Home » Eclipse Projects » Dali » JPA dali, moving the persistence.xml
JPA dali, moving the persistence.xml [message #435550] Sat, 18 July 2009 21:06 Go to next message
harpritt is currently offline harprittFriend
This has been driving me nuts all day
Id like to use the JPA Dali web tool but am faced with the annoying
problem of the persistence.xml file location.
I use maven and the maven file structure, this means that my
persistence.xml must be located under
src/main/resources/META-INF/persistence.xml
unfortunatly the Dali Jpa tool seems only to want to look in src/META-INF
ive added src/main/resources/ to my source, looked at the files under
settings ...
please, can anyone help..... minoxodil will not help my hair loss..... grrr
Re: JPA dali, moving the persistence.xml [message #435551 is a reply to message #435550] Sat, 18 July 2009 21:15 Go to previous messageGo to next message
Ok..... sods law
as soon as i post my problem on the news group... i flipping well work out
the solution. How annoying!
The solution was to add src/main/resources to the source (under build
path) BEFORE i set up the JPA Facet
....BEFORE... AFTER.... BEFORE AFTER..... baaaaaaaa
anyway it works now...
hope it helps someone else.
Re: JPA dali, moving the persistence.xml [message #435554 is a reply to message #435551] Thu, 23 July 2009 16:55 Go to previous messageGo to next message
Originally posted by: buchholz-news.security.de
This does not help for me. I use a Galileo installation, also with maven2
plugin. I follow your instructions, but the "JPA Content" Descriptor is
empty and after selecting an Entity Class the "JPA Details" view
shows: "Details are not available for current selection".
Did you use the stable Maven Plugin or the development release?
harpritt wrote:
> Ok..... sods law
Re: JPA dali, moving the persistence.xml [message #435555 is a reply to message #435554] Fri, 24 July 2009 06:52 Go to previous messageGo to next message
Philippe Marschall is currently offline Philippe MarschallFriend
There are a couple of tricks to get Dali working with Maven. The first
is that it needs to be a WTP project (actually faceted). For this you
need to set <wtpversion> [1]. Then you need to add the jpt.jpa facet.
You can do this manually or with <additionalProjectFacets>. In the later
case you'll probably also need some configuration files, see
<additionalConfig>.
[1] http://maven.apache.org/plugins/maven-eclipse-plugin/eclipse -mojo.html
Cheers
Philippe
Re: JPA dali, moving the persistence.xml [message #435582 is a reply to message #435555] Thu, 30 July 2009 11:56 Go to previous messageGo to next message
--nextPart1344033.xlZ5yCEqqc
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8Bit
<ver
Re: JPA dali, moving the persistence.xml [message #488450 is a reply to message #435554] Mon, 28 September 2009 17:20 Go to previous messageGo to next message
Gy is currently offline GyFriend
you might want to add one more step to the described method:
1. Remove the Java Persistence facet.
2. Add the resources folder to the src
3. AT BUILD PATH -> ORDER AND EXPORT TAB, MOVE THE RESOURCES FOLDER TO THE TOP
4. Add Java Persistence facet.
When I followed these steps I managed to get it working.
Gyorgy
Re: JPA dali, moving the persistence.xml [message #508143 is a reply to message #488450] Sat, 16 January 2010 14:18 Go to previous messageGo to next message
Daniel Zwicker is currently offline Daniel ZwickerFriend
I have solved the probelm with maven2 and eclipse JPA by removing the exclused: '**' from the src/main/resources entry in the classpath in the project properties. Instead I set the Includes to 'META-INF/persistence.xml'
For me its working even after e restart of eclipse.
Re: JPA dali, moving the persistence.xml [message #551534 is a reply to message #435550] Fri, 06 August 2010 20:53 Go to previous messageGo to next message
d. hartford is currently offline d. hartfordFriend
Thank you everyone who contributed this thread - all of these hints mattered (right up to and including the removing '**' exclusion entry in the classpath).
Re: JPA dali, moving the persistence.xml [message #616664 is a reply to message #435550] Sat, 18 July 2009 21:15 Go to previous messageGo to next message
Ok..... sods law
Re: JPA dali, moving the persistence.xml [message #616670 is a reply to message #435551] Thu, 23 July 2009 16:55 Go to previous messageGo to next message
harpritt wrote:
> Ok..... sods law
Re: JPA dali, moving the persistence.xml [message #616672 is a reply to message #435554] Fri, 24 July 2009 06:52 Go to previous messageGo to next message
<additionalConfig>.
Cheers
Philippe
Re: JPA dali, moving the persistence.xml [message #617454 is a reply to message #435555] Thu, 30 July 2009 11:56 Go to previous messageGo to next message
<ver
Re: JPA dali, moving the persistence.xml [message #617619 is a reply to message #435554] Mon, 28 September 2009 17:20 Go to previous messageGo to next message
Gyorgy
Re: JPA dali, moving the persistence.xml [message #618690 is a reply to message #617619] Sat, 16 January 2010 14:18 Go to previous messageGo to next message
Re: JPA dali, moving the persistence.xml [message #619384 is a reply to message #435550] Fri, 06 August 2010 20:53 Go to previous messageGo to next message
Re: JPA dali, moving the persistence.xml [message #1751960 is a reply to message #435550] Tue, 17 January 2017 09:07 Go to previous message
Yunus Evren is currently offline Yunus EvrenFriend
For me, the problem was the JPA version difference between the persistence.xml and the JPA project facet.
persistence.xml was configured with
<persistence version="2.1" ......
whereas the JPA version in my project facets was configured as 2.0.
Previous Topic:Need your criticism
Next Topic:Thoughts on JPA 2.0 metamodel generation in Dali 3.0
Current Time: Fri Jan 19 07:57:58 GMT 2018
Powered by FUDForum. Page generated in 0.03013 seconds
