContainer(otherEnd,
featureID, msgs);
<br>> > > > }</blockquote>
</html>
--------------A7868DDD177D694C355E129F--
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377840 is a reply to message #377839] |
Tue, 10 June 2003 16:39   |
Member |
Oh dear! I was afraid of as much; I've boiled my example out a lot of
code (too much and not in a good state to send). I could try and get a
small demo together (if indeed I can reproduce it in a small demo) but
that's going to take me some time. In the meantime, does the asymmetry
between the eInverseAdd() and the eInverseRemove() give you any clues?
Would any differences in the code that generates these methods be obvious
to you just by looking?
> Henrietta,
featureID, Class
> default:
> > * @generated
> > if (featureID >= 0)
> > default :
> > return
> > msgs);
> > notifications)
> > * @model
> > * @model
> > * @model
> > Thanks,
> > Henrietta
> > > Henrietta,
applicable
> > classes
> > > Thanks,
> > > Frank.
files
> > > > * @model
> > > > * @model
> > > > > Henrietta,
> > regen
> > > > you\'re
> > > > > model in 1.1?
to
> > work
> > > > together
opposite
> > tags
> > > > on
> > > > > Frank.
run
I\'ve
> > lost
do
> > you
> > > > > > Thanks,
> > > > > > Henrietta
> > example
relationships are
> > > > > > * @model
> > > > > > * @model
> > > > > > * @model
> > > > > > * @generated
> > > > > > if (featureID >= 0)
baseClass))
> > > > msgs);
> > > > > > default :
> > baseClass,
> > > > msgs);
> <html>
> Henrietta,
> {</tt>
> msgs);</tt>
> msgs);</tt></b>
> <br><tt> }</tt>
> <br><tt> }</tt>
> you are using...
> <br>
> first problem and
> be in the
> as though_
> up
> it be
> and
> and
> <p>/**
> <br> * @generated
> <br> */
> <br>{
> <br> {
> <br>
> <br>
> <br>
> <br>
> <br>
> default :
> <br>
> <br>
> <br>
> <br>
> featureID, msgs);
> <br>}
> in
> int
> <br>{
> <br> return
> otherEnd,
> <br>msgs);
> <br>}
> <br>notifications)
> <br>{
> <br> {
> <br> }
> <br>}
> <p>/**
> <br> * @model
> <br> */
> <br> /**
> <br> */
> <p> /**
> <br> */
> <br>}
> <p>/**
> <br> * @model
> <br> */
> <br> /**
> <br> */
> <br>}
> <p>/**
> <br> * @model
> <br> */
> <br> /**
> <br> */
> <br>}
> <br>Thanks,
> <br>Henrietta
> <p>> Henrietta,
applicable
> <br>classes
> <p>> Thanks,
> <br>> Frank.
> gone
> autogen\'d files
> problem to me
> <br>> >
> <br>> > /**
> <br>> > * @model
> <br>> > */
> <br>> > /**
> <br>> > * @model
> <br>> > */
> <br>> > }
> <br>> >
> <br>> > /**
> <br>> > * @model
> <br>> > */
> <br>> > /**
> <br>> > * @model
> <br>> > */
> <br>> > }
> <br>> >
> <br>> >
> <br>> >
> Did you
> <br>regen
> <br>> > you\'re
> <br>> >
> to
> <br>work
> <br>> > together
> the opposite
> <br>tags
> <br>> > on
> <br>> >
> <br>> > > Frank.
> <br>> >
> <br>> >
> and run
> the call to
> I\'ve
> <br>lost
> <br>> > > >
> do
> <br>you
> <br>> > > >
> <br>> > > > Thanks,
> <br>> > > >
> boiled this
> <br>example
relationships
> are
> <br>> > > >
> <br>> > > > /**
> <br>> > > > */
> <br>> > > > /**
> <br>> > > > */
> <br>> > > >
> <br>> > > > /**
> <br>> > > > */
> <br>> > > > }
> <br>> > > >
> <br>> > > > /**
> <br>> > > > */
> <br>> > > > /**
> <br>> > > > */
> getLillyModel();
> <br>> > > > }
> <br>> > > >
> <br>> > > > /**
> <br>> > > > */
> <br>> > > > /**
> <br>> > > > */
> getLillyModel();
> <br>> > > > }
> <br>> > > >
> <br>> > > >
> <br>> > > > /**
> <br>> > > > */
> int
> <br>> > > > {
> >= 0)
> <br>> > > > {
> <br>> > > >
> <br>> > > >
> <br>> > > >
> <br>> > > >
> <br>> > msgs);
> <br>> > > >
> default :
> <br>> > > >
> <br>baseClass,
> <br>> > msgs);
> <br>> > > >
> <br>> > > > }
> != null)
> <br>> > > >
> featureID, msgs);
> </html>
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377841 is a reply to message #377838] |
Tue, 10 June 2003 17:10   |
Henrietta,
I created a project with the three interfaces in your note and it generated properly. I'm using the
latest 1.1 driver. Here's what eInverseAdd() generated:
* @generated
public NotificationChain eInverseAdd(InternalEObject otherEnd, int featureID, Class baseClass,
case TestPackage.CONTAINER_CLASS__ACLASSES:
case TestPackage.CONTAINER_CLASS__BCLASSES:
default:
There must be something else in your environment causing the problem. Why don't you try to create a new
Java project, import just the three interfaces from your note and generate.
