Home » Eclipse Projects » BIRT » Add computed column to dataset (BIRT Engine)?
Add computed column to dataset (BIRT Engine)? [message #367945] Tue, 21 April 2009 14:32 Go to next message
Originally posted by: asd.asd.com
I create a dataset using the BIRT engine. Is it possible to add a computed
column to this data set?
OdaDataSetHandle dataSetHandle = elementFactory.newOdaDataSet( name,
"org.eclipse.birt.report.data.oda.xml.dataSet" );
dataSetHandle.setDataSource(dataSrcName);
dataSetHandle.setQueryText(query);
// Add computed columns
ComputedColumn column = StructureFactory.createComputedColumn();
String cname = "var1";
String cexp = "if(row[\"id\"]==\"var1\")row[\"value\"]";
column.setExpression(cexp);
// dataSetHandle.add... ??
Its possible to set a query but how do I add the computed column?
Re: Add computed column to dataset (BIRT Engine)? [message #367946 is a reply to message #367945] Tue, 21 April 2009 14:42 Go to previous message
Sometime a little googling helps :-)
http://wiki.eclipse.org/DerbySampleDE.java
in the bottom.
"JS" <asd@asd.com> wrote in message news:gskldr$htn$1@build.eclipse.org...
Previous Topic:Using parameters from multiple data sets in a single table?
Next Topic:Filtering Groups (DataSets) in the Data Cube Builder
Current Time: Wed Feb 21 21:45:47 GMT 2018
Powered by FUDForum. Page generated in 0.02543 seconds
