Home » Modeling » EMF » Getting two distinct editors in the same window
Getting two distinct editors in the same window [message #489206] |
Thu, 01 October 2009 20:19 |
Dominic Renaud Messages: 16 Registered: July 2009 |
I've been working on a project that is trying to bridge two EMF-based modeling frameworks, and I was wondering if it was possible make both sides of a split editor window distinct.
At the bottom is the code I use to have two separate editors in the same window. The problem is that they are both treated as a single editor, due to the FMPActionBarContributor linked in the plugin.xml file. This means that when I click on the OWL side, the editor tries and fails to map it to an FMP class. As well, I cannot spawn children of the base OWL class, as all drop down menus run through the FMP editor.
I've been considering possibly using two separate editor Java classes, but I'm not sure how I'd bridge those into one window. It would probably get around the xml-enforced contributor, but I don't know how well it would work. However, this is probably the best solution in the interest of reducing coupling.
Is there any way to have two separate, distinct editors occupying the same window in separate .java files? Am I even going about this the right way?
public void createPages() {
// Creates the model from the editor input
createModel();
// Michal: get project, model, metamodel and metametamodel
FmpResourceImpl o = (FmpResourceImpl) editingDomain.getResourceSet()
.getResources().get(0);
project = (Project) o.getAllContents().next();
model = project.getModel();
NodeIdDictionary.INSTANCE.visit(null, model);
metaModel = project.getMetaModel();
NodeIdDictionary.INSTANCE.visit(null, metaModel);
metaMetaModel = project.getMetaMetaModel();
NodeIdDictionary.INSTANCE.visit(null, metaMetaModel);
OWLGraph owlgraph = OWLFactoryImpl.eINSTANCE.createOWLGraph();
Ontology ontology = new OntologyImpl() {};
// Create a page for the modeling view.
ViewerPane leftViewPane =
new ViewerPane(getSite().getPage(), FmpEditor.this) {
public Viewer createViewer(Composite composite) {
Tree tree = new Tree(composite, SWT.MULTI);
TreeViewer newTreeViewer = new TreeViewer(tree);
return newTreeViewer;
public void requestActivation() {
super.requestActivation();
setCurrentViewerPane(this);
SplitViewPane rightViewPane =
new SplitViewPane(getSite().getPage(), FmpEditor.this) {
//Composites create a split window. The FMP model is on the
//left, while the Ontology view will be on the right.
// viewerPane.createControl(getContainer());
SashForm compositeTop = new SashForm(getContainer(), SWT.HORIZONTAL);
leftViewPane.createControl(compositeTop);
rightViewPane.createControl(compositeTop);
modelingViewer = (TreeViewer) leftViewPane.getViewer();
modelingViewer.setContentProvider(
new AdapterFactoryContentProvider(adapterFactory));
modelingViewer.setLabelProvider(new AdapterFactoryLabelProvider(adapterFactory));
drillDownAdapter = new FmpDrillDownAdapter(modelingViewer, adapterFactory);
modelingViewer.setInput(new ProxyItemProvider(getAdapterFactory(), project, model));
leftViewPane.setTitle(model);
TreeViewer ontologyViewer = (TreeViewer) rightViewPane.getViewer();
List factories = new ArrayList();
factories.add(new ResourceItemProviderAdapterFactory());
// factories.add(new FmpItemProviderAdapterFactory());
factories.add(new OWLAdapterFactory());
factories.add(new ReflectiveItemProviderAdapterFactory());
ComposedAdapterFactory ontologyAdapter = new ComposedAdapterFactory(factories);
BasicCommandStack commandStack = new BasicCommandStack();
AdapterFactoryEditingDomain ontologyDomain =
new AdapterFactoryEditingDomain(ontologyAdapter, commandStack, new HashMap());
rightViewPane.setTitle("Ontology");
ontologyViewer.setContentProvider(
new AdapterFactoryContentProvider(ontologyAdapter));
ontologyViewer.setLabelProvider(
new AdapterFactoryLabelProvider(ontologyAdapter));
// drillDownAdapter = new FmpDrillDownAdapter(ontologyViewer, adapterFactory);
ontologyViewer.setInput(
new ProxyItemProvider(ontologyAdapter, owlgraph, ontology));
new FmpAdapterFactoryTreeEditor(modelingViewer.getTree(),
adapterFactory, editingDomain, modelingViewer);
new OwlAdapterFactoryTreeEditor(ontologyViewer.getTree(),
ontologyAdapter, ontologyDomain, ontologyViewer);
createContextMenuFor(modelingViewer);
createContextMenuFor(ontologyViewer);
addDragAndDropSupport(modelingViewer);
addDragAndDropSupport(ontologyViewer);
int pageIndex = addPage(compositeTop);
setPageText(pageIndex, getString("_UI_ModelingPage_label"));
[Updated on: Thu, 01 October 2009 20:20] Report message to a moderator
Re: Getting two distinct editors in the same window [message #489286 is a reply to message #489206] |
Fri, 02 October 2009 08:37 |
Ed Merks Messages: 33140 Registered: July 2009 |
Dominic,
Comments below.
Eclipse itself allows two separate side by side editors using drag and
drop...
It sounds like Eclipse's support for showing more than one editor in the
same window at the same time will make you happy.
> right way?
> createModel();
> SplitViewPane rightViewPane = new
> SWT.HORIZONTAL);
> adapterFactory);
> // modelingViewer = (TreeViewer)
> viewerPane.getViewer();
> // modelingViewer.setContentProvider(
> // new
> // modelingViewer.setLabelProvider(new
> // modelingViewer.setInput(new
> // viewerPane.setTitle(model);
> ontology));
Ed Merks
Current Time: Thu Apr 25 04:30:08 GMT 2024
Powered by FUDForum. Page generated in 0.02544 seconds
