Home » Eclipse Projects » BIRT » Difference on ReportDesignHandle between onPrepare and beforeFactory
Difference on ReportDesignHandle between onPrepare and beforeFactory [message #366436] Tue, 30 December 2008 17:17 Go to next message
Loïc Bertholet is currently offline Loïc BertholetFriend
Member
Hi all,
I want to dynamically add columns on a Table.
I tried on the beforeFactory(...) method of ReportEventHandler and
everything is alright.
Then I tried on the onPrepare(...) method of TableEventHandler with the
same code but it didn't work.
It both case, I use the following code to get the TableHandle :
(TableHandle) reportContext.getDesignHandle().findElement("myTableName")
With the debugger, I saw that I have the same instance of reportContext in
each method. But the ReportDesignHandle behind is not the same... I guess
this is why I don't have the same final result.
But is it normal or is it a bug ?
Or maybe I don't use the good way to get the TableHandle on the
onPrepare(...) method ?
Loïc
Re: Difference on ReportDesignHandle between onPrepare and beforeFactory [message #366442 is a reply to message #366436] Tue, 30 December 2008 22:23 Go to previous messageGo to next message
Loïc,
I believe it is getting a cloned version of the design handle.
Can you log a bug for this?
Jason
Loïc Bertholet wrote:
> Hi all,
> in each method. But the ReportDesignHandle behind is not the same... I
> guess this is why I don't have the same final result.
> Loïc
Re: Difference on ReportDesignHandle between onPrepare and beforeFactory [message #366481 is a reply to message #366442] Mon, 05 January 2009 14:30 Go to previous message
Member
Ok it's done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=259948
Previous Topic:Interactive report
Next Topic:BIRT 2.3.1 slower than 2.2.0
Current Time: Sat May 26 16:06:01 GMT 2018
Powered by FUDForum. Page generated in 0.02082 seconds
