Home » Eclipse Projects » BIRT » Deploying BIRT
Deploying BIRT [message #365479] Fri, 03 October 2008 22:29 Go to next message
Nick P. is currently offline Nick P.
I recently began using BIRT and have developed a report to use with my
xulrunner application. What I haven't yet figured out is how I should
deploy the viewer. It seems like BIRT mostly targets Java applications, so
there are instructions for deploying on J2EE, JBoss, and other
technologies -- with which I am not familiar (but I'm not developing in
Java anyway).
Reviewing this article
( http://www.onjava.com/pub/a/onjava/2006/07/26/deploying-birt .html) on
deploying BIRT and reviewing the deployment details
(http://www.eclipse.org/birt/phoenix/deploy/) on BIRT's web site, I'm not
sure where to go. I wasn't expecting to have to add some large Java
dependency for the xulrunner application --is there no way I can drop an
executable in with my xulrunner app, call it from my app, and pass it a
report document? (Or something else that would be simpler than learning
and using J2EE, JBoss, tomcat?)
Re: Deploying BIRT [message #365482 is a reply to message #365479] Sat, 04 October 2008 00:02 Go to previous messageGo to next message
Eclipse User
Originally posted by: johnw.innoventsolutions.com
You can create a real simple Java application that just runs and renders
reports without needing any J2EE container. You are still bound by
needing some sort of Java VM to run the application though.
However, I have had success using Excelsior Jet to build a native
Windows and Linux executable that ran BIRT reports and rendered them.
Its rather huge end result, but it does work.
Outside of that, I don't know what to say. I am not real familiar with
xulrunner.
John
> so there are instructions for deploying on J2EE, JBoss, and other
> Java anyway).
> not sure where to go. I wasn't expecting to have to add some large Java
Re: Deploying BIRT [message #365484 is a reply to message #365482] Sat, 04 October 2008 18:18 Go to previous message
Jim Hale is currently offline Jim Hale
That worked... Thanks for your help on this as well as the pointers to the
doc on the josso problem. Both work now!
Previous Topic:Setting a variable from a non-scripted datasource
Next Topic:Upgrade from Birt 2.2.2 to Birt 2.3.1 - issues with styles and css
Current Time: Tue May 21 09:57:44 EDT 2013
Powered by FUDForum. Page generated in 0.01546 seconds
