Home » Eclipse Projects » Rich Client Platform (RCP) » IViewSite (ico multi-instance view): no means to update secondaryId
IViewSite (ico multi-instance view): no means to update secondaryId [message #533886] Mon, 17 May 2010 11:44 Go to next message
Guy Rooms is currently offline Guy RoomsFriend
I have a situation/question concerning multi-instance views:
Situation:
- (single) view_A: showing list of available devices
- (multiple) view_B: displaying details for a single device
Requested Scenarios:
- Scenario A:
"Via context menu on View_A, provide means to Create (and jump to) new
instance of view_B."
This works fine using the secondaryId, e.g.:
"activePage.showView(<view_B_Id>, <secondaryId>, IWorkbenchPage.VIEW_CREATE);"
Here, the <secondaryId> corresponds to a device, and is used during
view_Bs creation (using "IViewSite.getSecondaryID()")
- Scenario B:
"Additionaly have a dropdown list in View_Bs toolbar to be able to
switch to another device."
Also this works fine: I can add a dropdown list, I can update view_B
its contents according to the newly selected device.
however the (internal) secondaryId (corresponding to the originally
selected device) remains the same.
As a result, a discrepancy is created between view_Bs content (details
on newly selected device) and its internal secondaryId (originally
selected device).
As a result, this breaks the expected behavior of Scenario A.
A solution to this problem could be to provide a means to extend the
IViewSite interface with a method to update the secondaryID.
Questions:
- Is it an option to have IViewSite extended with:
".setSecondaryId(String secId))",
- Is there another, existing solution I don't know about, fulfilling
both requested scenario's
- Any other, better solution ?
Thank you for your replies.
Re: IViewSite (ico multi-instance view): no means to update secondaryId [message #533888 is a reply to message #533886] Mon, 17 May 2010 11:59 Go to previous messageGo to next message
It Seems I have posted this to the wrong forum, should have been the "eclipse platform" iso RCP.
Can I (..) move this to the correct forum ? Sorry for the trouble.
Guy (first time poster)
Re: IViewSite (ico multi-instance view): no means to update secondaryId [message #533910 is a reply to message #533886] Mon, 17 May 2010 13:04 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
This post is probably OK here as well. I'll just append my answer:
But I'll mention, we cannot add that enhancements (definitely not in
3.x, possibly not in 4.0 either). The primaryID+secondaryID are
immutable and point to an instance of the view in the framework
(scoped to a window, I believe).
Your best bet is to have your primaryID+secondaryID be a key into a
map of devices ... then you can swap out your model object and have
that view "key" point to the new device.
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: IViewSite (ico multi-instance view): no means to update secondaryId [message #533964 is a reply to message #533910] Mon, 17 May 2010 15:06 Go to previous messageGo to next message
Thx for your reply.
If I understand well, this implies:
- not to use the "normal" mechanism for navigating from view_A to view_B:
activePage.showView(<view_B>, <secId>, IWorkbenchPage.VIEW_CREATE);
- instead use an object in between which
[a] keeps track of the deviceSelection done at (every instance of) view_B
[b] is used by view_A for creating/navigating to the correct instance of view_B.
Is this correct ?
Re: IViewSite (ico multi-instance view): no means to update secondaryId [message #533996 is a reply to message #533964] Mon, 17 May 2010 16:19 Go to previous messageGo to next message
> view_B: activePage.showView(<view_B>, <secId>, IWorkbenchPage.VIEW_CREATE);
> - instead use an object in between which [a] keeps track of the
> of view_B.
That would be one way ... creating your own DeviceViewManager.
dvm.openView(Device) -> shows the view you want and works out the
primaryId+secondaryID -> Device mapping
dvm.getDevice(IViewPart) reverses the logic. Or something less
complicated, or something more complicated, depending one what your main
usecases are.
PW
Paul Webster
Re: IViewSite (ico multi-instance view): no means to update secondaryId [message #534657 is a reply to message #533996] Wed, 19 May 2010 18:23 Go to previous message
Hello Paul,
Thank you for your suggestion, I've implemented my own ViewMgr, and that indeed is doing the job well.
Previous Topic:reuse Java perspective in an RCP application
Next Topic:ALT+F4
Current Time: Tue Apr 24 10:59:42 GMT 2018
Powered by FUDForum. Page generated in 0.01546 seconds
