[CDO Teneo Hibernate Store] Unable to instantiate default tuplizer [message #518085] |
Tue, 02 March 2010 19:14 |
Originally posted by: austin.teng.siemens.com
--------------050700060002000709050100
I'm getting the following exception after loading a static mapping file
for use with a CDO 3.0 Hibernate Store.
The mapping file was generated using the following code:
props.put(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINME NT,
"PERSIST,MERGE");
props.put(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
props.put(PersistenceOptions.ADD_INDEX_FOR_FOREIGN_KEY, "true");
props.put(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH, "30");
props.put(PersistenceOptions.JOIN_COLUMN_NAMING_STRATEGY, "simple");
CDOHelper.getInstance().generateMapping(ePackages, props) method.
I've attached an excerpt from the the mapping file for reference.
[ERROR] Unable to instantiate default tuplizer
[org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOR evisionTuplizer]
org.hibernate.HibernateException: Unable to instantiate default tuplizer
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:110)
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:82)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:72)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:323)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:456)
at
org.hibernate.persister.entity.SingleTableEntityPersister.<init >(SingleTableEntityPersister.java:131)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:84)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:267)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore .getHibernateSessionFactory(HibernateStore.java:199)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Accessor.beginHibernateSession(HibernateStoreAccessor.java:1 55)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Accessor.getHibernateSession(HibernateStoreAccessor.java:229 )
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Accessor.queryResources(HibernateStoreAccessor.java:372)
at
org.eclipse.emf.cdo.internal.server.ResourcesQueryHandler.ex ecuteQuery(ResourcesQueryHandler.java:38)
at
org.eclipse.emf.cdo.internal.server.QueryManager$QueryContex t.run(QueryManager.java:262)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:107)
... 20 more
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore .addEntityNameEClassMapping(HibernateStore.java:93)
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORe visionTuplizer.initEClass(CDORevisionTuplizer.java:123)
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORe visionTuplizer.buildPropertyGetter(CDORevisionTuplizer.java: 240)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:122)
at
org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORe visionTuplizer. <init>(CDORevisionTuplizer.java:53)
... 25 more
