TPTP and Testing WebApps [message #29122] |
Thu, 01 September 2005 09:36  |
Originally posted by: Tom.Jones.de
hello,
is tptp able to write and manage testcases for webapps? this means
testing the functionality of a html site produced by an webapp (black
box tests).
thanks a lot :)
Re: TPTP and Testing WebApps [message #29423 is a reply to message #29237] |
Fri, 02 September 2005 07:39  |
Ok Thank you. Have you any experience with that?
Is that the only possibility? Recordning a scenario is not very
professional. And the compiled code seems not to be maintainable. For a
simple scenario, the code of tptp has a couple of 100 lines of code.
what do you think about that? :)
Ali Mehregani schrieb:
> Yes, TPTP includes an HTTP recorder that let users record HTTP requests and
> play them back. The source file that is generated from a recorded session
> is a JUnit class consisting of methods that simulate the user interaction
> with the web application. The methods pass or fail based on a response code
> comparison of what is recorded and what is received when the request is
> played back.
> See Help > Help Contents > TPTP Tester Guide > Performance Testing with TPTP
> (don't let the name mislead you, it can actually be used for functional
> testing as I've noted above).
> Ali Mehregani
> "Tom Jones" <Tom@Jones.de> wrote in message
> news:df6i22$nms$1@news.eclipse.org...
>>hello,
>>box tests).
>>thanks a lot :)
FUDForum. Page generated in 0.01316 seconds
