Home » Eclipse Projects » DSDP - Target Management » Using privileged ports for RSE
Using privileged ports for RSE [message #36693] Wed, 01 July 2009 07:47 Go to next message
Denise Schmidt is currently offline Denise Schmidt
Member
Is there a limitation on using privileged ports (<1024) for the
serverPortRange for RSE? We can use a privileged port for the daemon port
but when we tried using privileged ports for the serverPortRange, it looks
like it answers the connection request, but the connection fails.
We are attempting this in an effort to make the connections more secure so
if there is some limitation, we are interested in how we could remove the
limitation.
Thanks.
Re: Using privileged ports for RSE [message #36897 is a reply to message #36693] Thu, 02 July 2009 11:06 Go to previous messageGo to next message
David McKnight is currently offline David McKnight
Hi Denise,
The RSE dstore server doesn't distinguish between privileged and
non-privileged ports so I'm not sure what's causing the connection to fail
in this case.
Dave
"Denise Schmidt" <denise.schmidt@lmco.com> wrote in message
news:54182907978dce56be59393be8a5b7bb$1@www.eclipse.org...
> limitation.
> Thanks.
Re: Using privileged ports for RSE [message #36930 is a reply to message #36897] Thu, 02 July 2009 12:04 Go to previous messageGo to next message
Member
In order to bind a socket to a privileged port, the process must be
running as root. So I think it must be failing because the server process
is running as the client user ID (auth.pl does an "su" to the client user
ID to spawn the server). I assume that the server runs as the client user
ID for a reason (exporting the client environment, client permissions,
etc).
So my next question would be is there a way that the server could maybe
start executing as root to bind the socket and make the connection, then
switch to the client user ID to get the proper environment and do the
remaining "real" work? Could that work or would there still be problems
sending data over the port?
Re: Using privileged ports for RSE [message #36964 is a reply to message #36930] Thu, 02 July 2009 14:23 Go to previous message
news:863819bfe4506ac862880afe40272127$1@www.eclipse.org...
> etc).
That would explain it then. The daemon needs to be run as root but the
servers that gets started as run as the client user.
At the moment there is no ability to for the server to start executing as
root and then switch to the client user.
Re: Using privileged ports for RSE [message #581650 is a reply to message #36693] Thu, 02 July 2009 11:06 Go to previous message
Hi Denise,
in this case.
Dave
> limitation.
> Thanks.
Re: Using privileged ports for RSE [message #581662 is a reply to message #36897] Thu, 02 July 2009 12:04 Go to previous message
Member
etc).
Re: Using privileged ports for RSE [message #581678 is a reply to message #36930] Thu, 02 July 2009 14:23 Go to previous message
> etc).
Previous Topic:RSE: Impossible to connect from a Windows PC to a Sun Workstation via FTP
Next Topic:Cygwin Support?
Current Time: Thu Jun 20 00:45:23 EDT 2013
Powered by FUDForum. Page generated in 0.02102 seconds
