Home » Modeling » EMF » [CDO] xbcmodel(troubles with the xbcmodel's metamodel and CDO)
[CDO] xbcmodel [message #542569] Fri, 25 June 2010 11:04 Go to next message
cippalippa  is currently offline cippalippa Friend
Hi, I have the following problem.
I must use the metamodel XBCModel (in CDO2) that you can find in the link that follows;
as you can see in this metamodel there isn't any reference to EFeatureMap which is not supported in CDO2.
Anyway if you try to use this metamodel you will still get an exception which claim DBStore unsupport
EFeatureMap; is there any dependency in this metamodel to EFeatureMap?
http://pastebin.com/Fc86yses
Re: [CDO] xbcmodel [message #542575 is a reply to message #542569] Fri, 25 June 2010 11:12 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 25.06.2010 13:04, schrieb cippalippa:
> Hi, I have the following problem. I must use the metamodel XBCModel
> (in CDO2) that you can find in the link that follows; as you can see
> exception which claim DBStore unsupport EFeatureMap;
Please post the stack trace of that exception.
Unfortunately I'm not a feature map expert and I don.t know what to look
for. Maybe others can jump in?
Cheers
/Eike
Re: [CDO] xbcmodel [message #542617 is a reply to message #542575] Fri, 25 June 2010 12:55 Go to previous messageGo to next message
first of all, I would give thanks for your quickly reply, this is the log produced by Eclipse.
org.eclipse.net4j.util.transaction.TransactionException: Rollback in DBStore: org.eclipse.net4j.util.ImplementationError: Unrecognized CDOType: FEATURE_MAP_ENTRY
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createValueMapping(AbstractMappingStrategy.java:4 51)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractListTableMapping.initTable(AbstractListTableMapping.ja va:117)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractListTableMapping. <init>(AbstractListTableMapping.java:95)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Au ditListTableMapping. <init>(AuditListTableMapping.java:42)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalAuditMappingStrategy.doCreateListMapping(HorizontalA uditMappingStrategy.java:35)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createListMapping(AbstractMappingStrategy.java:45 7)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.createListMappings(AbstractHori zontalClassMapping.java:133)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping.initFeatures(AbstractHorizontal ClassMapping.java:106)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalClassMapping. <init>(AbstractHorizontalClassMapping.java:74)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalAuditClassMapping. <init>(HorizontalAuditClassMapping.java:63)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ho rizontalAuditMappingStrategy.doCreateClassMapping(Horizontal AuditMappingStrategy.java:29)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createClassMapping(AbstractMappingStrategy.java:3 55)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapClasses(AbstractMappingStrategy.java:325)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapPackageInfos(AbstractMappingStrategy.java:314)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.mapPackageUnits(AbstractMappingStrategy.java:336)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappi ngStrategy.createMapping(AbstractMappingStrategy.java:297)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write PackageUnits(DBStoreAccessor.java:496)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:129)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.acces s$4(DBStoreAccessor.java:1)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:80)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$1.run Loop(DBStoreAccessor.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.write (DBStoreAccessor.java:294)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl.write(TransactionCommitContextImpl.java:269)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:73)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication$1.runLoop(CommitTransactionIndication.java:1)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:325)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:198 )
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:140 )
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactio nStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:6 3)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:598)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:612)
at org.eclipse.emf.cdo.internal.ui.actions.CommitTransactionAct ion.doRun(CommitTransactionAction.java:38)
at org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:185)
Re: [CDO] xbcmodel [message #542690 is a reply to message #542617] Fri, 25 June 2010 15:52 Go to previous message
Thanks for the infos. According to Ed you don't seem to be using feature
maps. But this makes me suspicious (last line):
<eStructuralFeatures xsi:type="ecore:EAttribute" name="timestamp"
lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime"/>
Before we continue to discuss the problem I would like you to retest it
with CDO 3.0 as published with Helios or from CVS HEAD because CDO 2.0
is out of maintenance starting today.
Cheers
/Eike
Am 25.06.2010 14:55, schrieb cippalippa:
> ssor.java:129)
> wn Source)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Previous Topic:Helios RCP+RAP doesn't have EMF Databinding
Next Topic:Traverse an EMF tree
Current Time: Tue May 22 23:47:50 GMT 2018
Powered by FUDForum. Page generated in 0.01926 seconds
