Building a RAP web-app with buckminster [message #502137] |
Sun, 06 December 2009 14:42 |
Johannes Utzig Messages: 329 Registered: July 2009 |
--------------090409020701000107070904
on thursday I talked to Benjamin for a little while and he explained me
that users find it currently too hard to package rap based applications
as wars. We were talking about if the buckminster project could make
things easier.
So I had a look at at the org.eclipse.rap.demo.feature and how to build
a war out of it. I do understand now why people find this complicated :)
Anyway, I tried to 'buckminsterize' this build today and wanted to post
the results here so they can be discussed.
Since I could not modify the sources directly of course, I created a new
feature org.eclipse.rap.demo.releng.feature that encapsulates the war build.
This is still not great, because users would still have to adjust this
to their own project, but a wizard or a buckminster extension could
simplify things here. So I hope this is enough to give you an idea of
the buckminster approach.
Instructions:
-start with a new workspace
-Configure and activate the RAP Target Platform
-Install Buckminster into your IDE
-Import the attached eclipse project
-open buckminster/org.eclipse.rap.demo.feature.cquery
-Press Resolve and Materialize (this will bring all required build
materials into the workspace)
-right click on the org.eclipse.rap.demo.releng.feature project
-select buckminster -> invoke action
-select the buckminster/buckminster.properties file in the dialog
-select the create.webapp or create.webapp.war action
Now the build results should be available at
${user.home}/rap-build/org.eclipse.rap.demo.releng.feature_1 .0.0-eclipse.feature/
Now the interesting part is certainly how to do a headless build for
that on a build server.
With buckminster it's exactly the same as building it locally with UI
support:
First, resolve the query to populate the workspace with the build materials:
buckminster resolve http://url/to/query.cquery
Second, invoke the create.webapp.war action:
buckminster perform org.eclipse.rap.demo.releng.feature#create.webapp.war
That's all you need for a headless build.
A brief explanation on what's involved here (the resources and ant
scripts in the original org.eclipse.rap.demo.feature are not used):
-the cquery
The query describes the topmost component that you want to materialize
in the workspace. Buckminster will try to resolve this component, parse
its metadata and then resolve all direct and transitive dependencies of
this component
-the rmap
The resource map (rmap) contains search paths that describe where
components can be found. There are different kinds of component
providers, including cvs, svn, eclipse update sites, filesystem, maven,
archives, urls,...
In this example I used search paths for the eclipse platform itself
(things like org.eclipse.help), the rap update site, the cvs location
where the rap example resides and the cvs location for the equinox
servletbridge.
-buckminster.cspex
Buckminster derives information about a component automatically from the
component's metadata (like osgi manifest, maven pom,...).
The cspex file is a way to add additional metadata that cannot be
derived automatically. In this case I basically added 2 new actions to
the org.eclipse.rap.demo.releng.feature:
create.webapp and create.webapp.war
These two actions are responsible for building the webapp and packaging
it as a war file. They have an ant actor that does the actual work and
certain prerequisites that get injected into the actor (in case of ant
actors this is done by properties).
So for example the create.webapp action has 3 prerequisites:
feature.exports - this is an automatically derived action for all
eclipse.features. It produces the output you would expect if you export
the feature from within eclipse (bundles and features directory)
templates - this is the templates directory that contains the web.xml
and so on
library - this is what should go in /lib in the webapp. In the case of
the rap example it's the output of the bundle.jar action of the equinox
servletbridge.
-create.webapp.xml
This is a simple ant script that 'implements' the create.webapp and
create.webapp.war actions. All the input they need is automatically
delivered by buckminster so the script is just some simple copy statements.
I hope it works for you and gives you an idea...
