Home » Eclipse Projects » BIRT » Setting Chart width
Setting Chart width [message #366549] Fri, 09 January 2009 07:35 Go to next message
Tadej is currently offline TadejFriend
I'm new with eclipse and birt, and have a problem that has been making me
nutts.
I'm trying to resize a chart inserted in a table row. what I need is:
if (reportContext.getOutputFormat() == "pdf"){
this.width ="8,65in";
}else
I already managed it with labels and its styles :
this.getStyle().fontSize ="11px";
this.getStyle().paddingLeft ="1px";
else
this.getStyle();
but I can't get the chart to resize, all I ve tried, nothing worked, the
chart appeared as it is sized in report layout.
Hope you can help me, thanks in advance.
P.S. I'm using BIRT 2.2.2
Re: Setting Chart width [message #366552 is a reply to message #366549] Fri, 09 January 2009 12:03 Go to previous messageGo to next message
Colin Sutton is currently offline Colin SuttonFriend
Member
Try "8.65in" not "8,65in" - your locale is only used in the GUI.
Colin
Tadej wrote:
> Hello,
> me nutts.
> }else
> else
> this.getStyle();
Re: Setting Chart width [message #366564 is a reply to message #366552] Mon, 12 January 2009 08:18 Go to previous messageGo to next message
I've already tried, but still no change!
Any more ideas??
Thanks in advance
> Colin
> Tadej wrote:
>> Hello,
>> me nutts.
>> }else
>> else
>> this.getStyle();
Re: Setting Chart width [message #366578 is a reply to message #366564] Mon, 12 January 2009 18:45 Go to previous messageGo to next message
Take a look at this blog post.
http://birtworld.blogspot.com/2008/04/birt-resizing-charts.h tml
Jason
> Any more ideas??
> Thanks in advance
>> Colin
>> Tadej wrote:
>>> Hello,
>>> making me nutts.
>>> }else
>>> else
>>> this.getStyle(); }
>>> the chart appeared as it is sized in report layout.
Re: Setting Chart width [message #366586 is a reply to message #366578] Tue, 13 January 2009 11:22 Go to previous message
Hello Jason
Thank you very much, that rely helped me. Thank you again.
Tadej
> Jason
>> Any more ideas??
>> Thanks in advance
>>> Colin
>>> Tadej wrote:
>>>> Hello,
>>>> making me nutts.
>>>> }else
>>>> else
>>>> this.getStyle(); }
Previous Topic:Using Viewer In RCP
Next Topic:org.eclipse.birt.api exports wrong packages, so there is a ClassNotFoundException for com.ibm.icu.te
Current Time: Wed Apr 25 03:21:23 GMT 2018
Powered by FUDForum. Page generated in 0.02047 seconds