Any thoughts?
Austin
name="hbm_excerpt.txt"
filename="hbm_excerpt.txt"
CTxjbGFzcyBlbnRpdHktbmFtZT0iQ29ubmVjdGlvblBvaW50IiBhYnN0cmFj dD0iZmFsc2Ui
IGxhenk9ImZhbHNlIiB0YWJsZT0iYGNvbm5lY3Rpb25wb2ludGAiPg0KCQk8 bWV0YSBhdHRy
aWJ1dGU9ImVjbGFzc05hbWUiPkNvbm5lY3Rpb25Qb2ludDwvbWV0YT4NCgkJ PG1ldGEgYXR0
cmlidXRlPSJlcGFja2FnZSI+X19SRURBQ1RFRF9fPC9tZXRhPg0KCQk8dHVw bGl6ZXIgZW50
aXR5LW1vZGU9InBvam8iIGNsYXNzPSJvcmcuZWNsaXBzZS5lbWYuY2RvLnNl cnZlci5pbnRl
cm5hbC5oaWJlcm5hdGUudHVwbGl6ZXIuQ0RPUmV2aXNpb25UdXBsaXplciIv Pg0KCQk8dHVw
bGl6ZXIgZW50aXR5LW1vZGU9ImR5bmFtaWMtbWFwIiBjbGFzcz0ib3JnLmVj bGlwc2UuZW1m
LmNkby5zZXJ2ZXIuaW50ZXJuYWwuaGliZXJuYXRlLnR1cGxpemVyLkNET1Jl dmlzaW9uVHVw
bGl6ZXIiLz4NCgkJPGlkIHR5cGU9ImxvbmciIG5hbWU9ImVfaWQiIGNvbHVt bj0iZV9pZCIg
YWNjZXNzPSJvcmcuZWNsaXBzZS5lbWYuY2RvLnNlcnZlci5pbnRlcm5hbC5o aWJlcm5hdGUu
dHVwbGl6ZXIuQ0RPU3ludGhldGljSWRQcm9wZXJ0eUhhbmRsZXIiPg0KCQkJ PG1ldGEgYXR0
cmlidXRlPSJzeW50aGV0aWNJZCI+dHJ1ZTwvbWV0YT4NCgkJCTxnZW5lcmF0 b3IgY2xhc3M9
Im5hdGl2ZSIvPg0KCQk8L2lkPg0KCQk8dmVyc2lvbiBuYW1lPSJlX3ZlcnNp b24iIGNvbHVt
bj0iZV92ZXJzaW9uIiBhY2Nlc3M9Im9yZy5lY2xpcHNlLmVtZi5jZG8uc2Vy dmVyLmludGVy
bmFsLmhpYmVybmF0ZS50dXBsaXplci5DRE9TeW50aGV0aWNWZXJzaW9uUHJv cGVydHlIYW5k
bGVyIj4NCgkJCTxtZXRhIGF0dHJpYnV0ZT0ic3ludGhldGljVmVyc2lvbiI+ dHJ1ZTwvbWV0
YT4NCgkJPC92ZXJzaW9uPg0KCQk8cHJvcGVydHkgbmFtZT0icmVzb3VyY2VJ RCIgdHlwZT0i
b3JnLmVjbGlwc2UuZW1mLmNkby5zZXJ2ZXIuaW50ZXJuYWwuaGliZXJuYXRl LnR1cGxpemVy
LkNET0lEVXNlclR5cGUiPg0KCQkJPGNvbHVtbiBuYW1lPSJyZXNvdXJjZV9p ZCIvPg0KCQk8
L3Byb3BlcnR5Pg0KCQk8cHJvcGVydHkgbmFtZT0iY29udGFpbmVySUQiIHR5 cGU9InN0cmlu
ZyI+DQoJCQk8Y29sdW1uIG5hbWU9ImNvbnRhaW5lcl9pZCIvPg0KCQk8L3By b3BlcnR5Pg0K
CQk8bWFueS10by1vbmUgbmFtZT0ibWF0ZSIgZW50aXR5LW5hbWU9IkNvbm5l Y3Rpb25Qb2lu
dCIgbGF6eT0iZmFsc2UiIGNhc2NhZGU9Im1lcmdlLHBlcnNpc3Qsc2F2ZS11 cGRhdGUsbG9j
ayIgZm9yZWlnbi1rZXk9ImNvbm5lY3Rpb25wb2ludF9tYXRlIiBpbnNlcnQ9 InRydWUiIHVw
ZGF0ZT0idHJ1ZSIgbm90LW51bGw9ImZhbHNlIj4NCgkJCTxjb2x1bW4gbm90 LW51bGw9ImZh
bHNlIiB1bmlxdWU9ImZhbHNlIiBuYW1lPSJgbWF0ZWAiIGluZGV4PSJDb25u ZWN0aW9uUG9p
bnRfbWF0ZSIvPg0KCQk8L21hbnktdG8tb25lPg0KCQk8bWFueS10by1vbmUg bmFtZT0iY29v
cmRpbmF0ZXMiIGVudGl0eS1uYW1lPSJTcGF0aWFsQ29vcmRpbmF0ZXMiIGxh enk9ImZhbHNl
IiBjYXNjYWRlPSJhbGwiIGZvcmVpZ24ta2V5PSJjb25uZWN0aW9ucG9pbnRf Y29vcmRpbmF0
ZXMiIGluc2VydD0idHJ1ZSIgdXBkYXRlPSJ0cnVlIiBub3QtbnVsbD0iZmFs c2UiPg0KCQkJ
PGNvbHVtbiBub3QtbnVsbD0iZmFsc2UiIHVuaXF1ZT0iZmFsc2UiIG5hbWU9 ImBjb29yZGlu
YXRlc2AiIGluZGV4PSJDb25uZWN0aW9uUG9pbnRfY29vcmRpbmF0ZXMiLz4N CgkJPC9tYW55
LXRvLW9uZT4NCgkJPHByb3BlcnR5IG5hbWU9ImZsb3ciIGxhenk9ImZhbHNl IiBub3QtbnVs
bD0iZmFsc2UiIGluc2VydD0idHJ1ZSIgdXBkYXRlPSJ0cnVlIiB1bmlxdWU9 ImZhbHNlIj4N
CgkJCTxjb2x1bW4gbm90LW51bGw9ImZhbHNlIiB1bmlxdWU9ImZhbHNlIiBu YW1lPSJgZmxv
d2AiLz4NCgkJCTx0eXBlIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi5jZG8uc2Vy dmVyLmludGVy
bmFsLmhpYmVybmF0ZS50dXBsaXplci5DRE9FTnVtU3RyaW5nVHlwZSI+DQoJ CQkJPHBhcmFt
