Home » Language IDEs » PHP Development Tools (PDT) » Zend Debugger setup trouble
Zend Debugger setup trouble [message #99789] Thu, 09 July 2009 22:01
Originally posted by: null.void.net
Hi all,
I have difficulties setting up Zend Debugger on Eclipse 3.5 (Galileo).
Although I'm a newbie, I've followed all the instructions I've read (as
you'll see from the detailed info at the end of this post); I've even
scoured the web and found others with similar issues but none have any
real answer (that works). I tried all of those help and responses people
posts with no success, so I'm here on Eclipse news site hoping one of
the /original/ eclipse developers may be of help.
Thank you all in advance for your help.
`Js.
**************** PROBLEMS DESCRIPTION AND EFFORTS BELOW ****************
Problem:
When debugging a PHP script/page from Eclipse IDE (i.e. I have not been
able to use the debugger), I received the following error message in a
dialog box:
- Error launching 'one'
- The debug session could not be started.
- Please make sure that the debugger is properly configured as a php.ini
directive.
Efforts:
- I have set PHP successfully with IIS 7 on Vista x64 using FastCGI.
- Calls to phpinfo(); returns proper messages indicating my php
installation is proper (attached below).
- It can read php.ini in the specified location as you can see from the
phpinfo(); output.
- I've entered the following in php.ini following instructions in ZEND
tar's README:
[Zend]
zend_extension_ts=./ext/ZendDebugger.dll
zend_debugger.allow_hosts=127.0.0.1/32, 192.168.0.0/99
zend_debugger.expose_remotely=always
- I've enabled output_buffering (by default)
- I've set implicit_flush = On
**************** phpinfo() OUTPUT (EDITED) *****************************
PHP Version 5.3.0
System Windows NT TEST 6.0 build 6002 (Windows Vista Ultimate Edition
Service Pack 2) i586
Build Date Jun 29 2009 21:52:31
Compiler MSVC9 (Visual C++ 2008)
Architecture x86
Configure Command cscript /nologo configure.js
"--enable-snapshot-build" "--disable-isapi" "--enable-debug-pack"
"--with-pdo-oci=D:\php-sdk\oracle\instantclient10\sdk,shared "
"--with-oci8=D:\php-sdk\oracle\instantclient10\sdk,shared"
" --with-oci8-11g=D:\php-sdk\oracle\instantclient11\sdk,shared "
"--with-enchant=shared"
Server API CGI/FastCGI
Virtual Directory Support enabled
Configuration File (php.ini) Path C:\Windows
Loaded Configuration File C:\php\php-5.3.0-Win32-VC9-x86\php.ini
Scan this dir for additional .ini files (none)
Additional .ini files parsed (none)
PHP API 20090626
PHP Extension 20090626
Zend Extension 220090626
Zend Extension Build API220090626,TS,VC9
PHP Extension Build API20090626,TS,VC9
Debug Build no
Thread Safety enabled
Zend Memory Manager enabled
Zend Multibyte Support disabled
IPv6 Support enabled
Registered PHP Streams php, file, glob, data, http, ftp, zip,
compress.zlib, phar
Registered Stream Socket Transports tcp, udp
Registered Stream Filters convert.iconv.*, string.rot13,
string.toupper, string.tolower, string.strip_tags, convert.*, consumed,
dechunk, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.3.0, Copyright (c) 1998-2009 Zend Technologies
PHP Credits
Configuration
bcmath
BCMath support enabled
Directive Local Value Master Value
bcmath.scale 0 0
calendar
Calendar support enabled
cgi-fcgi
cgi.discard_path 0 0
cgi.fix_pathinfo 1 1
cgi.force_redirect 1 1
cgi.nph 0 0
cgi.redirect_status_env no value no value
cgi.rfc2616_headers 0 0
fastcgi.impersonate 0 0
fastcgi.logging 1 1
com_dotnet
COM support enabled
DCOM support disabled
..Net support enabled
com.allow_dcom 0 0
com.autoregister_casesensitive 1 1
com.autoregister_typelib 0 0
com.autoregister_verbose 0 0
com.code_page no value no value
