Home » Eclipse Projects » Eclipse Platform » PDE .product file only handles features **OR** plugins??
PDE .product file only handles features **OR** plugins?? [message #321718] Thu, 25 October 2007 01:01 Go to next message
Originally posted by: none.ibm.com
The PDE product editor seems to suggest that a .product file can declare
*either* plugins *or* features. Is there any reason you can't declare both?
Also, if you choose plug-ins, the editor leaves declared features in the
file, and vice-versa. Shouldn't it remove them if they have no effect?
Re: PDE .product file only handles features **OR** plugins?? [message #321723 is a reply to message #321718] Thu, 25 October 2007 03:52 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
It's handles features OR plug-ins due to simplicity. If you want to
support both at the same time, feel free to file an enhancement request
and we'll review it. Note, that after 3.4, features will most likely
disappear which PDE will have to adapt too.
For leaving features in when you switch between plug-ins / features, you
should file a bug against PDE UI.
~ Chris
Re: PDE .product file only handles features **OR** plugins?? [message #321748 is a reply to message #321723] Thu, 25 October 2007 16:04 Go to previous messageGo to next message
This also affects building your product. If you don't have features
containing *every* plug-in needed in your packaged product, then you are
going to have a hard time using the productBuild scripts in PDE. What to
people normally do if they want the RCP platform with a handful of its
optional plug-ins, and then their own features on top of that?
"Chris Aniszczyk" <zx@us.ibm.com> wrote in message
news:ffp3ul$4bj$1@build.eclipse.org...
> Cheers,
> ~ Chris
Re: PDE .product file only handles features **OR** plugins?? [message #321831 is a reply to message #321748] Mon, 29 October 2007 14:29 Go to previous message
Andrew Niefer is currently offline Andrew NieferFriend
Behind the scenes, pde.build is building from features. When you use a .product
file, the build is just generating a feature for you.
I expect people generally provide their own feature that contains their plug-ins
and includes the org.eclipse.rcp feature to get the base platform. Providing
your own feature gives you more control over what is happening in the headless
build.
-Andrew
>> Cheers,
>> ~ Chris
Previous Topic:LinkageError
Next Topic:help with simple canvas in view
Current Time: Fri Feb 23 03:15:45 GMT 2018
Powered by FUDForum. Page generated in 0.03339 seconds