Btw, you shouldn't ordinarly need to add the extends EObject to your interfaces. It is an implicit
model inheritance that the generator will add to the Java interfaces. If you add it yourself, it will
be explicit in the meta model.
Frank.
> work in 1.02 ...
> * @generated
> if (featureID >= 0)
> default:
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377842 is a reply to message #377841] |
Tue, 10 June 2003 17:38   |
Member |
Yeah, I\'ve tried that experiment too and several variations and I
haven\'t yet reproduced the problem in anything but my full development
environment. I\'m going to keep trying. In the meantime...
Here\'s one asymmetry in the code generation framework between adds and
removes. This code is from GenClassImpl.java. Note that more removes can
be generated than adds because of the genFeature.isContains() condition on
the remove. Does this one make any sense? This _could_ result in what
I\'m seeing.
public List getEInverseAddGenFeatures()
return
collectGenFeatures
(getAllBaseGenClasses(),
getGenFeatures(),
new GenFeatureFilter()
public boolean accept(GenFeature genFeature)
return genFeature.isBidirectional() &&
!genFeature.isVolatile();
public List getEInverseRemoveGenFeatures()
return
collectGenFeatures
getGenFeatures(),
return genFeature.isContains() ||
(genFeature.isBidirectional() &&
!genFeature.getReverse().isVolatile());
> Henrietta,
properly. I\'m using the
> latest 1.1 driver. Here\'s what eInverseAdd() generated:
> * @generated
> default:
don\'t you try to create a new
> Btw, you shouldn\'t ordinarly need to add the extends EObject to your
> Frank.
> > eInverseAdd() and it\'s the missing case statement that\'s causing my
> > work in 1.02 ...
> > * @generated
> > if (featureID >= 0)
> > return
> > return
> > default:
Re: Problem 2: eInverseAdd() null pointer exceptions in 1.1 [message #377850 is a reply to message #377848] |
Tue, 10 June 2003 21:19  |
--------------99EDF5ABEBB1180D296A67C5
Henrietta,
Sorry you were bitten by this! We deliberately ignore comments with
multiple /* occurrences (in JPatternDictionary.match) so that if you did this
* @generated
/*public void aMethodYouDontWant()
some code you've commented out;
* Some really important hand written code.
public void aMethodYouReallyWant()
// Some code that you've just written.
the merger won't treat this as if the @generated applies to
aMethodYouReallyWant, which would result it in it being removed during
regeneration. Note that all the stuff in blue is considered by JDOM to be
the comment of aMethodYouReallyWant.
Henrietta wrote:
> OK, it's easy to reproduce and easy to work around (once you know what it
> is). After you've generated the example I gave you paste the lines below
> into ContainerClassImpl.java just prior to the eInverseAdd() method call.
> You can then remove the BCLASSES case statement from the eInverseAdd() to
> simulate what's been happening in my environment and then regenerate. It
> doesn't generate the method again. Take the comment lines out,
> regenerate, and everything works fine.
> The interesting thing about this problem is that seems to affect
> subsequent eInverseAdds as well, even in different packages.
> Thanks for your help today,
> Henrietta
<html>
Henrietta,
<p>Sorry you were bitten by this! We deliberately ignore comments
with multiple /* occurrences (in JPatternDictionary.match) so that if you
did this
<p> <font color="#000099"> /**</font>
<br><font color="#000099">
* <!-- begin-user-doc --></font>
* <!-- end-user-doc --></font>
* @generated</font>
*/</font>
<br><font color="#000099"> /*public
void aMethodYouDontWant()</font>
<br><font color="#000099"> {</font>
some code you've commented out;</font>
<br><font color="#000099"> }*/</font><font color="#000099"></font>
<p><font color="#000099"> /**</font>
* Some really important hand written code.</font>
*/</font>
<br> public void aMethodYouReallyWant()
<br> {
<br>
<br> }
<p>the merger won't treat this as if the @generated applies to aMethodYouReallyWant,
which would result it in it being removed during regeneration. Note
that all the stuff in <font color="#000099">blue</font> is considered by
JDOM to be the comment of aMethodYouReallyWant.
<br>
<p>Henrietta wrote:
<blockquote TYPE=CITE>OK, it's easy to reproduce and easy to work around
<br>is). After you've generated the example I gave you paste the
lines below
<br>into ContainerClassImpl.java just prior to the eInverseAdd() method
call.
<p> /**
<br> */
<br> /*public void aMethodYouDontWant()
<br> {
<br>
<br> }*/
<p>You can then remove the BCLASSES case statement from the eInverseAdd()
to
<br>simulate what's been happening in my environment and then regenerate.
It
<br>doesn't generate the method again. Take the comment lines out,
<br>regenerate, and everything works fine.
<p>The interesting thing about this problem is that seems to affect
<br>subsequent eInverseAdds as well, even in different packages.
<p>Thanks for your help today,
<br>Henrietta</blockquote>
</html>
--------------99EDF5ABEBB1180D296A67C5--
Current Time: Thu Apr 26 19:33:18 GMT 2018
Powered by FUDForum. Page generated in 0.02804 seconds
