Re: No more handles [gtk_init_check() failed] when using the IAC on linux [message #110326 is a reply to message #109858] |
Mon, 27 August 2007 13:07 |
Rodrigo Pastrana Messages: 8 Registered: July 2009 |
Hi Paul, I attempted the workaround, but found no new success.
This "No more handles [gtk_init_check() failed]" issue doesn't come up
when trying to connect to the Xserver. It actually occurs when I attempt
to start profiling. I tried bumping up the file descriptor limit by
using the ulimit -n command. Is that what you mean by "Increase the file
descriptor limit."?
I've also tried setting the JAVA_HIGH_ZIPFDS flag to 500, with no luck.
Anybody else seeing this issue?
Paul Slauenwhite wrote:
> Hi Rodrigo,
> Unrelated to your application, we sometimes see the same symptom when
> launching the SWT Manual Test View. See the following explanation and
> work-around:
> http://www.eclipse.org/tptp/home/downloads/releasenotes/rele asenotes4_4_0.html#4_CTI_4
> Paul
> "Rodrigo Pastrana" <rpastran@us.ibm.com> wrote in message
> news:faht7b$uv$1@build.eclipse.org...
>> I am attempting to use the IAC (Eclipse 3.2.2 + TPTP 4.3.1) to profile on
>> Linux RH5. However, everytime I launch my application to profile, I get
>> this ugly error:
>> osgi> 2007/08/20 21:09:58.175 SEVERE CLPDN0016E: Error starting
>> RCPApplication com.ibm.rcp.personality.framework.RCPApplication
>> ::class.method=com.ibm.rcp.personality.framework.internal.RC PApplication.run()
>> ::thread=main ::loggername=com.ibm.rcp.personality.framework.internal
>> org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
>> at org.eclipse.swt.SWT.error(SWT.java:3589)
>> at org.eclipse.swt.widgets.Display.createDisplay(Display.java:8 36)
>> at org.eclipse.swt.widgets.Display.create(Display.java:824)
>> at org.eclipse.swt.graphics.Device.<init>(Device.java:152)
>> at org.eclipse.swt.widgets.Display.<init>(Display.java:472)
>> at org.eclipse.swt.widgets.Display.<init>(Display.java:463)
>> at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:452)
>> at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
>> at
>> com.ibm.rcp.personality.framework.internal.RCPApplication.ru n(RCPApplication.java:65)
>> at
>> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
>> at java.lang.reflect.AccessibleObject.invokeL(AccessibleObject. java:213)
>> at java.lang.reflect.Method.invoke(Method.java:278)
>> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
>> at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
>> at org.eclipse.core.launcher.Main.run(Main.java:977)
>> at org.eclipse.core.launcher.Main.main(Main.java:952)
>> The "No more handles [gtk_init_check() failed]" issue seems fairly common
>> and a few work-arounds have been posted, but none of them seem to make
>> this issue go away, anybody know how to get around it?
>> BTW, these are the work-arounds I attempted:
>> set JAVA_HIGH_ZIPFDS=500;
>> set ulimit -n 65535; pass -vmargs -Dosgi.bundlefile.limit=300 to the
>> eclipse runtime.
>> Any and all information is greatly appreciated.
Re: No more handles [gtk_init_check() failed] when using the IAC on linux [message #110730 is a reply to message #110326] |
Thu, 30 August 2007 11:24 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Rodrigo,
Yes, I meant increasing the file descriptor limit by using the ulimit -n
command.
I would try using the Agent Controller and if the problem persists, open
a defect.
Paul
news:fauido$is6$1@build.eclipse.org...
> to start profiling. I tried bumping up the file descriptor limit by using
> descriptor limit."?
>> Hi Rodrigo,
>> work-around:
>> Paul
>>> on Linux RH5. However, everytime I launch my application to profile, I
>>> get this ugly error:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> common and a few work-arounds have been posted, but none of them seem to
>>> make this issue go away, anybody know how to get around it?
>>> eclipse runtime.
FUDForum. Page generated in 0.10764 seconds
