Home » Eclipse Projects » BIRT » Several table filters : "or" condition
Several table filters : "or" condition [message #368618] Tue, 16 June 2009 09:59 Go to next message
Loïc Bertholet is currently offline Loïc BertholetFriend
Member
Hi all,
When adding several items to a Table Filters, an "and" condition is
applied between each of them (ie the result is the intersection of each
filter).
Is there a way to indicate that an "or" condition should be applied (ie
the result is the addition of each filter) ?
Loïc
Re: Several table filters : "or" condition [message #368628 is a reply to message #368618] Tue, 16 June 2009 15:04 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Loïc,
Not currently, but you should be able to use an expression on one filter
to implement your own or.
if( ( row["QUANTITYORDERED"] > 50 ) || (row["ORDERNUMBER"] == 10101 )){
1;
}else{
0;
equals 1
See attached example
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">eq</property>
<expression name="expr">if( (
1;
}else{
0;
}</expression>
<simple-property-list name="value1">
<value>1</value>
</simple-property-list>
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
Loïc Bertholet wrote:
> Hi all,
> filter).
> Loïc
Re: Several table filters : "or" condition [message #368657 is a reply to message #368628] Wed, 17 June 2009 17:23 Go to previous messageGo to next message
Member
Ok thank you Jason.
Can you tell me where can I find how to use "like" and other operators in
an expression ?
I've tried :
if( row["NAME"] like "A%")
if( row["NAME"] like 'A%')
if( row["NAME"] like "A*")
if( row["NAME"] like 'A*')
But nothing works...
Loïc
Jason Weathersby wrote:
> Loïc,
> 1;
> }else{
> 0;
> equals 1
> Jason
>> Hi all,
>> filter).
>> Thanks,
>> Loïc
Re: Several table filters : "or" condition [message #368678 is a reply to message #368657] Thu, 18 June 2009 16:47 Go to previous messageGo to next message
Try
BirtComp.like(row["PRODUCTCODE"],'S18%');
equals
true
Jason
> Ok thank you Jason.
> in an expression ?
> I've tried :
> Loïc
>> Loïc,
>> filter to implement your own or.
>> 1;
>> }else{
>> 0;
>> equals 1
>> Jason
>>> Hi all,
>>> each filter).
>>> (ie the result is the addition of each filter) ?
>>> Thanks,
>>> Loïc
Re: Several table filters : "or" condition [message #368725 is a reply to message #368678] Mon, 22 June 2009 10:34 Go to previous messageGo to next message
Member
Thanks for your answer.
When rendering in HTML, I have the following error...
Am I missing sommething ?
+ The filter definition using expression "if( BirtComp.like(row["name"],
"A%") ){
1;
}else{
0;
}" is not valid.
A BIRT exception occurred: There are errors evaluating script "if(
BirtComp.like(row["name"], "A%") ){
1;
}else{
0;
ReferenceError: "BirtComp" is not defined (<inline>#1).. See next
exception for more information.
There are errors evaluating script "if( BirtComp.like(row["name"], "A%") ){
1;
}else{
0;
Thanks.
> Try
> equals
> true
> Jason
Re: Several table filters : "or" condition [message #368728 is a reply to message #368725] Mon, 22 June 2009 15:08 Go to previous messageGo to next message
What version of BIRT are you using?
> "A%") ){
> 1;
> }else{
> 0;
> }" is not valid.
> 1;
> }else{
> 0;
> 1;
> }else{
> 0;
> Thanks.
>> Try
>> equals
>> true
>> Jason
Re: Several table filters : "or" condition [message #368733 is a reply to message #368728] Mon, 22 June 2009 16:48 Go to previous messageGo to next message
Member
BIRT 2.3.1
>> "A%") ){
>> 1;
>> }else{
>> 0;
>> }" is not valid.
>> 1;
>> }else{
>> 0;
>> 1;
>> }else{
>> 0;
>> Thanks.
>>> Try
>>> equals
>>> true
>>> Jason
Re: Several table filters : "or" condition [message #368754 is a reply to message #368733] Wed, 24 June 2009 14:12 Go to previous messageGo to next message
Loïc
Try the attached report. BTW what Java version are using?
(specifically IBM, Sun, OpenJdk..)