Johannes
Content-Type: application/zip;
name="webapp-releng.zip"
Content-Disposition: inline;
filename="webapp-releng.zip"
UEsDBBQACAAIAE15hjsAAAAAAAAAAAAAAAAsAAAAb3JnLmVjbGlwc2UucmFw LmRlbW8ucmVs
ZW5nLmZlYXR1cmUvLnByb2plY3R1kM0OgjAQhM/yFIa7rd48FEjUcPSiPkBt V1LTv2zB+Pi2
gESM3mY2s/Nll1VPo5cPwKCcLfINWedLsMJJZZsiv5zr1Tavyox5dHcQ7QGC QOXbGC6zBbPc
QOmwISC08gEIck8kGEcQNNiG3IC3HQKjfTJuCGcM2LZk9K3icCwPSdNPc+2U licPIprR7eMa
tzINfvC9BFIPzF1KA07oGOfYdIkZBktnntGv/nEw4iMrtQ7RQf8jH6eb+1Rq mpan+2affAFQ
SwcIRNyKAcMAAACGAQAAUEsDBBQACAAIAE15hjsAAAAAAAAAAAAAAABGAAAA b3JnLmVjbGlw
c2UucmFwLmRlbW8ucmVsZW5nLmZlYXR1cmUvYnVja21pbnN0ZXIvYnVja21p bnN0ZXIucHJv
cGVydGllcw3Iyw2AIAwA0LtzeLVMwDBQamwESvo5GXfXd3w18B48zUlBwlc4 qIjn/Qn765JB
b9KyjhrcW9qwMvDEHo3AJBQpn6UbfVBLBwgDwCzURQAAAEgAAABQSwMEFAAI AAgATXmGOwAA
AAAAAAAAAAAAAFMAAABvcmcuZWNsaXBzZS5yYXAuZGVtby5yZWxlbmcuZmVh dHVyZS9idWNr
bWluc3Rlci9vcmcuZWNsaXBzZS5yYXAuZGVtby5mZWF0dXJlLmNxdWVyeWWP sW7DMAxEd3+F
wN1SuwVG5AwFsnVokX6AIjOuUYuUKSlu/j5KgGTJrbx3x9vu/sOszihpYrLw rt9AIXkeJhot
/Bz27QZ2fbP1S+c5RCak/FVQLqpylDq/WPjNOXbGrOuq0c9TTKhZRnMs/i9M lDKK+bgz7T1e
MHERj58uWhAX24HHE/OgJbgIfaOqbn3CnL9xKZiyIhfQQk19NlRQDxhYC85I oz6hy0UQ1PPN
wyVW5uF/3E0dY17W9M0VUEsHCK4Yv1e8AAAACQEAAFBLAwQUAAgACABNeYY7 AAAAAAAAAAAA
AAAAQAAAAG9yZy5lY2xpcHNlLnJhcC5kZW1vLnJlbGVuZy5mZWF0dXJlL2J1 Y2ttaW5zdGVy
L3JhcC1kb2dmb29kLnJtYXDVlUtr20AQx8/yp1iWHtom1toJhSLkuNDHqQGT ptCDKaxWY3uJ
9tHdlR+UfveOXk5c4lgEeshJmtXM/z/z066UTreqIGtwXho9oeN4RAloYXKp lxP6/fbL8D2d
Xg0GqVPcEszVfkJXIdiEsc1mE4MopPUQG7dkWSnulNQ+gGM319wOa7W6Jtl6 eVC3uaxLLkaj
Mftx/fWbWIHiw6qYawF0EDVlyvZyu+Zr0DNn1jIHV9t2AranwuzTZ+z4UYlM 9FL4aJQyuq5E
XlHqgTuxmvGwIpormFAs2Bc7buMclMHUKEpta0sccLzc7iymi7WnRBhljQYd qjUkb/xSxlmp
8wLOO60F8FA6oESVgWcFlgZXVgijyJvSiW6hsorS0snqGi0MvtEwoQlKOHz/ CddG75Qp/Ycc
