| Error when creating new BIRT report [message #366345] |
Wed, 17 December 2008 08:49  |
Originally posted by: asd.asd.com
I have installed BIRT 2.3.1 on eclipse 3.4.1 for Windows Vista 32. I have
then created a new BIRT project and in that project created a Simple Report
(.rptdesign file). The report loads fine but I get the error:
"The Table must be able to access one data set."
When I switch to the XML source view the error is in this line:
<table id="4">
from this context:
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="4"> // HERE!
<property name="width">100%</property>
<property name="pageBreakInterval">50</property>
<column id="20"/>
<column id="21"/>
<column id="22"/>
I have tried to add a XML data Source and specify and XML file with some
content. Next I also specified a Data Set (using the XML file) which I
successfully setup. But the error is still there, any ideas?
| Re: Error when creating new BIRT report [message #366350 is a reply to message #366345] |
Wed, 17 December 2008 11:06  |
Problem solved, just needed to add (drag/drop) some data.
"bob" <asd@asd.com> wrote in message news:gib01p$qde$1@build.eclipse.org...
> <table id="4">
> from this context:
> </text>
> </page-footer>
> </page-setup>
> <body>
> <column id="20"/>
> <column id="21"/>
> <column id="22"/>
FUDForum. Page generated in 0.01572 seconds