com.typelib_file no value no value
Core
PHP Version 5.3.0
allow_call_time_pass_reference Off Off
allow_url_fopen On On
allow_url_include Off Off
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags On On
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors On On
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl Off Off
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 22527 22527
exit_on_timeout Off Off
expose_php On On
extension_dir ./ext ./ext
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors Off Off
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush On On
include_path .;C:\php5\pear .;C:\php5\pear
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 30 30
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 128M 128M
open_basedir no value no value
output_buffering 4096 4096
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
register_globals Off Off
register_long_arrays Off Off
report_memleaks On On
report_zend_debug On On
request_order GP GP
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path no value no value
serialize_precision 100 100
short_open_tag Off Off
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors On On
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order GPCS GPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.enable_gc On On
ctype
ctype functions enabled
date
date/time support enabled
"Olson" Timezone Database Version 2009.10
Timezone Database internal
Default timezone America/Los_Angeles
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone America/Los_Angeles America/Los_Angeles
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.7.3
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
ereg
Regex Library Bundled library enabled
filter
Input Validation and Filtering enabled
Revision $Revision: 1.52.2.39.2.16 $
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128
ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3
tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost adler32 crc32
crc32b salsa10 salsa20 haval128,3 haval160,3 haval192,3 haval224,3
haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4
haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation "libiconv"
iconv library version 1.11
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
json
json support enabled
json version 1.2.1
libxml
libXML support active
libXML Compiled Version 2.7.3
libXML Loaded Version 20703
libXML streams enabled
mcrypt
mcrypt support enabled
Version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish cast-256 loki97
rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent
xtea blowfish enigma rc2 tripledes arcfour
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir no value no value
mcrypt.modes_dir no value no value
mhash
MHASH support Enabled
MHASH API Version Emulated Support
mysqlnd
mysqlnd enabled
Version mysqlnd 5.0.5-dev - 081106 - $Revision: 1.3.2.27 $
Command buffer size 2048
Read buffer size 32768
Collecting statistics Yes
Collecting memory statistics No
Client statistics
bytes_sent 0
bytes_received 0
packets_sent 0
packets_received 0
protocol_overhead_in 0
protocol_overhead_out 0
bytes_received_ok_packet 0
bytes_received_eof_packet 0
bytes_received_rset_header_packet 0
bytes_received_rset_field_meta_packet 0
bytes_received_rset_row_packet 0
bytes_received_prepare_response_packet 0
bytes_received_change_user_packet 0
packets_sent_command 0
packets_received_ok 0
packets_received_eof 0
packets_received_rset_header 0
packets_received_rset_field_meta 0
packets_received_rset_row 0
packets_received_prepare_response 0
packets_received_change_user 0
result_set_queries 0
non_result_set_queries 0
no_index_used 0
bad_index_used 0
