Home » Eclipse Projects » Eclipse Platform » A cycle was detected when generating the classpath
A cycle was detected when generating the classpath [message #311497] Sun, 14 January 2007 18:20 Go to next message
Originally posted by: arno.nymix.gmail.com
Hello
My Plugin runs in the eclipse environment, but when I try to export the
following error occurs:
Problems during export
com.test.myplugin_1.0.0,
org.eclipse.core.runtime_3.2.0v20060603,
org.eclipse.equinox.registry_3.2.0v20060601,
com.ibm.openactivities.client.common.service_3.0.0.20061101- 1847,
What does that mean and how can I avoid this error?
Thx
Arno
Re: A cycle was detected when generating the classpath [message #311530 is a reply to message #311497] Mon, 15 January 2007 14:36 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
It means that somewhere you have a plugin A requiring plugin B and
plugin B requiring plugin A.
Arno Nymix wrote:
> Hello
> Thx
> Arno
Rich Kulp
Re: A cycle was detected when generating the classpath [message #537008 is a reply to message #311530] Mon, 31 May 2010 21:01 Go to previous message
Dennis Meade is currently offline Dennis MeadeFriend
Now that you know what the problem is if you believe things are ok, goto Preferences/Java/Compiler/Building and change the reporting error level from error to warning.
Previous Topic:Attaching source and Javadoc
Next Topic:Adding new services to editor sites or the workbench window so they are found via getService() (serv
Current Time: Sun Feb 25 10:15:02 GMT 2018
Powered by FUDForum. Page generated in 0.01665 seconds
