Can command line update manager resolve dependencies? [message #314393] |
Wed, 11 April 2007 09:26 |
Marcin Okraszewski Messages: 32 Registered: July 2009 |
Member |
I tried to use command line update manager to install EMF SDO. The EMF
SDO depends on EMF feature. The command failed with message not so easy
to understand what should I install.
In GUI there is a "select required" button. I couldn't find any
information about this feature for command line in help. Is there any
way to do the same with command line?
The command I used for installation was:
java -cp plugins/org.eclipse.equinox.launcher_1.0.0.v20070319.jar
org.eclipse.equinox.launcher.Main -consolelog -application
org.eclipse.update.core.standaloneUpdate -from
http://download.eclipse.org/releases/europa/staging -command install
-featureId org.eclipse.emf.ecore.sdo -version 2.3.0.v200703291501
Marcin Okraszewski
FUDForum. Page generated in 0.02840 seconds
