Home » Eclipse Projects » Eclipse Platform » Custom Eclipse Launcher
Custom Eclipse Launcher [message #316678] Thu, 14 June 2007 17:17 Go to next message
Originally posted by: pecze.nospam.us.ibm.com
I'm attempting to create an executable to launch my eclipse based
application.
All the exe does is use java to launch eclipse. I have it mostly
working, however, I can't get my splash screen to display.
I'm running the following command:
java -Xms40m -Xmx256m -jar "C:\MyDirectory\startup.jar" -os win32 -ws
win32 -arch x86 -launcher "C:\MyDirectory\mylauncher.exe" -configuration
"C:\MyDirectory\configuration" -showsplash 600 -vm
"C:\MyDirectory\_jvm\jre\bin\javaw" -vmargs -Xms40m -Xmx256m -jar
config.ini sets eclipse.product and osgi.splashPath
My product branding gets displayed properly, but not the splash screen.
When I run via eclipse.exe, the splash screen gets displayed. I'm not
sure what I'm doing wrong.
Shawn
Re: Custom Eclipse Launcher [message #316703 is a reply to message #316678] Fri, 15 June 2007 13:33 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
Shawn,
Which version of eclipse are you using, because the launcher was rewritten in
3.3 and launching has changed a lot.
Since you have a startup.jar, does that mean your are using 3.2?
Note that it is the launcher itself that displays the splash screen. In 3.2
Main will exec your launcher again with a command line something like
mylauncher.exe -showsplash 600 <path/to/splash.bmp>
You launcher is expected to show the splash screen (its a new process). The
eclipse.exe also listens on stdin for commands to show a progress bar and
display text.
3.2 source for the launcher is in cvs under platform-launcher/library
-Andrew
> application.
> Shawn
Re: Custom Eclipse Launcher [message #316829 is a reply to message #316703] Tue, 19 June 2007 19:18 Go to previous message
I'm using Eclipse 3.2.1
Andrew Niefer wrote:
> Shawn,
> rewritten in 3.3 and launching has changed a lot.
> 3.2 Main will exec your launcher again with a command line something like
> The eclipse.exe also listens on stdin for commands to show a progress
> bar and display text.
> -Andrew
>> application.
>> -configuration "C:\MyDirectory\configuration" -showsplash 600 -vm
>> Thanks,
>> Shawn
Previous Topic:Using the internal Tomcat to launch Web Applications
Next Topic:objectContribution for files in project with custom nature
Current Time: Fri May 25 18:26:12 GMT 2018
Powered by FUDForum. Page generated in 0.02571 seconds
