Home » Eclipse Projects » DSDP - Target Management » Re: Remote debugging question
Re: Remote debugging question [message #30174] Wed, 03 December 2008 20:39
Martin Oberhuber is currently offline Martin OberhuberFriend
Hi Richard,
this question should have gone to "eclipse.dsdp.tm" which is the
Newsgroup for RSE. I'm not sure what you mean by "Synchronize on Demand"
but I assume that you want to press a button to get modified files
downloaded (and only modified files).
RSE doesn't provide this out of the box, but will soon have it through a
Google Summer of Code contribution. Feel free to try it out:
http://wiki.eclipse.org/Platform/Team_Synchronization_on_top _of_RSE#Current_Status
If it were myself though, I guess I wouldn't employ RSE for the
synchronization but run rsync over ssh.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Richard Geddes wrote:
> Eclipse
> Version: 3.4.1
> Build id: M20080911-1700
> PDT Core Plugin: 2.0.0v2008103
> Xdebug 2.0.3
> I've set up PDT/Xdebug to debug an app on a remote server. To
> accomplish this, I basically start with a copy of the app on my local
> machine and then upload that app to the remote machine with RSE. When I
> make edits to the copies on the local machine I synchronize the app on
> the remote machine with the app on my local machine.
> Here's the problem:
> The app that I'm running modifies the contents within its directory
> tree, and as the app runs on the remote system(the server), its contents
> are changed. So my local app is out of sync with my remote app, but my
> local app is the one that should be updated.
> Is there any way of getting RSE, to sync from the server to the client
> on demand?
> Thanks
> R
Previous Topic:Question on remote debugging
Next Topic:TM 3.0.2 is released
Current Time: Wed Apr 25 09:01:12 GMT 2018
Powered by FUDForum. Page generated in 0.01667 seconds
