Home » Modeling » EMF » [XCORE] How to define a non cross reference
[XCORE] How to define a non cross reference [message #1268446] Mon, 10 March 2014 14:08 Go to next message
Simone Di Cola is currently offline Simone Di ColaFriend
Member
Hi all,
according to the code below, could you please tell me how (and if it possible to) refer to the array defined inside the class ComputationUnit from the class Service?
class ComputationUnit{
contains Method[1..*] methods
class Method{
String name
String signature
Object sourceCode
contains Parameter[1..*] parameters
class Service{
contains Comment comment
contains Contract[0..*] contracts
refers Method[] methods //How can I refer to the array defined inside the ComputationUnit class?
Re: [XCORE] How to define a non cross reference [message #1268566 is a reply to message #1268446] Mon, 10 March 2014 17:24 Go to previous messageGo to next message
Simone,
This is again a question of navigation and with only snippets of the
model, it's not clear how to answer...
On 10/03/2014 3:08 PM, Simone Di Cola wrote:
> Hi all,
> contains Method[1..*] methods }
> class Method{
> String name
> String signature
> Object sourceCode
> class Service{
Re: [XCORE] How to define a non cross reference [message #1268579 is a reply to message #1268566] Mon, 10 March 2014 17:45 Go to previous messageGo to next message
Member
Thanks ED for your answer. Following your advice in my previous topic, I've come up with this implementation:
op Method getMethod(String methodSignature) {
for (Method method : methods) {
if(method.signature == methodSignature) return method
return null
class Method{
String signature
String sourceCode
class MethodReference{
contains Method methodReference
class Service{
contains MethodReference[1..*] methodReferences
So now I can assign a reference of a Method to a service by doing something like this:
Service s1 = factory.createService();
Method m1 = factory.createMethod();
MethodReference mr = factory.createMethodReference();
m1.setSignature("void increment ( int m, int &n )");
mr.setMethodReference(m1);
s1.getMethodReferences().add(mr);
Do you know a better way to do it?
Simone
Re: [XCORE] How to define a non cross reference [message #1268595 is a reply to message #1268579] Mon, 10 March 2014 18:13 Go to previous messageGo to next message
Simone,
Comments below.
That seems reasonable, but you'll want to be pretty sure that signatures
such as void increment ( int m, int &n ) use a consistent whitespace
convention if you're going to use String equality... Note too that
using Xbase's closures you can express this more elegantly... The Xtend
documentation shows some of these nice capabilities...
> return null
> class Method{
> String signature
> String sourceCode
> class Service{
> Thanks
> Simone
Re: [XCORE] How to define a non cross reference [message #1272391 is a reply to message #1268595] Mon, 17 March 2014 20:20 Go to previous messageGo to next message
Member
Hi Ed,
how can I define a not contained EReference? I mean, how can I define a reference without using the contains keyword? (if it is possible of course)
Simone
Re: [XCORE] How to define a non cross reference [message #1272399 is a reply to message #1272391] Mon, 17 March 2014 20:40 Go to previous messageGo to next message
Simone,
Keep in mind that context completion proposals will show you the
keywords (though very far down in the list). The "refers" keyword is
used to specify cross references.
On 17/03/2014 1:20 PM, Simone Di Cola wrote:
> Hi Ed,
> course)
> Simone
Re: [XCORE] How to define a non cross reference [message #1272629 is a reply to message #1272399] Tue, 18 March 2014 11:15 Go to previous message
Member
Thanks Ed,
It was so obvious.
Thanks again
Simone
Previous Topic:[XCORE] Meaning of the command Contains resolving
Next Topic:Eclipse 4.3 Paste holding unwanted transitions
Current Time: Mon Feb 19 18:47:34 GMT 2018
Powered by FUDForum. Page generated in 0.02124 seconds