1g+nTBi24owJzIXzf4ZgDgrQS/Z79KfRj9JMJDiPBRd2N7Agd7Cb0Aec4v1I lLCmJYY91RxY
BwKjlN0DxLAH0CdYdlkSrV14LtYFLzzGHdQm3FMlHdF2r+RmowvD84MN4xAi UhvHF6y0OQ8w
bVqq28yk5m5H2QkWJzeXLXiomnkJQNr7loZnl/G75yA5QQR+lVKbbVxt9QJC 5mS+hBd99tqJ
WCMw9DgCa3rz//0wYlwYwYNx5H4Z5Y984ojlAb3w7/ITn8+7hHmVMa9TXs/j +OzNtOmhp/aT
so3gWX/BxzfIUYs2fX6Y37i+7e+6P6hHjFour2rFQcqqf/DV4C9QSwcIaEC+ ajECAACzBwAA
UEsDBBQACAAIAE15hjsAAAAAAAAAAAAAAAA1AAAAb3JnLmVjbGlwc2UucmFw LmRlbW8ucmVs
ZW5nLmZlYXR1cmUvYnVja21pbnN0ZXIuY3NwZXjVVMtu2zAQPNtfQRC9mnTa SxFQDoKiObVA
gbRIryS1sZlQJMuHZaPov3clS4mV1EEfp/IiacWZ3Z1ZUlzsGku2EJPxrqJn bEkJOO1r49YV
/fL5avGWXqzmQqcA+v0ug+s2zmeIcul8l0xFNzmHc87btmXtG+bjmr9eLs/4 148frvUGGrkw
LmXpNNARpvQEBdqakKCHqqLvmw4Akb/zTePdoqtpQP4e7BpL7VGr+UzImM2t 1Dnhx0yEoqzR
xMkGKpqhCVZmSJQEmTeTAO+w/Bgs8Imt/4JHR0AQa0HJECjBfT5WVLpMSbeZ 4BJ98FP0AZAS
kIQ8WSIcfu7JPewrqoqx9ZWxQMlW2gJDhE9yMRSF8ikXFv1SKkwDEb4Vkwz2 SaQ1ElVtkDMa
aVMnGS4hc45GlQxDi7eYtURgsAs+ZtRnAKriaot68RO4I0UHxGPkFObAye5k pET7JngHLlcU
bX6wvGvA+R1LELcWsoqmXsNDCmtUlHE/JBB80vIzOXxd0OARO5qoZMJSXn0/ GizmSw4l/6BT
ChwGHJ5hgm5AXYbAn5sy5jmKY7CfohW+vzxTrO20+A/n6nBkmHGo26nRenJ6 /t60Ra/SPxl3
IyM/vPWS/6mLj9Sz/vYYLwzBp9fnav4TUEsHCIS26xPhAQAAdwUAAFBLAwQU AAgACABNeYY7
AAAAAAAAAAAAAAAAOwAAAG9yZy5lY2xpcHNlLnJhcC5kZW1vLnJlbGVuZy5m ZWF0dXJlL2J1
aWxkL2NyZWF0ZS53ZWJhcHAueG1spZJdS8MwFIav218RgrdL9HakHQgK3njr dZKejbi0CflY
nbL/7mlX3XRYkAUKKW/yvA+ciNVba8kOQjSuq+gdu6WruhQ+uFfQiXSyhYpO f7QuykIkGTbw
legAMgHrQUnvaV0WhWi3jQkEv4refES/PGYHysdUO78nyV3Gg4NyEZkpZBhR hVgbCxHLTscT
tN5iZcQbA5HgEnygjniV9bY1XUwQ2F9V/OXhfvH0/MhBW+MjUOKwuw8mnZeP 4HPc5LIJLnuy
kzbDgF3HpcpdY7+FCsF/S/zfzBp1rRUiggz7WSvBj8PE7exgWS/D3HAXmB84 Y9OM340nDcQ0
uF2eo0TJCCeE1AmfHjOdzwnDWnC8/0NO8OkB1mX5CVBLBwhkgJMKGAEAALAC AABQSwMEFAAI