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="operator">like</property>
<expression name="expr">row["ORDERNUMBER"]</expression>
<value>'101%'</value>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<structure>
<expression
name="expr">BirtComp.like(row["PRODUCTCODE"],'S18%');</expression >
<value>true</value>
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
</data>
</cell>
<cell id="24">
<data id="25">
<property
</data>
</cell>
<cell id="26">
<data id="27">
<property
</data>
</cell>
<cell id="28">
<data id="29">
<property
</data>
</cell>
<cell id="30">
<data id="31">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
> BIRT 2.3.1
>>> 1;
>>> }else{
>>> 0;
>>> }" is not valid.
>>> 1;
>>> }else{
>>> 0;
>>> "A%") ){
>>> 1;
>>> }else{
>>> 0;
>>> Thanks.
>>>> Try
>>>> equals
>>>> true
>>>> Jason
Re: Several table filters : "or" condition [message #890022 is a reply to message #368754] Wed, 20 June 2012 15:43 Go to previous messageGo to next message
Stephane Turpin is currently offline Stephane TurpinFriend
To follow this old discussion, I have the same problem as Loic had.
I am trying to add a "Like" filter in an "OR" clause.
In the report design perspective of Eclipse, in the "Filters" tab of the property editor of the table, I added the following filter expression:
BirtComp.like(row["quotationPlace"], "%025%");
then I set the operator to:
Equal to
and the Value1 to:
true
The result is a blank report, no row pass through the filter.
I am using Eclipse Indigo and Birt 3.7.0
If someone has the answer, it would be very helpful.
Re: Several table filters : &quot;or&quot; condition [message #890071 is a reply to message #890022] Wed, 20 June 2012 21:59 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
What are some of your values for quotationPlace and what is its data
type. BTW look at the first table's filter in the attached example.
Jason
> Equal to
> and the Value1 to:
> true
Re: Several table filters : &quot;or&quot; condition [message #890072 is a reply to message #890022] Wed, 20 June 2012 21:59 Go to previous messageGo to next message
Jason
> Equal to
> and the Value1 to:
> true
Re: Several table filters : &quot;or&quot; condition [message #890073 is a reply to message #890022] Wed, 20 June 2012 21:59 Go to previous messageGo to next message
Jason
> Equal to
> and the Value1 to:
> true
Re: Several table filters : &quot;or&quot; condition [message #890074 is a reply to message #890022] Wed, 20 June 2012 21:59 Go to previous messageGo to next message
Jason
> Equal to
> and the Value1 to:
> true
Re: Several table filters : &quot;or&quot; condition [message #890113 is a reply to message #890074] Thu, 21 June 2012 07:42 Go to previous messageGo to next message
The datas I use for my report all have a quotation place of value "025".
Tha data type of quotationPlace is string.
I joined the rptdesign with the filter set if you wish to take a look at it.
Stephane
  • Attachment: trace.zip
    (Size: 8.14KB, Downloaded 134 times)
Re: Several table filters : &amp;quot;or&amp;quot; condition [message #890306 is a reply to message #890113] Thu, 21 June 2012 20:26 Go to previous messageGo to next message
Stephane,
This makes sense that all would get filtered out then. In the filter
you are saying if the string contains 025 filter it out. Try setting to
false.
Jason
> Stephane
Re: Several table filters : &amp;quot;or&amp;quot; condition [message #890451 is a reply to message #890306] Fri, 22 June 2012 10:27 Go to previous messageGo to next message
So it's working the other way around when we use BirtComp.like ?
If , for example, I just want to filter on quotationPlace = "025", the filter will look like:
Expression = row["quotationPlace"]
Oparator = Equal to
Value 1 = "025"
and that works well. And you're saying that for BirtComp.like it would be:
Expression = BirtComp.like(row["quotationPlace"], "%025%");
Oparator = Equal to
Value 1 = false
Anyway, I tried with a Value1 set to false and it still produces a report with no row, only the headers.
It looks like there is a problem with the BIRT function or the javascript.
Re: Several table filters : &amp;amp;quot;or&amp;amp;quot; condition [message #890583 is a reply to message #890451] Fri, 22 June 2012 15:47 Go to previous messageGo to next message
You are correct the value should be true. I am not certain why this is
not working for you. In the example I posted a couple messages back, I
filter the first table with virtually the same expression and it works.
Where you able to test that example report?
Jason
> Oparator = Equal to
> Value 1 = "025"
> Oparator = Equal to
> Value 1 = false
Re: Several table filters : &amp;amp;quot;or&amp;amp;quot; condition [message #892434 is a reply to message #890583] Thu, 28 June 2012 08:32 Go to previous messageGo to next message
sorry for the delay.
