Can not get entry named /DataEngine/NamingRelation because the archive file has,been closed. System [message #365043] |
Mon, 08 September 2008 09:23 |
Originally posted by: moi.toto.com
Each time i'm generating report through birt-viewer, I've got this error
in jboss logs :
10:55:07,929 INFO [STDOUT]
org.eclipse.birt.data.engine.core.DataException: A r
eport document error occurred when getting the save stream.
file has
been closed. System ID: null
10:55:07,932 INFO [STDOUT] at
org.eclipse.birt.data.engine.api.DataEngineCo
ntext.getOutputStream(DataEngineContext.java:292)
10:55:07,933 INFO [STDOUT] at
org.eclipse.birt.data.engine.impl.document.Ba
seSave.saveNamingRelation(BaseSave.java:53)
10:55:07,935 INFO [STDOUT] at
org.eclipse.birt.data.engine.impl.ResultItera
tor$RDSaveHelper.saveNamingRelation(ResultIterator.java:1115 )
10:55:07,938 INFO [STDOUT] at
tor$RDSaveHelper.access$2(ResultIterator.java:1112)
10:55:07,940 INFO [STDOUT] at
tor.saveNamingRelation(ResultIterator.java:892)
10:55:07,943 INFO [STDOUT] at
tor.close(ResultIterator.java:846)
10:55:07,944 INFO [STDOUT] at
tor.finalize(ResultIterator.java:874)
10:55:07,946 INFO [STDOUT] at
java.lang.ref.Finalizer.invokeFinalizeMethod(
Native Method)
10:55:07,949 INFO [STDOUT] at
java.lang.ref.Finalizer.runFinalizer(Finalize
r.java:83)
10:55:07,953 INFO [STDOUT] at
java.lang.ref.Finalizer.access$100(Finalizer.
java:14)
10:55:07,955 INFO [STDOUT] at
java.lang.ref.Finalizer$FinalizerThread.run(F
inalizer.java:160)
10:55:07,956 INFO [STDOUT] Caused by: java.io.IOException: Can not get
entry na
med /DataEngine/NamingRelation because the archive file has been closed.
System
Do you know how to avoid it ?
Blured.
Re: Can not get entry named /DataEngine/NamingRelation because the archive file has,been closed. Sys [message #365050 is a reply to message #365043] |
Mon, 08 September 2008 15:52 |
Moi,
Take a look at bug 236389, which should be fixed in the 2.3.1 build.
Jason
moi wrote:
> Hello,
> in jboss logs :
> file has
> Native Method)
> r.java:83)
> java:14)
> inalizer.java:160)
> entry na
> System
> Blured.
FUDForum. Page generated in 0.02088 seconds