slow_queries 0
buffered_sets 0
unbuffered_sets 0
ps_buffered_sets 0
ps_unbuffered_sets 0
flushed_normal_sets 0
flushed_ps_sets 0
ps_prepared_never_executed 0
ps_prepared_once_executed 0
rows_fetched_from_server_normal 0
rows_fetched_from_server_ps 0
rows_buffered_from_client_normal 0
rows_buffered_from_client_ps 0
rows_fetched_from_client_normal_buffered 0
rows_fetched_from_client_normal_unbuffered 0
rows_fetched_from_client_ps_buffered 0
rows_fetched_from_client_ps_unbuffered 0
rows_fetched_from_client_ps_cursor 0
rows_skipped_normal 0
rows_skipped_ps 0
copy_on_write_saved 0
copy_on_write_performed 0
command_buffer_too_small 0
connect_success 0
connect_failure 0
connection_reused 0
reconnect 0
pconnect_success 0
active_connections 0
active_persistent_connections 0
explicit_close 0
implicit_close 0
disconnect_close 0
in_middle_of_command_close 0
explicit_free_result 0
implicit_free_result 0
explicit_stmt_close 0
implicit_stmt_close 0
mem_emalloc_count 0
mem_emalloc_ammount 0
mem_ecalloc_count 0
mem_ecalloc_ammount 0
mem_erealloc_count 0
mem_erealloc_ammount 0
mem_efree_count 0
mem_malloc_count 0
mem_malloc_ammount 0
mem_calloc_count 0
mem_calloc_ammount 0
mem_realloc_count 0
mem_realloc_ammount 0
mem_free_count 0
proto_text_fetched_null 0
proto_text_fetched_bit 0
proto_text_fetched_tinyint 0
proto_text_fetched_short 0
proto_text_fetched_int24 0
proto_text_fetched_int 0
proto_text_fetched_bigint 0
proto_text_fetched_decimal 0
proto_text_fetched_float 0
proto_text_fetched_double 0
proto_text_fetched_date 0
proto_text_fetched_year 0
proto_text_fetched_time 0
proto_text_fetched_datetime 0
proto_text_fetched_timestamp 0
proto_text_fetched_string 0
proto_text_fetched_blob 0
proto_text_fetched_enum 0
proto_text_fetched_set 0
proto_text_fetched_geometry 0
proto_text_fetched_other 0
proto_binary_fetched_null 0
proto_binary_fetched_bit 0
proto_binary_fetched_tinyint 0
proto_binary_fetched_short 0
proto_binary_fetched_int24 0
proto_binary_fetched_int 0
proto_binary_fetched_bigint 0
proto_binary_fetched_decimal 0
proto_binary_fetched_float 0
proto_binary_fetched_double 0
proto_binary_fetched_date 0
proto_binary_fetched_year 0
proto_binary_fetched_time 0
proto_binary_fetched_datetime 0
proto_binary_fetched_timestamp 0
proto_binary_fetched_string 0
proto_binary_fetched_blob 0
proto_binary_fetched_enum 0
proto_binary_fetched_set 0
proto_binary_fetched_geometry 0
proto_binary_fetched_other 0
odbc
ODBC Support enabled
Active Persistent Links 0
Active Links 0
ODBC library Win32
odbc.allow_persistent On On
odbc.check_persistent On On
odbc.default_cursortype Static cursor Static cursor
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 7.9 2009-04-11
pcre.backtrack_limit 100000 100000
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers no value
Phar
Phar: PHP Archive support enabled
Phar EXT version 2.0.0-dev
Phar API version 1.1.1
CVS revision $Revision: 1.370.2.62 $
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression disabled (install pecl/bz2)
OpenSSL support disabled (install ext/openssl)
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
Reflection
Reflection enabled
Version $Revision: 1.164.2.33.2.45.2.58 $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 Off Off
session.bug_compat_warn Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly Off Off
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 5 5
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path no value no value
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies On On
session.use_trans_sid 0 0
SimpleXML
Simplexml support enabled
Revision $Revision: 1.151.2.22.2.35.2.32 $
Schema support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator,
SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject,
BadFunctionCallException, BadMethodCallException, CachingIterator,
DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator,
FilterIterator, GlobIterator, InfiniteIterator,
InvalidArgumentException, IteratorIterator, LengthException,
LimitIterator, LogicException, MultipleIterator, NoRewindIterator,
OutOfBoundsException, OutOfRangeException, OverflowException,
ParentIterator, RangeException, RecursiveArrayIterator,
RecursiveCachingIterator, RecursiveDirectoryIterator,
RecursiveFilterIterator, RecursiveIteratorIterator,
RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator,
RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject,
SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage,
SplPriorityQueue, SplQueue, SplStack, SplTempFileObject,
UnderflowException, UnexpectedValueException
standard
Dynamic Library Support enabled
Internal Sendmail Support for Windows enabled
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.7.3
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
zip
Zip enabled
Extension Version $Id: php_zip.c,v 1.1.2.38.2.29 2009/02/24 23:55:14
iliaa Exp $
Zip version 1.9.1
Libzip version 0.9.0
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
Environment
Variable Value
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Windows\system32\config\systemprofile\AppData\Roaming
APP_POOL_ID DefaultAppPool
CLASSPATH .;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
CommonProgramFiles C:\Program Files (x86)\Common Files
CommonProgramFiles(x86) C:\Program Files (x86)\Common Files
CommonProgramW6432 C:\Program Files\Common Files
COMPUTERNAME MOZI
ComSpec C:\Windows\system32\cmd.exe
DFSTRACINGON FALSE
FP_NO_HOST_CHECK NO
LOCALAPPDATA C:\Windows\system32\config\systemprofile\AppData\Local
mysql5133 C:\mysql-5.1.33-win32\bin\
NUMBER_OF_PROCESSORS 2
OS Windows_NT
Path C:\php\php-5.3.0-Win32-VC9-x86\;
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PHPRC C:\php\php-5.3.0-Win32-VC9-x86\
PROCESSOR_ARCHITECTURE x86
PROCESSOR_ARCHITEW6432 AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 23 Stepping 6, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 1706
ProgramData C:\ProgramData
PUBLIC C:\Users\Public
QTJAVA C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
SqlSamplesDatabasePath C:\Program Files\Microsoft SQL
Server\MSSQL10.DEVSQL2008_01\MSSQL\DATA\
SqlSamplesSourceDataPath C:\Program Files\Microsoft SQL
Server\100\Tools\Samples\
SystemDrive C:
SystemRoot C:\Windows
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
TRACE_FORMAT_SEARCH_PATH
\\NTREL202.ntdev.corp.microsoft.com\34FB5F65-FFEB-4B61-BF0E- A6A76C450FAA\TraceFormat
USERDOMAIN WORKGROUP
USERNAME TEST$
USERPROFILE C:\Windows\system32\config\systemprofile
VS80COMNTOOLS C:\Program Files (x86)\Microsoft Visual Studio
8\Common7\Tools\
VS90COMNTOOLS c:\Program Files (x86)\Microsoft Visual Studio
9.0\Common7\Tools\
windir C:\Windows
PHP Variables
Variable Value
_SERVER["ALLUSERSPROFILE"] C:\ProgramData
_SERVER["APPDATA"] C:\Windows\system32\config\systemprofile\AppData\Roaming
_SERVER["APP_POOL_ID"] DefaultAppPool
_SERVER["CLASSPATH"] .;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
_SERVER["CommonProgramFiles"] C:\Program Files (x86)\Common Files
_SERVER["CommonProgramFiles(x86)"] C:\Program Files (x86)\Common Files
_SERVER["CommonProgramW6432"] C:\Program Files\Common Files
_SERVER["COMPUTERNAME"] TEST
_SERVER["ComSpec"] C:\Windows\system32\cmd.exe
_SERVER["DFSTRACINGON"] FALSE
_SERVER["FP_NO_HOST_CHECK"] NO
_SERVER["LOCALAPPDATA"]
_SERVER["mysql5133"] C:\mysql-5.1.33-win32\bin\
_SERVER["NUMBER_OF_PROCESSORS"] 2
_SERVER["OS"] Windows_NT