I tried your report design and indeed the filter applied on the table works.
The only difference I see between you report and mine is the data source, but I do not see how it could interfere in the result set.
So, I am still stuck.
Even if it works in an "AND" clause, we cannot reasonably explain to our clients that they can use it in an "AND" but not in an "OR" clause.
So in the mean time, I took off the option of "Like" and "Between" in the filter choices of our product.
My last resort is to download BIRT sources and in debugging mode try to see why it does not work.
Re: Several table filters : &amp;amp;amp;quot;or&amp;amp;amp;quot; condition [message #892593 is a reply to message #892434] Thu, 28 June 2012 16:12 Go to previous messageGo to next message
Stephane,
Can you try one more thing. Modify your filter expression to something
like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/filterevents.txt", true ) );
out.println( "--"+row["PRODUCTCODE"]);
out.println( "---"+BirtComp.like(row["PRODUCTCODE"], "%S18%"));
out.close();
BirtComp.like(row["PRODUCTCODE"], "%S18%");
Kind of a bad way to debug, but while birt has javascript event handler
debugging, filtering does not.
Jason
On 6/28/2012 4:32 AM, Stephane Turpin wrote:
> works.
Re: Several table filters : &amp;amp;amp;quot;or&amp;amp;amp;quot; condition [message #892978 is a reply to message #892593] Mon, 02 July 2012 08:21 Go to previous messageGo to next message
Hi Jason,
ok, I tried your debugging code on a simple report design with a column "routingMode" with values in ("Electronique", "Sans routage", "Trade blotter").
If I put this code in the filter expression (Operator still at "Equal to" and value1 at "true):
out = new PrintWriter( new FileWriter( "c:/Temp/filterevents.txt", true ) );
out.println( "---" + row["routingMode"] + "---");
out.close();
true
In the filterevents.txt I have:
---Electronique---
---Trade blotter---
---Electronique---
---Electronique---
---Sans routage---
etc...
and my report is complete (normal, I put "true" in the last line of the filter expression)
But if I had to the filter expression a dummy BirtComp.like like this:
out.println( "---" + BirtComp.like("Electronique", "%ctro%") + "---");
out.close();
true
then the filterevents.txt is created but empty, so is the report.
It seems that something in my environment does not recognize the BirtComp and stop processing the report.
Stephane
Re: Several table filters : &amp;amp;amp;amp;quot;or&amp;amp;amp;amp;quot; condition [message #893151 is a reply to message #892978] Mon, 02 July 2012 22:25 Go to previous messageGo to next message
Are you running 3.7.0? Can you try the attached?
Jason
On 7/2/2012 4:21 AM, Stephane Turpin wrote:
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : &amp;amp;amp;amp;quot;or&amp;amp;amp;amp;quot; condition [message #893152 is a reply to message #892978] Mon, 02 July 2012 22:25 Go to previous messageGo to next message
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : &amp;amp;amp;amp;quot;or&amp;amp;amp;amp;quot; condition [message #893153 is a reply to message #892978] Mon, 02 July 2012 22:25 Go to previous messageGo to next message
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : &amp;amp;amp;amp;quot;or&amp;amp;amp;amp;quot; condition [message #893155 is a reply to message #892978] Mon, 02 July 2012 22:25 Go to previous messageGo to next message
Jason
> Hi Jason,
> blotter").
> out.close();
> true
> ---Electronique---
> ---Trade blotter---
> ---Electronique---
> ---Electronique---
> ---Sans routage---
> etc...
> filter expression)
> out.close();
> true
> Stephane
Re: Several table filters : &amp;amp;amp;amp;quot;or&amp;amp;amp;amp;quot; condition [message #893561 is a reply to message #893155] Wed, 04 July 2012 14:51 Go to previous message
Yes, I am running 3.7.0, and the birtcomptest.zip works.
I am going on vacation for a month (vive la France !) and in august I will install BIRT source and go in debug to try to see where it does not work in my environment.
Thanks for all your answers and I'll keep you informed in august.
Previous Topic:Performance analyasis of BIRT
Next Topic:Report Design Perspective missing from Open Perspective Window
Current Time: Fri Apr 27 07:06:05 GMT 2018
Powered by FUDForum. Page generated in 0.02520 seconds
