Home » Eclipse Projects » BIRT » create ReportEngine failed
create ReportEngine failed [message #368741] Tue, 23 June 2009 06:59 Go to next message
xing tongkun is currently offline xing tongkunFriend
I use the birt 2.3.2.2 to create a report using API.The following is the
code:
package com.test.birt.report;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
public class MyReportCreator {
* @param args
// TODO Auto-generated method stub
final EngineConfig config = new EngineConfig();
config.setBIRTHome("D:/work/libs/birt-runtime-2_3_2/ReportEngine ");
try {
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
IReportEngine engine = factory.createReportEngine(config);
} catch (BirtException e) {
// TODO Auto-generated catch block
e.printStackTrace();
when I run it ,it throws the following error message:
Exception in thread "main" java.lang.NullPointerException
org.eclipse.birt.report.engine.api.impl.ReportEngine$EngineE xtensionManager. <init>(ReportEngine.java:794)
org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:105)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:18)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$ 1.run(ReportEngineFactory.java:1)
org.eclipse.birt.report.engine.api.impl.ReportEngineFactory. createReportEngine(ReportEngineFactory.java:14)
at com.test.birt.report.MyReportCreator.main(MyReportCreator.ja va:24)
how can I do with it?
Re: create ReportEngine failed [message #368767 is a reply to message #368741] Wed, 24 June 2009 15:49 Go to previous message
Originally posted by: jasonweathersby.windstream.net
Can you try this example. Make sure to mod the birt home.
package org.eclipse.birt.examples.reapi;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import java.util.logging.Level;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IParameterSelectionChoice ;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SlotHandle;
public class RunAndRenderTask {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_3_2\\birt-runtime-2_3_2\\ReportEngi ne ");
config.setLogConfig(null, Level.FINEST);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/topNPercent.rptdesign");
ReportDesignHandle rdh = (ReportDesignHandle)design.getDesignHandle();
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
Map rpMap = new HashMap();
rpMap.put("Top Count", 15);
rpMap.put("Top Percentage", 5);
task.setParameterValues(rpMap);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output/resample/TopNPercent.html ");
options.setOutputFormat("HTML");
//options.setHtmlRtLFlag(false);
options.setImageDirectory("output/resample/images");
options.setEnableAgentStyleEngine(true);
options.setEmbeddable(true);
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
finally
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
catch ( Exception e )
Jason
> code:
> * @param args
> public static void main(String[] args) {
> try {
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
Previous Topic:The report contains error bug
Next Topic:Draw line, rectangle etc..
Current Time: Tue Apr 24 21:23:12 GMT 2018
Powered by FUDForum. Page generated in 0.01490 seconds