IG5hbWU9ImVudW1DbGFzcyI+X19SRURBQ1RFRF9fLkZsb3dEaXJlY3Rpb248 L3BhcmFtPg0K
CQkJCTxwYXJhbSBuYW1lPSJlY2xhc3NpZmllciI+Rmxvd0RpcmVjdGlvbjwv cGFyYW0+DQoJ
CQkJPHBhcmFtIG5hbWU9ImVwYWNrYWdlIj5fX1JFREFDVEVEX188L3BhcmFt Pg0KCQkJPC90
eXBlPg0KCQk8L3Byb3BlcnR5Pg0KCQk8bWFueS10by1vbmUgbmFtZT0ib3du aW5nRnVuY3Rp
b24iIGVudGl0eS1uYW1lPSJGdW5jdGlvbiIgbGF6eT0iZmFsc2UiIGNhc2Nh ZGU9Im1lcmdl
LHBlcnNpc3Qsc2F2ZS11cGRhdGUsbG9jayIgZm9yZWlnbi1rZXk9ImNvbm5l Y3Rpb25wb2lu
dF9vd25pbmdmdW5jdGlvbiIgaW5zZXJ0PSJmYWxzZSIgdXBkYXRlPSJmYWxz ZSIgbm90LW51
bGw9ImZhbHNlIj4NCgkJCTxjb2x1bW4gbm90LW51bGw9ImZhbHNlIiB1bmlx dWU9ImZhbHNl
IiBuYW1lPSJgb3duaW5nZnVuY3Rpb25gIiBpbmRleD0iQ29ubmVjdGlvblBv aW50X293bmlu
Z0Z1bmN0aW9uLENvbm5lY3Rpb25Qb2ludF9vd25pbmdGdW5jdGlvbiIvPg0K CQk8L21hbnkt
dG8tb25lPg0KCQk8cHJvcGVydHkgbmFtZT0ibmFtZSIgbGF6eT0iZmFsc2Ui IGluc2VydD0i
dHJ1ZSIgdXBkYXRlPSJ0cnVlIiBub3QtbnVsbD0iZmFsc2UiIHVuaXF1ZT0i ZmFsc2UiIHR5
cGU9ImphdmEubGFuZy5TdHJpbmciPg0KCQkJPGNvbHVtbiBub3QtbnVsbD0i ZmFsc2UiIHVu
aXF1ZT0iZmFsc2UiIG5hbWU9ImBuYW1lYCIvPg0KCQk8L3Byb3BlcnR5Pg0K CTwvY2xhc3M+
--------------050700060002000709050100--
Re: [CDO Teneo Hibernate Store] Unable to instantiate default tuplizer [message #518132 is a reply to message #518085] |
Wed, 03 March 2010 08:27 |
Hi Austin,
A NPE is always a bug. The source line mentioned in the stack trace does not seem to correspond to what I have. Are you
using the latest version of CDO 3.0? You can install the latest version always through this update site:
https://build.eclipse.org/hudson/job/emf-cdo-integration/las tSuccessfulBuild/artifact/result/site.p2/
In any case it is a bug, can you print what you have on this line:
(or debug to see which member/variable is null)
Then I can check with some more detail what goes wrong here.
gr. Martin
> "PERSIST,MERGE");
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> Method)
> Source)
> Source)
> at
> ... 20 more
> at
> at
> at
> at
> at
> ... 25 more
> Any thoughts?
> Austin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO Teneo Hibernate Store] Unable to instantiate default tuplizer [message #518565 is a reply to message #518132] |
Thu, 04 March 2010 08:58 |
Thanks for the reply. I'll take a deeper look some time in the next
several days and get back to you.
--Austin
On 3/3/10 2:27 AM, Martin Taal wrote:
> Hi Austin,
> not seem to correspond to what I have. Are you using the latest version
> update site:
> gr. Martin
>> file for use with a CDO 3.0 Hibernate Store.
>> "PERSIST,MERGE"); props.put(PersistenceOptions.INHERITANCE_MAPPING,
>> "JOINED"); props.put(PersistenceOptions.ADD_INDEX_FOR_FOREIGN_KEY,
>> "true");
>> tuplizer
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> ... 20 more
>> at
>> at
>> at
>> at
>> at
>> ... 25 more
>> Any thoughts?
>> Thanks,
>> Austin
FUDForum. Page generated in 0.03299 seconds
