Home » Archived » M2M (model-to-model transformation) » [QVTo] Failed to resolve meta model during standalone execution
[QVTo] Failed to resolve meta model during standalone execution [message #630190] |
Thu, 30 September 2010 20:50  |
How to register the meta models that QVTo can resolve them? If I run my project from inside eclipse, QVTo can resolve the meta models and execute the transformations.
However, if I package everything in a jar, this does not work anymore. Any idea, how I can get this to work?
Error is: Failed to resolve metamodel!
The meta models are shipped in generated form in jar files that are included into the classpath.
Re: [QVTo] Failed to resolve meta model during standalone execution [message #630200 is a reply to message #630190] |
Fri, 01 October 2010 01:03   |
Hi Simon
When you run within Eclipse, the plugin.xml for each project
automatically registers plugin facilities.
When you run standalone, you must register these facilities yourself.
Documentation on this can usually be found by reading the extension
point description that is accessible from the plugin/manifest editor.
Some Eclipse plugins provide, or autogenerate, special setup routines to
assist in standalone usage.
For EMF meta-models access you need to initialise either the global
Resource.Registry.INSTANCE, or the local registry within your
ResourceSet. For file loading you will need to register a
ResourceFactory again st a file extension or content type. For
URI-mapping you will need to register your URI map. many options -
follow the extension point documentation.
Ed Willink
Re: [QVTo] Failed to resolve meta model during standalone execution [message #633925 is a reply to message #630190] |
Tue, 19 October 2010 17:58   |
Simon harrer wrote on Fri, 01 October 2010 02:50 | How to register the meta models that QVTo can resolve them?
Hi Simon,
This way works for me. It is programmable as follows:
First, you need to instantiate a Registry:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
EPackage.Registry registry = new EPackageRegistryImpl(EPackage.Registry.INSTANCE);
Then, there should be a ResourceSet
ResourceSet rs = new ResourceSetImpl();
which is used to register the meta-models
EPackage mm1 = (EPackage) rs.getResource(URI.createURI("file:///C:/temp/A.ecore"), true).getContents().get(0);
EPackage mm2 = (EPackage) rs.getResource(URI.createURI("file:///C:/temp/B.ecore"), true).getContents().get(0);
registry.put(mm1.getNsURI(), mm1);
registry.put(mm2.getNsURI(), mm2);
Re: [QVTo] Failed to resolve meta model during standalone execution [message #633969 is a reply to message #633925] |
Wed, 20 October 2010 02:20  |
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hi all,
seems like too much work. I used only this:
.put(fileExt, fact);
while fileExt can be "*", and fact can be new XMIResourceFactoryImpl(),
like this:
.put("*", new XMIResourceFactoryImpl());
This registers XMI resource factory for all 'other' file extensions.
Then you need to register the namespace URI of your language, like this:
EPackage.Registry.INSTANCE.put(nsURI, pkg);
For any language X, code generation (using genmodel), generates an
XPackage class. You can use it like this:
EPackage.Registry.INSTANCE.put(XPackage.eNS_URI,
XPackage.eINSTANCE);
Two lines of code (well, 2 statements), that should be all there is to
it... (or 3 lines if you register 2 metamodels). Note that subpackages
are automatically registered.
Hope this helps,
Dennis
> Hi Simon,
Current Time: Sun Jul 20 07:28:44 EDT 2025
Powered by FUDForum. Page generated in 0.07302 seconds