_SERVER["Path"] C:\php\php-5.3.0-Win32-VC9-x86\;
_SERVER["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
_SERVER["PHPRC"] C:\php\php-5.3.0-Win32-VC9-x86\
_SERVER["PROCESSOR_ARCHITECTURE"] x86
_SERVER["PROCESSOR_ARCHITEW6432"] AMD64
_SERVER["PROCESSOR_IDENTIFIER"] Intel64 Family 6 Model 23 Stepping 6,
GenuineIntel
_SERVER["PROCESSOR_LEVEL"] 6
_SERVER["PROCESSOR_REVISION"] 1706
_SERVER["ProgramData"] C:\ProgramData
_SERVER["ProgramFiles"] C:\Program Files (x86)
_SERVER["ProgramFiles(x86)"] C:\Program Files (x86)
_SERVER["ProgramW6432"] C:\Program Files
_SERVER["PUBLIC"] C:\Users\Public
_SERVER["QTJAVA"] C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
_SERVER["SqlSamplesDatabasePath"] C:\Program Files\Microsoft SQL
_SERVER["SqlSamplesSourceDataPath"] C:\Program Files\Microsoft SQL
_SERVER["SystemDrive"] C:
_SERVER["SystemRoot"] C:\Windows
_SERVER["TEMP"] C:\Windows\TEMP
_SERVER["TMP"] C:\Windows\TEMP
_SERVER["TRACE_FORMAT_SEARCH_PATH"]
_SERVER["USERDOMAIN"] WORKGROUP
_SERVER["USERNAME"] TEST$
_SERVER["USERPROFILE"] C:\Windows\system32\config\systemprofile
_SERVER["VS80COMNTOOLS"] C:\Program Files (x86)\Microsoft Visual Studio
8\Common7\Tools\
_SERVER["VS90COMNTOOLS"] c:\Program Files (x86)\Microsoft Visual Studio
9.0\Common7\Tools\
_SERVER["windir"] C:\Windows
_SERVER["FCGI_ROLE"] RESPONDER
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_ACCEPT"]
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q= 0.8
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_HOST"] localhost
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 6.0;
en-US; rv:1.9.1) Gecko/20090624 Firefox/3.5 (.NET CLR 3.5.30729)
_SERVER["DOCUMENT_ROOT"] C:\inetpub\wwwroot
_SERVER["REQUEST_URI"] /exploration/one.php
_SERVER["SCRIPT_FILENAME"]
C:\Users\john.smith\workspace-php\Exploration\one.php
_SERVER["APPL_MD_PATH"] /LM/W3SVC/1/ROOT
_SERVER["APPL_PHYSICAL_PATH"] C:\inetpub\wwwroot\
_SERVER["AUTH_TYPE"] no value
_SERVER["AUTH_PASSWORD"] no value
_SERVER["AUTH_USER"] no value
_SERVER["CERT_COOKIE"] no value
_SERVER["CERT_FLAGS"] no value
_SERVER["CERT_ISSUER"] no value
_SERVER["CERT_SERIALNUMBER"] no value
_SERVER["CERT_SUBJECT"] no value
_SERVER["CONTENT_LENGTH"] 0
_SERVER["CONTENT_TYPE"] no value
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["HTTPS"] off
_SERVER["HTTPS_KEYSIZE"] no value
_SERVER["HTTPS_SECRETKEYSIZE"] no value
_SERVER["HTTPS_SERVER_ISSUER"] no value
_SERVER["HTTPS_SERVER_SUBJECT"] no value
_SERVER["INSTANCE_ID"] 1
_SERVER["INSTANCE_META_PATH"] /LM/W3SVC/1
_SERVER["LOCAL_ADDR"] 127.0.0.1
_SERVER["LOGON_USER"] no value
_SERVER["PATH_TRANSLATED"]
_SERVER["QUERY_STRING"] no value
_SERVER["REMOTE_ADDR"] 127.0.0.1
_SERVER["REMOTE_HOST"] 127.0.0.1
_SERVER["REMOTE_PORT"] 52721
_SERVER["REMOTE_USER"] no value
_SERVER["REQUEST_METHOD"] GET
_SERVER["SCRIPT_NAME"] /exploration/one.php
_SERVER["SERVER_NAME"] localhost
_SERVER["SERVER_PORT"] 80
_SERVER["SERVER_PORT_SECURE"] 0
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["SERVER_SOFTWARE"] Microsoft-IIS/7.0
_SERVER["URL"] /exploration/one.php
_SERVER["ORIG_PATH_INFO"] /exploration/one.php
_SERVER["PHP_SELF"] /exploration/one.php
_SERVER["REQUEST_TIME"] 1247176015
PHP License
This program is free software; you can redistribute it and/or modify it
under the terms of the PHP License as published by the PHP Group and
included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions
about PHP licensing, please contact license@php.net.
**************** phpinfo() OUTPUT END **********************************
Previous Topic:Code Assist for global variables
Next Topic:PDT code assist garbled
Current Time: Sun May 20 12:13:05 GMT 2018
Powered by FUDForum. Page generated in 0.02084 seconds
