Home » Eclipse Projects » Eclipse Platform » Eclipse Jobs and Hibernate
Eclipse Jobs and Hibernate [message #324357] Wed, 23 January 2008 14:39 Go to next message
Piotr Górny is currently offline Piotr GórnyFriend
Member
I've got strange problem with Hibernate used as database persistence system
when invoking a few database queries in separate jobs.
My screnario looks this way:
I have a class called LogonManager (extends Job) which calls about 10
job steps using:
protected IStatus run(final IProgressMonitor monitor)
final IWorkbench workbench = PlatformUI.getWorkbench();
final IWorkbenchWindow window = workbench.getActiveWorkbenchWindow();
final Shell shell = window != null ? window.getShell() : null;
final IRunnableWithProgress runnableWithProgress = new
IRunnableWithProgress()
public void run(final IProgressMonitor monitor) throws
InvocationTargetException, InterruptedException
try
monitor.beginTask("my job", , IProgressMonitor.UNKNOWN);
for (ILogonStep step : steps)
monitor.subTask(step.getLogonStepName());
step.execLogonStep(new SubProgressMonitor(monitor, 1));
finally
monitor.done();
Each step does some database querying by opeing its own transaction,
sending query,
getting results and doing something with them.
Unfortunately lately my application hungs up at random steps, and I have
discovered
that it stop when calling:
session.createQuery(...)
Does anyone have any idea what problem can be here?
Is it connected to Eclipse's jobs?
I'll ask the same question on hibernate forum, but I wander if this
isn't connected
with jobs architecture of Eclipse - that's why I've asked here too.
Piotr
Re: Eclipse Jobs and Hibernate [message #324397 is a reply to message #324357] Wed, 23 January 2008 21:39 Go to previous messageGo to next message
Snjezana Peco is currently offline Snjezana PecoFriend
This problem isn't related to Eclipse's jobs.
Do you commit/rollback the transactions that you open in your steps?
Snjeza
Piotr Górny wrote:
> job steps using:
> try
> finally
> monitor.done();
> sending query,
> discovered
> isn't connected
> Piotr
Re: Eclipse Jobs and Hibernate [message #324408 is a reply to message #324397] Thu, 24 January 2008 06:04 Go to previous messageGo to next message
Member
Snjezana Peco pisze:
> Snjeza
[cut]
Yes, I do... Each step has opens its own transaction and commits or
rollback it.
Piotr
Re: Eclipse Jobs and Hibernate [message #324468 is a reply to message #324408] Thu, 24 January 2008 19:42 Go to previous messageGo to next message
Is your step.execLogonStep method executed in a separate job or thread?
Snjeza
>> Snjeza
> [cut]
> rollback it.
> Piotr
Re: Eclipse Jobs and Hibernate [message #324495 is a reply to message #324468] Fri, 25 January 2008 07:36 Go to previous messageGo to next message
Member
> Snjeza
>>> Snjeza
>> [cut]
>> rollback it.
>> Piotr
It is a substep of the main job. One tick of the main job is the whole
time of this step.
It's like you call: new SubProgressMonitor(monitor, 1) on the main job.
Inside the step:
try
monitor.beginTask(STEP_NAME, IProgressMonitor.UNKNOWN);
finally
monitor.done();
Piotr
Re: Eclipse Jobs and Hibernate [message #324607 is a reply to message #324495] Tue, 29 January 2008 00:37 Go to previous message
You probably have a deadlock in some of your steps. Try to execute the
steps sequentially (without Eclipse job)
Snjeza
>> Snjeza
>>>> Snjeza
>>> [cut]
>>> rollback it.
>>> Piotr
> time of this step.
> Inside the step:
> try
> finally
> monitor.done();
> Piotr
Previous Topic:Extending Project Explorer tree and controlling behavior of added items
Next Topic:[Databinding] TableViewer Editing
Current Time: Sat Apr 21 07:54:11 GMT 2018
Powered by FUDForum. Page generated in 0.02157 seconds
