Home » Eclipse Projects » BIRT » Export Data - Available Columns
Export Data - Available Columns [message #368864] Wed, 01 July 2009 14:32 Go to next message
SuperTime is currently offline SuperTimeFriend
Member
I understand that the columns shown in the export list are all the columns
listed under the binding tab.
I do not want the aggregation bindings to show up in the export.
So I use the following code as a work around:
Modifed the BirtSimpleExportDataDialog.js file in the ajax directory of
the viewer.in the __bind method I modified and added an if statement.
for ( var k = 0; k < resultSets.length; k++ )
var resultSet = resultSets[k];
var queryNames = resultSet.getElementsByTagName( 'QueryName' );
oSelects[0].options.add( new Option( queryNames[0].firstChild.data ) );
this.availableResultSets[k] = {};
var columns = resultSet.getElementsByTagName( 'Column' );
for( var i = 0; i < columns.length; i++ )
var column = columns[i];
var columnName = column.getElementsByTagName( 'Name' );
var label = column.getElementsByTagName( 'Label' );
if (columnName != 'ORDERDATE')
this.availableResultSets[k][label[0].firstChild.data] =
columnName[0].firstChild.data;
After saving the above code. I run the report in birt viewer and use the
export data options. The column ORDERDATE still exists and shows up in the
export document.
Am I doing something incorrect?
Re: Export Data - Available Columns [message #368883 is a reply to message #368864] Thu, 02 July 2009 14:42 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Try:
if( columnName[0].firstChild.data != 'ORDERDATE' ){
Jason
> columns listed under the binding tab. I do not want the aggregation
> the export document.
Re: Export Data - Available Columns [message #675952 is a reply to message #368883] Thu, 02 June 2011 06:26 Go to previous messageGo to next message
pratim  is currently offline pratim Friend
Hi Jason,
Even i have a requirement, where i don't want to show a column item in the export data dialogue box.
I tried the above steps, but that does not help.
Then, i try by removing the "BirtSimpleExportDataDialog.js" file itself, and building my application using tomcat server. But still, export data dialogue box shows up all the column item.
So, my question is does this file handle which column item to show up or not !! Or, there is some other files which handle this?
Re: Export Data - Available Columns [message #676050 is a reply to message #675952] Thu, 02 June 2011 14:49 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
That is the right file. look at the __bind function. For example I
could modify it to leave out columns name CUSTOMERTOTAL like:
if( columnName[0].firstChild.data != "CUSTOMERTOTAL" ){
Jason
On 6/2/2011 2:26 AM, pratim wrote:
> Hi Jason,
Previous Topic:Layout Problem with Scripted data set with hashmap
Next Topic:Overlay dynamic image
Current Time: Tue Apr 24 03:21:14 GMT 2018
Powered by FUDForum. Page generated in 0.42609 seconds
