Home » Eclipse Projects » Eclipse Platform » Eclipse causes Swing to hang
Eclipse causes Swing to hang [message #319681] Wed, 29 August 2007 21:34 Go to next message
Steve Ray is currently offline Steve RayFriend
Member
I have a simple program. It has two threads, one that reads from
System.in via a BufferedReader and another that displays a JFrame. When I
run this inside of Eclipse, the application hangs in the BufferedReader
and never lets the JFrame display. Is it allright to post the code in
this forum? The program runs fine outside Eclipse.
Re: Eclipse causes Swing to hang [message #319684 is a reply to message #319681] Wed, 29 August 2007 22:31 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
What platform? There may be Mac-specific issues if you use that platform. You are also allocating a console to read input from? For what it's worth, Eclipse doesn't send the characters byte-by-byte to the input reader; rather, it waits for return and then sends it a line at a time.
Alex.
Re: Eclipse causes Swing to hang [message #319726 is a reply to message #319684] Thu, 30 August 2007 14:16 Go to previous messageGo to next message
Member
I'm running on Windows with Europa and Java 1.6. The application runs
fine standalone, but inside Eclipse I get hangs. Happy to send the code
although you can see it at the Swing forum. At first I thought it was a
java problem, but it runs fine standalone and in that other IDE
netWhatever.
http://forum.java.sun.com/thread.jspa?messageID=9850370
Re: Eclipse causes Swing to hang [message #319902 is a reply to message #319681] Wed, 05 September 2007 15:34 Go to previous message
Darin Wright is currently offline Darin WrightFriend
See Eclipse bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=40066.
Darin
"Steve Ray" <stephen.l.ray@boeing.com> wrote in message
news:7fa806114eecd2a38378c8f59378460b$1@www.eclipse.org...
>I have a simple program. It has two threads, one that reads from System.in
>via a BufferedReader and another that displays a JFrame. When I run this
>inside of Eclipse, the application hangs in the BufferedReader and never
>lets the JFrame display. Is it allright to post the code in this forum?
Previous Topic:Red box w/white X decorator in Synchronize view?
Next Topic:X error in Ubuntu
Current Time: Tue May 22 09:42:22 GMT 2018
Powered by FUDForum. Page generated in 0.02098 seconds
