Home » Eclipse Projects » Babel » Signing jar problem(When I sign jar xxx.nl_xxx manifest.mf is wrong)
Signing jar problem [message #503862] Wed, 16 December 2009 02:20 Go to next message
Hoang-Quan is currently offline Hoang-Quan
I have a problem when I sign fragments plugins packages languages.
The jars are signed but the file manifest.mf is changed and information on the bundle are removed.
The following data is removed from the file manifest.mf:
Manifest-Version: 1.0
Bundle-Name: org.eclipse.core.commands French NLS Support
Bundle-SymbolicName: org.eclipse.core.commands.nl_fr ;singleton=true
Bundle-Version: 3.4.0.v20081123043401
Bundle-Vendor: Eclipse.org
Fragment-Host: org.eclipse.core.commands
There remains only the information on the signing:
SHA1-Digest: Vigk0ly8waWzdFFZzSZEA1UvS9Y=
SHA1-Digest: VpXXGnjM0HeeD/l2/5T0GziCHVE=
SHA1-Digest: 6mDW8kS/T9pK7w1by/wcxy21Z20=
Someone would have an idea?
Thank you in advance for your help.
Hoang-Quan
Re: Signing jar problem [message #504779 is a reply to message #503862] Tue, 22 December 2009 11:03 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse Webmaster
On 12/16/2009 02:20 AM, Hoang-Quan wrote:
> Hello,
> Quote:
> Quote:
How are you signing your jars? Are you using jarsigner and a code
signing cert?
Re: Signing jar problem [message #504856 is a reply to message #504779] Wed, 23 December 2009 01:23 Go to previous messageGo to next message
Thank you for your reply.
I used the "export wizard" feature.xml and I also sign the jar with the command jarsigner.
Both ways gave the same result.
Yes I use a certificate.
Hoang-Quan
Re: Signing jar problem [message #509035 is a reply to message #504856] Thu, 21 January 2010 04:06 Go to previous messageGo to next message
TW  is currently offline TW
Member
did you find a solution to fix your problem.
I have a similar problem when exporting my producs with ant scripts.
I added some language packs and want to sign my jars. The standard eclipse plugins and features are already signed by eclipse. But the language files (plugins) which I downloaded from the babel website are not signed.
During the build process these unsigned language plugins get signed with my signature and end up in the structure you discribed earlier.
Because of this it is not possible to launch my product with the language packs.
If I don't sign jars => Product launches in german language
If I sign jars => Product does launch in english language
I think this has something to do with signing the jars.
A solution would be to exclude the language plugins from the sign process, but I would have to all plugins manually.
Is there any other solution or are there any signed babel language packs?
Re: Signing jar problem [message #509041 is a reply to message #509035] Thu, 21 January 2010 04:25 Go to previous messageGo to next message
Member
Hi I found something interesting here.
Are you building with 1.5.xx or 1.6.xx (sounds like with 1.6.xx the manifest.mf will not be overwritten).
http:// stackoverflow.com/questions/1877552/how-can-i-sign-an-osgi-b undle-with-ant-without-overwriting-the-manifest-mf-conten
Re: Signing jar problem [message #509119 is a reply to message #509041] Thu, 21 January 2010 07:49 Go to previous messageGo to next message
I tried to sign my jar with jdk 1.6.xx and it works.
I conducted a second test with an old jdk I had 1.5.0_12 and it works well.
By cons with jdk 1.5.0_18 and 1.5.0_20 that does not work anymore.
I found this post on sun bug jarsigner :
http://bugs.sun.com/view_bug.do?bug_id=6712755
Thank you very much for your answer, you helped me a lot.
Re: Signing jar problem [message #509143 is a reply to message #509119] Thu, 21 January 2010 08:59 Go to previous messageGo to next message
Member
great to hear that your build now works correctly.
I have one question did I understand you right, that you can build with 1.5.0_12 and sign unsigned jars but with 1.5.0_18 and _20 it doesnt work. I think we used _9 and _16 but were not successful.
Can you post me a quote from your build properties where you set the jarsigner with the properties.
I want to check If he have the same properties and correct ours If this is necessary because we are not able to switch to 1.6.xx at the moment
Re: Signing jar problem [message #509187 is a reply to message #509143] Thu, 21 January 2010 10:51 Go to previous messageGo to next message
The build of the application is done with jdk 1.5.0_20.
I use a feature to export project and sign the jar. The feature project uses windows environment variables to select the jdk to use for signing jars.
In the environment variables I set the jdk 1.5.0_12.
In doing so it works.
[Updated on: Thu, 21 January 2010 10:52]
Report message to a moderator
Re: Signing jar problem [message #509809 is a reply to message #509187] Mon, 25 January 2010 08:41 Go to previous messageGo to next message
Member
I think this is a good solution. I would like to do it the same way but didn't understand the build process you use completely.
I would like to build my application with JDK 1.5.x and sign my jars with 1.6 because in 1.6 this bug has been fixed.
You say that you build your application with JDK 1.5.0_20. So how do you build your application, with Ant Skripts, or do you build your executable file with another method?
Can you explain the thing with the feature which selects the jdk from a environment variable a little more detailed?
TW
Re: Signing jar problem [message #580222 is a reply to message #504779] Wed, 23 December 2009 01:23 Go to previous messageGo to next message
Hoang-Quan
Hoang-Quan
Re: Signing jar problem [message #580453 is a reply to message #580222] Thu, 21 January 2010 04:06 Go to previous messageGo to next message
Member
Re: Signing jar problem [message #580466 is a reply to message #580453] Thu, 21 January 2010 04:25 Go to previous messageGo to next message
Member
http://stackoverflow.com/questions/1877552/how-can-i-sign-an -osgi-bundle-with-ant-without-overwriting-the-manifest-mf-co nten
Re: Signing jar problem [message #580489 is a reply to message #580466] Thu, 21 January 2010 07:49 Go to previous messageGo to next message
Hoang-Quan
Re: Signing jar problem [message #580505 is a reply to message #580489] Thu, 21 January 2010 08:59 Go to previous messageGo to next message
Member
Re: Signing jar problem [message #580521 is a reply to message #580505] Thu, 21 January 2010 10:51 Go to previous messageGo to next message
Hoang-Quan
Hoang-Quan
Re: Signing jar problem [message #580562 is a reply to message #580521] Mon, 25 January 2010 08:41 Go to previous message
Member
TW
Previous Topic:where can i find the BableLangugaePack for cdt 6.0?
Next Topic:customize strings/translations
Current Time: Wed May 22 17:53:01 EDT 2013
Powered by FUDForum. Page generated in 0.02172 seconds
