Home » Eclipse Projects » Eclipse Platform » Commands and Toolbar and Toggle style buttons?
Commands and Toolbar and Toggle style buttons? [message #336423] Wed, 10 June 2009 20:37 Go to next message
Originally posted by: eclipse-newsgroups.scharf.gr
I am trying to do a very simple thing: I want to add
a simple button to the windows menu and the tool bar
and it should be a toggle button. I used the "Hello world
Command" template.
I have the following problems:
1. if I add it to the toolbar as in the with
locationURI as:
toolbar:org.eclipse.ui.main.toolbar?after=additions
the button appears but in the "Customize perspective"
the tool bar has no group and I am too stupid to figure
out how to create a group :-(
2. How do I update the toggle state of the tool bar command
and the menu command? (they should somehow listen to the
state of my Handler). I am sure there is somewhere some
magic, but I was unable to figure it out...
So, I thought I'd better ask the experts:
http://michaelscharf.blogspot.com/2009/05/why-is-rcp-emf-p2- databinding-so-hard.html
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Commands and Toolbar and Toggle style buttons? [message #336427 is a reply to message #336423] Thu, 11 June 2009 06:16 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
> Command" template.
The "Hello World" Command template, is what its meant to be - the
starting point to understand the commands. It adds a command, a handler,
a binding and two UI contributions (menu and toolbar).
If you really wanted to learn beyond a "Hello World" example, I would
suggest you to get into the following links:
http://blog.eclipse-tips.com/search/label/Commands
Is there something more can be done to simplfy the learning?
- Prakash
Re: Commands and Toolbar and Toggle style buttons? [message #336435 is a reply to message #336427] Thu, 11 June 2009 14:42 Go to previous messageGo to next message
Prakash,
Great links! But I still cannot figure out how
the heck I create a group so it appears in the
customize perspective as something that I can select
(with a name).
Michael
>> Command" template.
> - Prakash
Michael Scharf
Re: Commands and Toolbar and Toggle style buttons? [message #336439 is a reply to message #336423] Thu, 11 June 2009 18:08 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Those groups each represent one toolbar in the coolbar, but the labels
in the CustomizePerspectiveDialog are kinda hacked in. Basically, they
currently come from
org.eclipse.ui.internal.WorkbenchWindow.getToolbarLabel(Stri ng). File
and Navigate are hard code :-) and everything else is looked up from the
actionSet registry. sigh, I can't believe this stuff.
So for example, if you create a new toolbar using something like:
<menuContribution locationURI="toolbar:org.eclipse.ui.main.toolbar">
<toolbar id="com.example.myToolbar">
<command commandId="org.eclipse.ui.help.aboutAction"/>
</toolbar>
</menuContribution>
Then com.example.myToolbar will be sent to that method.
But it implies a workaround would be to create an empty actionSet with
an ID matching your toolbar and the appropriate label.
PW
Paul Webster
Re: Commands and Toolbar and Toggle style buttons? [message #336440 is a reply to message #336435] Thu, 11 June 2009 18:12 Go to previous message
> Prakash,
> (with a name).
Were you able to find the toggle update part? There should have been an
example off of the http://wiki.eclipse.org/Menu_Contributions page, it
basically involves using IElementUpdater on the handler.
PW
Paul Webster
Previous Topic:Keyboard Timeout
Next Topic:add filesystem resources to project without copying?
Current Time: Fri Feb 23 18:49:25 GMT 2018
Powered by FUDForum. Page generated in 0.02250 seconds