AAgATXmGOwAAAAAAAAAAAAAAADQAAABvcmcuZWNsaXBzZS5yYXAuZGVtby5y ZWxlbmcuZmVh
dHVyZS9idWlsZC5wcm9wZXJ0aWVzS8rM08vMS84pTUktVrBVSEtNLCktStWr yM3hAgBQSwcI
iKXg9h0AAAAbAAAAUEsDBBQACAAIAE15hjsAAAAAAAAAAAAAAAAvAAAAb3Jn LmVjbGlwc2Uu
cmFwLmRlbW8ucmVsZW5nLmZlYXR1cmUvZmVhdHVyZS54bWx9kT9TAjEQxfv7 FDfpyWHnOHdQ
qFSWWjkWIVmOHfaSkD8c+ukNmMF4IyRd9r332822y+NA9QGcR6M7dsfnrAYt jULdd+ztdTW7
Z8tF1W5AhOigqs8HVceM6zlIQuuBO2G5gsFwBwS651nNspzEGqhjq7+vJTTd fRSEGwTHFtVJ
0Srw0qENSVNHl/zbEOxD04zjyOEoBkvApRmaQpesP9nvzzqAqzOxfiqituCA f5wJpTVDpbGf
DvttuIm8qKbAx4v9GvJizUBCCdrDTVzWTGEv2XoNlW0ZhFpSTAPnjFtbnKyv 3NVpU3PW5ExL
sUd9PRH2EbU5cg/uQBDWDlVfxiozajJCzTx+QQovSqh9EET/VCa9/BaitkLu OrYRlD7r1GPb
5FEW1TdQSwcIRZG0PyYBAADpAgAAUEsDBBQACAAIAE15hjsAAAAAAAAAAAAA AABNAAAAb3Jn
LmVjbGlwc2UucmFwLmRlbW8ucmVsZW5nLmZlYXR1cmUvdGVtcGxhdGVzL1dF Qi1JTkYvZWNs
aXBzZS8uZWNsaXBzZXByb2R1Y3QDAFBLBwgAAAAAAgAAAAAAAABQSwMEFAAI AAgATXmGOwAA
AAAAAAAAAAAAAFYAAABvcmcuZWNsaXBzZS5yYXAuZGVtby5yZWxlbmcuZmVh dHVyZS90ZW1w
bGF0ZXMvV0VCLUlORi9lY2xpcHNlL2NvbmZpZ3VyYXRpb24vY29uZmlnLmlu aY2UTUsEMQyG
7/srBrxKEREEYWFB9LQnvXppZzKzWTtNN03349/bOiruoZ05tFDy9G37JunN S2vRB2jeohMc
oXkm1+MQWQuSa17RworCgMpE11kI65ZGhSaNNiqjA2yCaJbbj1XTEA8KJjnV EudpHLXrQp1x
Ak7k4qtSnRZt0HXohoWYIhOAj9rYpcLKM3lgudR4OHuGEJI51Wft0+m1OE92 FxA4RHR0Vtr7
GSJbTG5z/1THdiJeMQwYhEvPu2KzdRbEMHbD3C3/b5hBk3c9MLgWSu78kjOX /a7JfCaWpXZg
S/ax9qqDkSrhfa/bJXX3x1bifBJ1uHssxSo7JQoxapsXC7AKElEdEU4ls36Q E/GnSfnZVbGZ
3F0VT+qY1OC5YaYv5Oo7SUnodbTynvW2cAS7flh9AVBLBwipQc4mNQEAAJQE AABQSwMEFAAI
AAgATXmGOwAAAAAAAAAAAAAAAEgAAABvcmcuZWNsaXBzZS5yYXAuZGVtby5y ZWxlbmcuZmVh
dHVyZS90ZW1wbGF0ZXMvV0VCLUlORi9lY2xpcHNlL2xhdW5jaC5pbmmFkcFq wzAQRO/+iiE5
FHLIHwQKobdCQ9Mf2MprW1TWipWcxH/fRQ4ppoUepZl9M1pt8eKCT5nxPsXi R8ZRYuf7Sal4
iXi7sKpvOTdbfAxsvqSSWIvnDFJGEGq5tVsviiLIhUyMPcrA6JRGvop+gWIL RxEUsuCTMWUb
