Home » Eclipse Projects » Eclipse Platform » Eclipse 3.x for AIX 5.3
Eclipse 3.x for AIX 5.3 [message #336567] Tue, 23 June 2009 22:15 Go to next message
Barbara Iszard is currently offline Barbara IszardFriend
I have ownership of installing Eclipse on a couple AIX 5.3 servers. I have
2 elementary questions that I'm hoping someone can answer.
Question 1)
When I go to download eclipse-SDK-3.x.x-aix-motif.zip I get a message that
says:
To run Eclipse on AIX, you must ensure that your AIX install includes the
necessary filesets and service updates. Please use the following command
to determine the service level of an AIX fileset on your machine:
lslpp -l | grep FilesetName
Please see the section below that corresponds to your AIX release.
All AIX releases:
Fileset X11.adt.lib must be installed (this is available on the AIX
installation media).
AIX Version 4.3.3:
For fileset X11.base.lib:
If service level < 4.3.3.79, you must apply APAR IY27694
For fileset X11.motif.lib:
If service level > 4.3.3.81, you must apply APAR IY41939
AIX Version 5.1:
If service level < 5.1.0.25, you must apply APAR IY27695
If service level > 5.1.0.36, you must apply APAR IY41942
AIX Version 5.2:
If service level > 5.2.0.0, you must apply APAR IY41944
Is there really no requirement for AIX Version 5.3? Or is it just that
it's not compatible with AIX 5.3 or something else?
Question 2:
I'm suspicious of the download because it is a zip file. When I open it in
Windows it looks like it would install to Windows directories (ie. the
slashes in the path are going the wrong direction). Normally compressed
AIX files end in TAR or gz. That is the case for the Eclipse download
files for Linux. Am I missing something?
Any help would be appreciated
Re: Eclipse 3.x for AIX 5.3 [message #336598 is a reply to message #336567] Wed, 24 June 2009 17:36 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
I don't know much about AIX. It could just be that the download note
just hasn't been updated recently. You should ask on
eclipse.platform.swt, I think they take care of that download message.
As for the archive, the back slashes are likely just because you are
looking at it on windows. The archive itself would have been created on
linux. I see this:
/eclipse/zips> unzip -l eclipse-SDK-3.5-aix-motif.zip
Archive: eclipse-SDK-3.5-aix-motif.zip
Length Date Time Name
0 06-11-09 18:57 eclipse/
6506 03-17-05 17:12 eclipse/notice.html
0 06-11-09 18:57 eclipse/configuration/
817 06-11-09 18:57 eclipse/configuration/config.ini
0 06-11-09 18:57 eclipse/configuration/org.eclipse.update/
-Andrew
> have 2 elementary questions that I'm hoping someone can answer.
> Question 1)
> that says:
> the necessary filesets and service updates. Please use the following
> command
> All AIX releases:
> AIX Version 4.3.3:
> If service level < 4.3.3.79, you must apply APAR IY27694 For
> AIX Version 5.1:
> AIX Version 5.2:
> Question 2:
> in Windows it looks like it would install to Windows directories (ie.
> the slashes in the path are going the wrong direction). Normally
> compressed AIX files end in TAR or gz. That is the case for the Eclipse
> download files for Linux. Am I missing something?
Re: Eclipse 3.x for AIX 5.3 [message #336599 is a reply to message #336598] Wed, 24 June 2009 17:47 Go to previous messageGo to next message
I just talked to an SWT committer, our AIX drop is actually built on
5.3, so it will work there. He wasn't sure about the APARs, but he
thought you might be good to go straight out of the box.
-Andrew
> linux. I see this:
> -Andrew
>> Question 1)
>> that says:
>> command
>> All AIX releases:
>> AIX Version 4.3.3:
>> AIX Version 5.1:
>> AIX Version 5.2:
>> Question 2:
>> it in Windows it looks like it would install to Windows directories
>> (ie. the slashes in the path are going the wrong direction). Normally
>> Eclipse download files for Linux. Am I missing something?
Re: Eclipse 3.x for AIX 5.3 [message #336604 is a reply to message #336599] Wed, 24 June 2009 22:27 Go to previous message
Thanks for your reply. I've seen a number of postings of Eclipse 3.2 and
AIX 5.3 issues so I'm planning to go with Eclipse 3.0. That's what's
recommended for the app that I'm planning to plug into anyway.
I'm still confused as to why the Eclipse folks would tar the Linux install
and not the AIX install. Because the AIX installs are zipped I now have to
go find some unzip software and get it approved to be installed on the AIX
servers.
I'll get over it.
Previous Topic:eclipse 3.3 rcp could not be launched on SESU Linux 10
Next Topic:Getting wrong selection, sometimes
Current Time: Sun Apr 22 12:56:11 GMT 2018
Powered by FUDForum. Page generated in 0.01663 seconds
