Home » Eclipse Projects » BIRT » Facing issue while setting Default values to date parameter
Facing issue while setting Default values to date parameter [message #1232286] Thu, 16 January 2014 15:50
sachin india is currently offline sachin indiaFriend
Hi all,
I am new to this community, tool. Apology for my questions because they may be already asked earlier.
i have to show 5 columns in the report and and the 5th column is a concatenation of other columns.
its like this : column5/column6/column7
but problem i am facing when any of the column5, column6,column7 is null or all of them are null as i am getting an exception.
my report should work like this:
if column5 is null and rest are not null
then column6/column7
if column6 is null and rest are not null
then column5/column7
if column7 is not null and rest are null
then column7
if all 3 are null
then blank should come
Please suggest asap.
highly thankful to all of you.
Previous Topic:Birt in web application
Next Topic:View image from postgresql
Current Time: Wed May 23 03:42:02 GMT 2018
Powered by FUDForum. Page generated in 0.01915 seconds