Mrvc+TjPufCI04Nugc9xCgHegpATO08BFwrTH9MVH5h0HfuU4STNkM4Q64T5 v8qWv9ltaumf
vj2bR3H1Zbi3s/kl+NcDDEcFIxU3WHpS7vwN0eh7NI3k3u93h8poRPv96oKX P3mcF3uyfcdy
DJRz3boeKKVFchIL3xbttWqnaq6Ob1BLBwjmwlBf+wAAAOQBAABQSwMEFAAI AAgATXmGOwAA
AAAAAAAAAAAAAD0AAABvcmcuZWNsaXBzZS5yYXAuZGVtby5yZWxlbmcuZmVh dHVyZS90ZW1w
bGF0ZXMvV0VCLUlORi93ZWIueG1stVZtb9s2EP6c/IqrPhaR1PrTkCku0rwM GbrVmFMM/VTQ
0slmQpEcX+zo3+9ISraSrfFQYEYgOMfjPXfPPXdy9eGpE7BFY7mSF9n74l0G KGvVcLm+yL7c
3+Y/ZR/mp9Wb689X918XN7DDVc60hsWXj5/uriDLy3LpJfzGa6Nsbx129gzu ZF2U5fX9NfyJ
K7jUWvCaOUKAWTEry5vfM8g2zunzsnxgW1ZYL4tadeXDDLFsXGPLAebb7Nus IENGKYzIvLnI
KCxFJetJZdFsBbpoXhnerDGY9/Zcsg7n+JfnUj2l8+GkKp+5hDsNt1qwPhlu 0h34GC/Bcrz1
zCneQlsbrkN937808ZlmVwtm7VyZdYG14NpiMaRaDB4p5SLFW77MPF0/BfrE R/Umz8FtED4v
f+FQK2mVQOAWvMXWC2iVAWeUX5HVbpRy1GZYeQc7Lug0PLyGXnmT4u0/RHzA RANCrYFSrB9F
fwZWQYOsdnzLHAL1VxvV+Dq2miAhz+f7vELZXHKXa2ZYF1g4qeLXxCT1v2Oy EVxiVU7sE78t
Ex7n+VDW6JWs5BUAyglCtIwZHOi5pTPcKfMIV0oSGcISUV40sMJnNKGN7Ghv tLJ4Fmg6cLJD
IB2wwCMn7Un443JBg7PlRskOpQNNVDXYMi9cZOH14lGGUPvMxsReJ6Jlwh5n 4TSZUgMAjkoN
qAlRQoPY4HJxB8wg4JNWxmEDzDvV0TjXTIgenIreXjZoRB8Yi9prx1qKCHu/ CQEcklezL/Mm
RrQQE0VHjFFEtbMxoNVY83bcG6oF1jQ8fGcCwtKgW/UjW4952QMOdY/SC6pn EFUFFgNEyF1w
60Kw4RIwOwLR4aqPyFnKK18kgIw6T7pEIHnyllQBG2RUbAK8JangE+u0wPOA VnQ9PTWTfTFg
/Lxfr7Rdi3dnL7wUQZp/d40A/0E83+H1dfUcF84gG4hpfFUeaiYHtvq0I9RO HhoNgnlZUzEQ
Cjq0Y5wCbs+Pq6/YF/FpiHak+Pal/1VYia+X/gNZPGfrH5smLZrEoVCsyZXM rWPGeT1/X5Uv
TfTaGlf45BWWd7RlaYB++PXljaCEHA2SnJdvq3L6/wRygpPWQugTTQv9mYBk aBR4mzrMJu/u
NAY2zg7t9l+XC1uQOELh/1MRb4sHq4/XcXJajT8Y5qd/A1BLBwjeItv2bQMA ANIIAABQSwEC
FAAUAAgACABNeYY7RNyKAcMAAACGAQAALAAAAAAAAAAAAAAAAAAAAAAAb3Jn LmVjbGlwc2Uu
cmFwLmRlbW8ucmVsZW5nLmZlYXR1cmUvLnByb2plY3RQSwECFAAUAAgACABN eYY7A8As1EUA
