oAW error :'Couldn't find operation....' [message #376309] |
Tue, 20 March 2007 09:30 |
Originally posted by: elena.tibrea.gmail.com
I get a runtime error :'Couldn't find operation....'
0 INFO -
50 INFO - openArchitectureWare 4.1.1, Build v20061128
50 INFO - (c) 2005, 2006 openarchitectureware.org and contributors
50 INFO -
50 INFO - running workflow:
D:/_eclipse3.2/workspace1/oaw4.demo.emf.datamodel.xtend/src/ workflow1.oaw
50 INFO -
821 INFO - xmiParser: file 'default.sm' => slot 'rootElement'
1091 INFO - XtendComponent: executing 'test::Trafo1'
1352 ERROR - Couldn't find operation 'setSmName(String)' for
sm2::StateMachineType. in test/Trafo1.ext on line 9 'setSmName(old.smName)'
org.openarchitectureware.expression.EvaluationException: Couldn't find
operation 'setSmName(String)' for sm2::StateMachineType. in
org.openarchitectureware.expression.ast.OperationCall.evalua teInternal(OperationCall.java:136)
org.openarchitectureware.expression.ast.Expression.evaluate( Expression.java:42)
org.openarchitectureware.xtend.ast.CreateExtensionStatement. evaluate(CreateExtensionStatement.java:77)
org.openarchitectureware.expression.ast.OperationCall.evalua teInternal(OperationCall.java:94)
org.openarchitectureware.expression.ast.OperationCall.evalua teInternal(OperationCall.java:62)
org.openarchitectureware.expression.ast.OperationCall.evalua teInternal(OperationCall.java:71)
org.openarchitectureware.expression.ExpressionFacade.evaluat e(ExpressionFacade.java:62)
org.openarchitectureware.expression.ExpressionFacade.evaluat e(ExpressionFacade.java:51)
org.openarchitectureware.xtend.XtendComponent.invokeInternal (XtendComponent.java:89)
org.openarchitectureware.workflow.lib.AbstractWorkflowCompon ent2.invoke(AbstractWorkflowComponent2.java:38)
org.openarchitectureware.workflow.container.CompositeCompone nt.internalInvoke(CompositeComponent.java:81)
org.openarchitectureware.workflow.container.CompositeCompone nt.invoke(CompositeComponent.java:69)
org.openarchitectureware.workflow.WorkflowRunner.executeWork flow(WorkflowRunner.java:236)
org.openarchitectureware.workflow.WorkflowRunner.run(Workflo wRunner.java:177)
org.openarchitectureware.workflow.WorkflowRunner.main(Workfl owRunner.java:126)
when using this transformation:
import sm2;
extension test::io;
create DocumentRoot this duplicate(DocumentRoot s):
setStatemachine( s.statemachine.duplicate() );
create StateMachineType this duplicate(StateMachineType old):
setSmName( old.smName );
for a EMF model created from the following XML Schema:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xs:schema xmlns:tns="http://www.tu-harburg.de/~soet1085/SM"
xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified"
targetNamespace="http://www.tu-harburg.de/~soet1085/SM">
<xs:element name="statemachine" type="tns:StateMachineType"/>
<xs:complexType name="StateMachineType">
<xs:attribute name="smName" type="xs:string"/>
</xs:complexType>
</xs:schema>
Can you please help?
I cannot figure out why:(
elena
Re: oAW error :'Couldn't find operation....' [message #376311 is a reply to message #376309] |
Sat, 24 March 2007 20:05 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi elena,
ecore meta models derived from schema use XML data types not the ecore
data types. The ecore adapter used in oAW can only map ecore data types
(ecore::EString, ecore::EInt, etc.) to oaw's data types (String,
Integer, etc.).
Make sure that your ecore meta model uses ecore::EString (and the like)
regards,
Sven
elena t wrote:
> 0 INFO -
> 50 INFO -
> 50 INFO - 821 INFO - xmiParser: file 'default.sm' => slot 'rootElement'
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> import sm2;
> extension test::io;
> <xs:complexType name="StateMachineType"> <xs:attribute name="smName"
> type="xs:string"/>
> </xs:complexType> </xs:schema>
> Thanks
> elena
Re: oAW error :'Couldn't find operation....' [message #578261 is a reply to message #376309] |
Hi elena,
Integer, etc.).
regards,
Sven
elena t wrote:
> 0 INFO -
> 50 INFO -
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> import sm2;
> extension test::io;
> type="xs:string"/>
> Thanks
> elena
FUDForum. Page generated in 0.03325 seconds
