Home » Eclipse Projects » DSDP - Target Management » RSE terminals and windows tiling
RSE terminals and windows tiling [message #34930] Wed, 06 May 2009 13:30 Go to next message
Igor Moiseev is currently offline Igor MoiseevFriend
Usually, debugging the programs I need to keep more than one terminal
window in eclipse with RSE.
If anybody knows, is it possible to open the terminal tabs in tiles?
And in general, how do I open in tiles the tabs of the main editor window?
Tiling concept: http://en.wikipedia.org/wiki/Tiling_window_manager
Thank you.
Re: RSE terminals and windows tiling [message #34998 is a reply to message #34930] Tue, 12 May 2009 17:39 Go to previous message
Martin Oberhuber is currently offline Martin OberhuberFriend
Hi Igor,
you cannot tile the RSE Terminal, but you can have multiple instances
of the TM Terminal View: Make sure that the TM Terminal component is
installed, then Window > Show View > Terminal > Terminal
It has user help (F1) that explains the view buttons, which include
"Create new View".
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Thank you.
Re: RSE terminals and windows tiling [message #580670 is a reply to message #34930] Tue, 12 May 2009 17:39 Go to previous message
Hi Igor,
"Create new View".
> Thank you.
Previous Topic:TCF agent issue
Next Topic:DStore Deamon - binary version for embedded devices
Current Time: Tue May 22 06:35:32 GMT 2018
Powered by FUDForum. Page generated in 0.01975 seconds
