Home » Eclipse Projects » Eclipse Platform » P2 - "Install New Software" behind company proxy
P2 - "Install New Software" behind company proxy [message #336597] Wed, 24 June 2009 17:33 Go to next message
Ivan is currently offline IvanFriend
First let me congratulate you for the galileo release.. one love...
Today we ( 14 developers of a german car manufactory ) run into a very
strange problem with the p2 update manager. We can not connect to a
eclipse update site
- even not a to galileos own.
Every attempt ends with something like this :
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception:
Unable to read repository at
http://download.eclipse.org/tools/mylyn/update/e3.4/content. xml.
org.eclipse.equinox.internal.p2.metadata.repository.CacheMan ager.createCache(CacheManager.java:179)
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleM etadataRepositoryFactory.java:60)
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.validateAndLoad(Simp leMetadataRepositoryFactory.java:99)
Caused by: java.net.SocketException: Socket is closed
at java.net.Socket.setTcpNoDelay(Socket.java:825)
org.eclipse.ecf.provider.filetransfer.events.socket.Abstract SocketWrapper.setTcpNoDelay(AbstractSocketWrapper.java:187)
org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:721)
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1361)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
the think is that we sit behind several proxies when at work.
Even when the proxy settings are set correctly - we could connect to our
bugzilla repository and even when trying galileos Test Connection feature
it shows that the requested URL is available.
Some month ago we had a "similar" problem with ivy RC1 when trying to
resolve jars from ibiblio. We found out that it was a http HEAD request
that that was causing the trouble. For some reason the proxies couldn't
handle it correctly so the ivy guys added a configurable option to always
use a GET request.
Before we start looking into it deeper it would be great to know if
somebody has a explanation for this behaviour.
Now from my home machines everything works fantastic like always.
Ivan
Re: P2 - "Install New Software" behind company proxy [message #336677 is a reply to message #336597] Fri, 26 June 2009 17:46 Go to previous messageGo to next message
Jose Otavio Carlomagno Filho is currently offline Jose Otavio Carlomagno FilhoFriend
I'm having the same problem, this is the stack trace the error log gives
me:
http://download.eclipse.org/eclipse/updates/3.5/content.xml.
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.load(SimpleMetadataR epositoryFactory.java:87)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :54)
org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:669)
org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:617)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
org.apache.commons.httpclient.HttpParser.readRawLine(HttpPar ser.java:78)
at org.apache.commons.httpclient.HttpParser.readLine(HttpParser .java:106)
org.apache.commons.httpclient.HttpConnection.readLine(HttpCo nnection.java:1116)
org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnect ionManager.java:1413)
org.apache.commons.httpclient.HttpMethodBase.readStatusLine( HttpMethodBase.java:1973)
org.apache.commons.httpclient.HttpMethodBase.readResponse(Ht tpMethodBase.java:1735)
org.apache.commons.httpclient.HttpMethodBase.execute(HttpMet hodBase.java:1098)
org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:398)
org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:346)
org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientF ileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java :188)
org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSys temBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:7 1)
... 1 more
I tried changing the proxy settings but it still doesn't work, but when I
use Eclipse 3.4 it accesses the update sites correctly (including
Galileo's site).
Re: P2 - "Install New Software" behind company proxy [message #336683 is a reply to message #336677] Fri, 26 June 2009 18:47 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=281472
Paul Webster
Re: P2 - "Install New Software" behind company proxy [message #629187 is a reply to message #336683] Mon, 27 September 2010 12:58 Go to previous message
Suganya Devi is currently offline Suganya DeviFriend
I'm facing some problems with our application, not sure if its something todo with the Proxy.
I'm getting Nullpointer exception at RepositoryTransport.download(RepositoryTransport.java:75) if I point to a remote repository. It works fine with local repository in the build directory. I have created the following bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=323149. Please let me know if anyone has a solution for this.
Previous Topic:Problems in cheatsheet passing parameters to commands.
Next Topic:Why some items aren't uninstallable with galileo?
Current Time: Sun Apr 22 03:23:03 GMT 2018
Powered by FUDForum. Page generated in 0.02008 seconds
