Home » Eclipse Projects » Remote Application Platform (RAP) » Again Table Refresh Error
Again Table Refresh Error [message #32248] Tue, 12 June 2007 05:39 Go to next message
Thomas Kühne is currently offline Thomas Kühne
Member
I have again a Problem with the table Refresh.
I have a view part which shows a search result in a TableViewer.
The search string is provided via a Text criteria and a modify
listener is bound to it. The modify Listener updates the table with
tableViewer.setInput( criteria.getText() );
That works fine when the number of search results are growing. When
a search result get less results then the one before I get the following
Error . The error just occures when
a table item is selected which wil not be in the search result after update
I tried a delelectAll() on the table before refresh but it does not work
out.
I am working with cvs.
The Exception :
java.lang.IllegalArgumentException: Index out of bounds
at org.eclipse.swt.SWT.error(SWT.java:629)
at org.eclipse.swt.SWT.error(SWT.java:588)
at org.eclipse.swt.SWT.error(SWT.java:584)
at org.eclipse.swt.internal.widgets.ItemHolder.getItem(ItemHold er.java:102)
at org.eclipse.swt.widgets.Table.getItem(Table.java:387)
org.eclipse.swt.internal.widgets.tableitemkit.TableItemLCA.i sFocused(TableItemLCA.java:224)
org.eclipse.swt.internal.widgets.tableitemkit.TableItemLCA.w riteFocused(TableItemLCA.java:171)
org.eclipse.swt.internal.widgets.tableitemkit.TableItemLCA.r enderChanges(TableItemLCA.java:89)
org.eclipse.swt.lifecycle.AbstractWidgetLCA.render(AbstractW idgetLCA.java:55)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$Rende rVisitor.render(DisplayLCA.java:63)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA$Rende rVisitor.doVisit(DisplayLCA.java:47)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidget TreeVisitor.visit(WidgetTreeVisitor.java:25)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:56)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.handleIte ms(WidgetTreeVisitor.java:88)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:45)
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:48)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.rende r(DisplayLCA.java:133)
at org.eclipse.swt.internal.lifecycle.Render.execute(Render.jav a:28)
org.eclipse.swt.internal.lifecycle.RWTLifeCycle.execute(RWTL ifeCycle.java:81)
Any ideas ?
Thomas
Re: Again Table Refresh Error [message #32284 is a reply to message #32248] Tue, 12 June 2007 06:02 Go to previous messageGo to next message
Eclipse User
Originally posted by: rherrmann.innoopract.com
I am not able to reproduce the exception. Could you open a bug and
attach a small snippet?
Rüdiger
Thomas Kühne wrote:
> out.
> The Exception :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas ?
> Thomas
Re: Again Table Refresh Error [message #32735 is a reply to message #32284] Tue, 12 June 2007 11:17 Go to previous message
Member
Hi R
Previous Topic:JavaScript Error using todays cvs update
Next Topic:Canvas Support in Rap
Current Time: Sun May 19 08:16:51 EDT 2013
Powered by FUDForum. Page generated in 0.01947 seconds
