Home » Eclipse Projects » Eclipse Platform » Copy files out of Plugins programmatically
Copy files out of Plugins programmatically [message #319540] Fri, 24 August 2007 09:26 Go to next message
Originally posted by: stefan.bley.dd.gmx.de
Hello.
I try to copy files out of plugin bundles, but I don't come to a solution.
I get the Bundle:
Bundle b = Platform.getBundle(...);
Then I tried:
URL url = b.getResource("lib/aFile.jar"); // where lib/aFile.jar is the
file I want to copy
But what can I do with this URL? I cannot instantiate a java.io.File with
it. Is there any convenience class I did not see yet? How can I copy the
file?
Thanks in advance,
Stefan
Re: Copy files out of Plugins programmatically [message #319541 is a reply to message #319540] Fri, 24 August 2007 09:45 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Look at FileLocator class.
Derek
Stefan Bley wrote:
> Hello.
> I get the Bundle:
> Then I tried:
> file I want to copy
> with it. Is there any convenience class I did not see yet? How can I
> copy the file?
> Thanks in advance,
> Stefan
Re: Copy files out of Plugins programmatically [message #319544 is a reply to message #319541] Fri, 24 August 2007 10:05 Go to previous messageGo to next message
Derek,
Yes, one could use toFileURI. That creates a copy in the file system,
so is not really the most efficient way. I'm not sure why Stefan
doesn't just use openStream on the URL to read directly from the jar and
then write those bytes to the target...
Re: Copy files out of Plugins programmatically [message #319545 is a reply to message #319540] Fri, 24 August 2007 10:13 Go to previous message
Originally posted by: automatic.javalobby.org
Get the contents as a stream, create a new file output stream, write contents of input stream to output stream. Java 101.
If you've not done stuff with IO before, check out the Java tutorial on same:
http://java.sun.com/docs/books/tutorial/essential/io/buffers .html
Basically, use that example except instead of creating a FileInputStream, you use b.getResource().openStream() instead.
Alex.
Previous Topic:Meaning of //$NON-NLS-1$
Next Topic:Accessing views of other plug-ins
Current Time: Wed Jun 20 12:04:38 GMT 2018
Powered by FUDForum. Page generated in 0.05318 seconds