AABIAAAARgAAAAAAAAAAAAAAAAAdAQAAb3JnLmVjbGlwc2UucmFwLmRlbW8u cmVsZW5nLmZl
YXR1cmUvYnVja21pbnN0ZXIvYnVja21pbnN0ZXIucHJvcGVydGllc1BLAQIU ABQACAAIAE15
hjuuGL9XvAAAAAkBAABTAAAAAAAAAAAAAAAAANYBAABvcmcuZWNsaXBzZS5y YXAuZGVtby5y
ZWxlbmcuZmVhdHVyZS9idWNrbWluc3Rlci9vcmcuZWNsaXBzZS5yYXAuZGVt by5mZWF0dXJl
LmNxdWVyeVBLAQIUABQACAAIAE15hjtoQL5qMQIAALMHAABAAAAAAAAAAAAA AAAAABMDAABv
cmcuZWNsaXBzZS5yYXAuZGVtby5yZWxlbmcuZmVhdHVyZS9idWNrbWluc3Rl ci9yYXAtZG9n
Zm9vZC5ybWFwUEsBAhQAFAAIAAgATXmGO4S26xPhAQAAdwUAADUAAAAAAAAA AAAAAAAAsgUA
AG9yZy5lY2xpcHNlLnJhcC5kZW1vLnJlbGVuZy5mZWF0dXJlL2J1Y2ttaW5z dGVyLmNzcGV4
UEsBAhQAFAAIAAgATXmGO2SAkwoYAQAAsAIAADsAAAAAAAAAAAAAAAAA9gcA AG9yZy5lY2xp
cHNlLnJhcC5kZW1vLnJlbGVuZy5mZWF0dXJlL2J1aWxkL2NyZWF0ZS53ZWJh cHAueG1sUEsB
AhQAFAAIAAgATXmGO4il4PYdAAAAGwAAADQAAAAAAAAAAAAAAAAAdwkAAG9y Zy5lY2xpcHNl
LnJhcC5kZW1vLnJlbGVuZy5mZWF0dXJlL2J1aWxkLnByb3BlcnRpZXNQSwEC FAAUAAgACABN
eYY7RZG0PyYBAADpAgAALwAAAAAAAAAAAAAAAAD2CQAAb3JnLmVjbGlwc2Uu cmFwLmRlbW8u
cmVsZW5nLmZlYXR1cmUvZmVhdHVyZS54bWxQSwECFAAUAAgACABNeYY7AAAA AAIAAAAAAAAA
TQAAAAAAAAAAAAAAAAB5CwAAb3JnLmVjbGlwc2UucmFwLmRlbW8ucmVsZW5n LmZlYXR1cmUv
dGVtcGxhdGVzL1dFQi1JTkYvZWNsaXBzZS8uZWNsaXBzZXByb2R1Y3RQSwEC FAAUAAgACABN
eYY7qUHOJjUBAACUBAAAVgAAAAAAAAAAAAAAAAD2CwAAb3JnLmVjbGlwc2Uu cmFwLmRlbW8u
cmVsZW5nLmZlYXR1cmUvdGVtcGxhdGVzL1dFQi1JTkYvZWNsaXBzZS9jb25m aWd1cmF0aW9u
L2NvbmZpZy5pbmlQSwECFAAUAAgACABNeYY75sJQX/sAAADkAQAASAAAAAAA AAAAAAAAAACv
DQAAb3JnLmVjbGlwc2UucmFwLmRlbW8ucmVsZW5nLmZlYXR1cmUvdGVtcGxh dGVzL1dFQi1J
TkYvZWNsaXBzZS9sYXVuY2guaW5pUEsBAhQAFAAIAAgATXmGO94i2/ZtAwAA 0ggAAD0AAAAA
AAAAAAAAAAAAIA8AAG9yZy5lY2xpcHNlLnJhcC5kZW1vLnJlbGVuZy5mZWF0 dXJlL3RlbXBs
YXRlcy9XRUItSU5GL3dlYi54bWxQSwUGAAAAAAwADAAoBQAA+BIAAAAA
--------------090409020701000107070904--
FUDForum. Page generated in 0.03504 seconds
