Home » Eclipse Projects » BIRT » Draw line, rectangle etc..
Draw line, rectangle etc.. [message #368744] Tue, 23 June 2009 16:55 Go to next message
coolguy Missing name is currently offline coolguy Missing nameFriend
Can I draw lines, rectangles in a BIRT report? I do not see any controls
related to that in the palette.
Appreciate your help.
Re: Draw line, rectangle etc.. [message #368769 is a reply to message #368744] Wed, 24 June 2009 15:54 Go to previous message
Originally posted by: jasonweathersby.windstream.net
BIRT does not support this currently. You can work around it by using
grids of fixed size( set the layout to fixed in the main report
properties) and file the grid cells or use borders for lines. BIRT does
support writting an extension to implement this feature, but to date no
one has contributed a drawing report item.
Jason
Previous Topic:create ReportEngine failed
Next Topic:Expand and Collapse Report Group
Current Time: Tue May 22 16:03:45 GMT 2018
Powered by FUDForum. Page generated in 0.02383 seconds
