Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » support for map types in uml2 or emf
support for map types in uml2 or emf [message #35169] Thu, 25 May 2006 20:12 Go to next message
Originally posted by: solomono.yahoo.com
I must create a property/attribute of type map in UML2 or EMF class
Is there a mechanism in which this can be done such that the code
generator generates the appropriate type and accessors in java, is this
possible in either emf or uml2 or both.
How is access supported through the emft ocl engine if at all
If this is not supported any direction on how to implement this would
be helpful
Solomon
Re: support for map types in uml2 or emf [message #35192 is a reply to message #35169] Thu, 25 May 2006 20:22 Go to previous messageGo to next message
Solomon,
EMF and UML are in eclipse.tools, not eclipse.technology...
There have been quite a few questions about EMap/Map support in in the
EMF newsgroup. You should search and look at those. An example of map
support is EAnnotation's details feature. An EMap is effectively just
modeled as a containment reference to objects that implement Map.Entry,
so you should be able to access them like any other containment feature.
Solomon Obi wrote:
> Hi
> this possible in either emf or uml2 or both.
> be helpful
> Solomon
Re: support for map types in uml2 or emf [message #35464 is a reply to message #35192] Tue, 30 May 2006 07:14 Go to previous messageGo to next message
Philipp W. Kutter is currently offline Philipp W. KutterFriend
Hi, Solomon.
I would be interested in your second question, whether Ocl can access
maps specified in EMF.
Regarding the first: Ed is right the info is out there.
Collecting all the info about maps is hard, but all is there.
All you need to know is the following:
for maps being returned:
@model ... keyType="xxx" valueType="yyy"
for parameters:
@model .... myFirstParameterKeyType="aaa" myFirstParameterValueType="bbb"
Then reload the ECore from Java, and EMF will generate the
corresponding XxxToYyyMapEntry and AaaToBbbMapEntry types, and
use them as types of the return or parameter stuff.
One can as well set the map types explicitly, but we never did
this.
Regards, Philipp
Ed Merks wrote:
> Solomon,
> Solomon Obi wrote:
>> Hi
>> be helpful
>> Solomon
Re: support for map types in uml2 or emf [message #35507 is a reply to message #35464] Tue, 30 May 2006 11:26 Go to previous messageGo to next message
Philipp,
I don't think OCL is aware that there are EMaps in the model, but I
could be wrong. It will just see that as yet another containment
reference and will let you access the items by position or perhaps (I
know very little about OCL) by matching an item in the containment
reference that has a particular key value...
Philipp W. Kutter wrote:
> Hi, Solomon.
> for parameters:
> this.
> Regards, Philipp
> Ed Merks wrote:
>> Solomon,
>> the EMF newsgroup. You should search and look at those. An example
>> of map support is EAnnotation's details feature. An EMap is
>> effectively just modeled as a containment reference to objects that
>> implement Map.Entry, so you should be able to access them like any
>> Solomon Obi wrote:
>>> Hi
>>> be helpful
>>> Solomon
Re: support for map types in uml2 or emf [message #35537 is a reply to message #35507] Tue, 30 May 2006 13:16 Go to previous messageGo to next message
Hi, Ed, Solomon,
OCL will see a property of type Collection(EMapEntry) or whatever the type
of an entry is (I forget just now). So, this collection can be iterated
like any other and its elements accessed. The only trouble is, that the
map entry type is an EDataType, which means that OCL can't really do
anything with it.
UML allows DataTypes to define features (properties and operations), which
Ecore does not. This would be a good enhancement to raise on EMFT OCL's
bugzilla: to provide access to the features of an EDataType, as defined by
its Java implementation class.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT& ;version=1.0&component=OCL&bug_severity=enhancement& amp;form_name=enter_bug
Christian
Ed Merks wrote:
> Philipp,
Correction [Re: support for map types in uml2 or emf] [message #35571 is a reply to message #35537] Tue, 30 May 2006 14:16 Go to previous message
Hi, all,
I confused the EMap representation in Ecore with something else (feature
maps), with which I am more familiar.
"feature maps" vs. "map features" -- no wonder.
Anyways, Ecore models EMap features as containment references typed by an
EClass that defines an instance class. This instance class is a kind of
Map.Entry and defines (via EOperations and EStructuralFeatures) the
features required by OCL to access the mapped keys and values.
So, you should be able to iterate the contents of your EMap feature which
OCL sees as a Collection of objects like any other, and use the entry
class's features to inspect those contents.
Of course, none of this detracts from the need for better EDataType support
in OCL.
HTH,
Christian
Christian W. Damus wrote:
> Hi, Ed, Solomon,
> anything with it.
> by its Java implementation class.
> Cheers,
> Christian
> Ed Merks wrote:
>> Philipp,
Re: support for map types in uml2 or emf [message #578924 is a reply to message #35169] Thu, 25 May 2006 20:22 Go to previous message
Solomon,
Solomon Obi wrote:
> Hi
> be helpful
> Solomon
Re: support for map types in uml2 or emf [message #579086 is a reply to message #35192] Tue, 30 May 2006 07:14 Go to previous message
Hi, Solomon.
for parameters:
this.
Regards, Philipp
Ed Merks wrote:
> Solomon,
> Solomon Obi wrote:
>> Hi
>> be helpful
>> Solomon
Re: support for map types in uml2 or emf [message #579119 is a reply to message #35464] Tue, 30 May 2006 11:26 Go to previous message
Philipp,
> Hi, Solomon.
> for parameters:
> this.
> Regards, Philipp
> Ed Merks wrote:
>> Solomon,
>> Solomon Obi wrote:
>>> Hi
>>> be helpful
>>> Solomon
Re: support for map types in uml2 or emf [message #579148 is a reply to message #35507] Tue, 30 May 2006 13:16 Go to previous message
Hi, Ed, Solomon,
anything with it.
Christian
Ed Merks wrote:
> Philipp,
Correction [Re: support for map types in uml2 or emf] [message #579165 is a reply to message #35537] Tue, 30 May 2006 14:16 Go to previous message
Hi, all,
in OCL.
HTH,
Christian
> Hi, Ed, Solomon,
> anything with it.
> Cheers,
> Christian
> Ed Merks wrote:
>> Philipp,
Previous Topic:JET 1.0.0: incomplete xpath expressions?
Next Topic:[Announce] EMFT JETEDITOR 1.0.0RC6 is available
Current Time: Mon May 28 03:42:58 GMT 2018
Powered by FUDForum. Page generated in 0.01956 seconds
