Home » Language IDEs » AJDT » Where/how can I get source code?
Where/how can I get source code? [message #31899] Tue, 16 March 2004 11:32 Go to next message
Originally posted by: niksa_os.n.n
I'm new to AOP and I don't understand all for now.
From my experience with Java I understand better if I can see source code.
Where/how can I see source code generated with AspectJ?
With some Java decompiler?
Re: Where/how can I get source code? [message #32005 is a reply to message #31899] Thu, 18 March 2004 23:08 Go to previous message
Martin Kersten is currently offline Martin KerstenFriend
Well do you mean byte code (you mentioned decompilers)
or java source code?
A couple of snippets can be seen by this pdf file:
http://dolphin.c.u-tokyo.ac.jp/~kazu0/aspectj/doc/tutorial/a spectj-tutorial.pdf
It demonstrates the basic features provided by AspectJ and shows some
limitations. But getting byte code of weaven applications, can be done
by every decompiler. The aspectJ compiler produces the Java compliant
byte code. So nearly every VM and every decompiler should be able
to handle that byte code.
Martin (Kersten)
Re: Where/how can I get source code? [message #576362 is a reply to message #31899] Thu, 18 March 2004 23:08 Go to previous message
Martin (Kersten)
Previous Topic:Where/how can I get source code?
Next Topic:AOP based refactoring
Current Time: Sat Apr 21 16:05:12 GMT 2018
Powered by FUDForum. Page generated in 0.01418 seconds
