Home » Eclipse Projects » BIRT » how to get PDF export to use stylesheet?
how to get PDF export to use stylesheet? [message #365412] Wed, 01 October 2008 22:47 Go to next message
Rowan Maclaren is currently offline Rowan MaclarenFriend
Member
I am using BIRT 2.3.1. The PDF emitter is ignoring the external css. How
can I get it to use the css? I have the following in the .rptdesign:
<list-property name="cssStyleSheets">
<structure>
<property name="fileName">web/css/birt.css</property>
</structure>
</list-property>
The uri for the same css file would be: /mvwebreports/css/birt.css
-- Rowan
Re: how to get PDF export to use stylesheet? [message #365433 is a reply to message #365412] Thu, 02 October 2008 13:51 Go to previous messageGo to next message
Rowan,
If you are using the "use external style sheets" feature and do not
check the box to specify a url then this filename must be in the
resource folder or the directory of the report design. If you check the
box you can specify a url which should produce xml like:
> <structure>
> <property name="fileName">mybirt.css</property>
> <property name="externalCssURI">css/mybirt.css</property>
> </structure>
> </list-property>
Jason
Rowan Maclaren wrote:
> <structure>
> </structure>
> </list-property>
> -- Rowan
Re: how to get PDF export to use stylesheet? [message #365450 is a reply to message #365433] Thu, 02 October 2008 17:39 Go to previous messageGo to next message
Member
Hi Jason,
1. The pdf emitter is much fussier about the styles than the html
emitter. There are log entries of css style errors, but no information
about the offending line. e.g.
Oct 2, 2008 1:16:14 PM
org.eclipse.birt.report.model.css.StyleSheetLoader semanticWarning
WARNING: Error.StyleSheetParserException.STYLE_NOT_SUPPORTED
My theory is that the pdf emitter gives up, whereas the html emitter
applies the styles it can.
2. I tried to use the URL checkbox, but the ok button remains grayed
out. Also, the url checkbox states: "Include CSS file at view time(Apply
only to HTML format)." so presumably it does not apply for PDF format.
-- Rowan
Jason Weathersby wrote:
> Rowan,
> > <structure>
> > </structure>
> > </list-property>
> Jason
>> How can I get it to use the css? I have the following in the .rptdesign:
>> <structure>
>> </structure>
>> </list-property>
>> -- Rowan
Re: how to get PDF export to use stylesheet? [message #365454 is a reply to message #365450] Thu, 02 October 2008 21:50 Go to previous messageGo to next message
Rowan,
you are correct, the pdf emitter will only use the style if it finds the
style at the fileName attribute. If you email me the css I will take
a look at what style it is failing on.
Jason
> Hi Jason,
> -- Rowan
>> Rowan,
>> the box you can specify a url which should produce xml like:
>> > <structure>
>> > </structure>
>> > </list-property>
>> Jason
>>> Hi,
>>> <structure>
>>> </structure>
>>> </list-property>
>>> -- Rowan
Re: how to get PDF export to use stylesheet? [message #365457 is a reply to message #365454] Thu, 02 October 2008 22:11 Go to previous message
Member
--------------040305040905070008030900
Thank you Jason. I appreciate it.
The css has a mix of styles for the standard birt classes and for custom
bookmark ids.
-- Rowan
> Rowan,
> style at the fileName attribute. If you email me the css I will take a
> Jason
>> Hi Jason,
>> time(Apply only to HTML format)." so presumably it does not apply for
>> PDF format.
>> -- Rowan
>>> Rowan,
>>> > <structure>
>>> > </structure>
>>> > </list-property>
>>> Jason
>>>> Hi,
>>>> .rptdesign:
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> -- Rowan
Content-Type: text/css;
name="birt.css"
Content-Disposition: inline;
filename="birt.css"
#reportTitle {
z-index: 1;
text-align: left !important;
display: block;
padding-right: 365px;
xwidth: 100% !important;
padding-bottom: 5px !important;
padding-top: 20px !important;
font-size: 20px !important;
font-family: Lucida Sans, Jamrul, Verdana, Arial !important;
fontWeight: bold !important;
color: #628095 !important;
border-top: 2px #628095 solid;
line-height: 1.2em;
position: relative;
..table-header, .style_1, #headerRow, #headerRowGrid {
color: black;
backgroundColor: #9ABDD0;
font-family: Verdana, Arial !important;
font-size: 0.7em;
font-weight: bold !important;
align: left;
valign: top;
margin-top: 20px;
margin-bottom: 20px;
background-color: rgb(154, 189, 208);
#headerRowGrid th {
border-right: 1px ridge #CCCCCC !important;
border-left: 1px ridge #CCCCCC !important;
..table-group-header-2, .table-detail, .table-group-header-2, #detailRowGrid, .style_2 {
text-indent: 0.5em;
align: left;
margin-top: 4px;
margin-bottom: 4px;
font-weight: normal;
font-family: Arial, Verdana;
font-size: 0.8em;
overflow: hidden;
#detailRowGrid td {
border: 1px ridge #DDF0F8 !important;
#numericTH {
text-align: right;
margin-right: 20px;
#numericTD {
text-align: right;
margin-right: 30px;
#numericTH2column {
text-align: right;
padding-right: 200px;
margin-right: 20px;
#numericTD2column {
text-align: right;
margin-right: 30px;
#groupTitle {
font-family: Arial;
font-weight: bolder;
color: #628095;
..table-group-header-1, #groupHeader {
color: #555555;
font-weight: bold;
text-align: left;
font-size: 0.8em !important;
text-indent: 0px !important;
font-weight: bold;
..table-group-footer, .table-group-footer-2, #groupFooter, #groupFooter2 {
border-top: 1px ridge #DDF0F8;
..tableFooter, #parameters {
color: #555555;
font-size: 0.8em;
..noData, .comparisonActivityNoData, #noData {
font-family: Arial;
font-size: larger;
color: #FF8040;
text-align: center;
#navigationBar {
color: #555555;
tr#legend,#legendHeader th {
color: #555555;
font-weight: bold;
text-align: left;
text-indent: 0px;
align: right;
padding-top: 1em;
table#fixedTableHeader {
width: 95%;
--------------040305040905070008030900--
Previous Topic:websphere crashed running birt report
Next Topic:BIRT 2.3.1 CSV export data dialog broken?
Current Time: Sat May 26 00:47:45 GMT 2018
Powered by FUDForum. Page generated in 0.01586 seconds
