Home » Eclipse Projects » Eclipse Platform » build problem - BasicNewResourceWizard
build problem - BasicNewResourceWizard [message #311694] Fri, 19 January 2007 14:21 Go to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I am just setting up a new development machine to continue developing a set of
plugins. I have checked out the plugins from CVS and made sure I have the same
versions of Eclipse, CDT and Java on both machines.
On the original machine, the plugins build OK. However, on the new machine, I
get the following error:
The project was not built since its build path is incomplete. Cannot find the
class file for org.eclipse.ui.wizards.newresource.BasicNewResourceWizard. Fix
the build path then try building this project
I can't work out why this is occuring. Can anybody help?
Derek
Re: build problem - BasicNewResourceWizard [message #311697 is a reply to message #311694] Fri, 19 January 2007 14:58 Go to previous message
Solved my own problem:
I had to add org.eclipse.ui.wizards.newresource explicitly to the 'Import
Packages' part of the Dependencies. (Although why this wasn't necessary on my
original machine remains a mystery).
Derek
Derek Morris wrote:
> set of plugins. I have checked out the plugins from CVS and made sure I
> have the same versions of Eclipse, CDT and Java on both machines.
> machine, I get the following error:
> find the class file for
> org.eclipse.ui.wizards.newresource.BasicNewResourceWizard. Fix the build
Previous Topic:how to add "help" button to a "new" wizard?
Next Topic:Two projects with the same name in the workspace - newbie
Current Time: Tue Apr 16 12:15:34 GMT 2024
Powered by FUDForum. Page generated in 1.32525 seconds
