Home » Eclipse Projects » Buckminster dev » New component types not registering in headless product
New component types not registering in headless product [message #28139] Thu, 13 November 2008 22:20 Go to next message
Jim Strawn is currently offline Jim StrawnFriend
I have created a feature to allow the Tigerstripe product to be used
with Buckminster. In doing so, I've implemented two new component types.
The new component types will work for me when I am using them from a
standard Eclipse workbench, but when trying to use them from a headless
environment Buckminster does not seem to resolve my extentions. I
believe that I have all of the required plugin/feature installed in my
tigerstripe buckminster headless product. Output below.
I was wondering if anyone could pass along any pointers on debugging this.
Thanks much,
Jim Strawn
$./buckminster --loglevel debug -data ../workspace resolve
http://www.eclipse.org/tigerstripe/queries/eclipse-summit-08 .cquery
resolve
' http://www.eclipse.org/tigerstripe/queries/eclipse-summit-08 .cquery'
Downloading
Platform install location: /Users/jimstrawn/Development/headless/buckminster
Target platform provided by class
org.eclipse.buckminster.core.TargetPlatform
Equipment-model:tigerstripe: Using resolver rmap
ERROR [0001] : No component type with id tigerstripe has been
registered with extension-point org.eclipse.buckminster.core.componentTypes
Doing full workspace refresh
ERROR: Error while refreshing workspace: null
Waiting for jobs to end
Command canceled
Re: New component types not registering in headless product [message #28178 is a reply to message #28139] Fri, 14 November 2008 01:08 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Jim,
Are you sure the plugin.xml is included in the bundle jar? Is your bundle declared with
singleton=true?
Can you provide your plugin.xml for the bundle in question?
Thomas Hallgren
Jim Strawn wrote:
> Hello,
> Thanks much,
> Jim Strawn
> resolve
> Downloading
> Command canceled
Re: New component types not registering in headless product [message #28294 is a reply to message #28178] Fri, 14 November 2008 14:54 Go to previous message
--------------090804050805050506080900
Hi Thomas,
Thanks for prompt response!
I have attached plugin.xml. I do have the bundle declared with
singleton=true. I also unzipped the .jar and verified that plugin.xml
was included. I'm obviously missing something, though.
Jim
Thomas Hallgren wrote:
> Hi Jim,
> bundle declared with singleton=true?
> Thomas Hallgren
> Jim Strawn wrote:
>> Hello,
>> types. The new component types will work for me when I am using them
>> from a standard Eclipse workbench, but when trying to use them from a
>> headless environment Buckminster does not seem to resolve my
>> extentions. I believe that I have all of the required plugin/feature
>> installed in my tigerstripe buckminster headless product. Output below.
>> this.
>> Thanks much,
>> Jim Strawn
>> resolve
>> Downloading
>> Command canceled
Content-Type: text/xml;
name="plugin.xml"
Content-Disposition: inline;
filename="plugin.xml"
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.buckminster.core.componentTypes">
<componentType
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.TigerstripeProjectComponentType "
id="tigerstripe">
</componentType>
<componentType
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.TigerstripeGeneratorComponentType "
id="tigerstripe.generator">
</componentType>
</extension>
<extension
point="org.eclipse.buckminster.core.actors">
<actor
ID="tigerstripe.installGenerator"
class=" org.eclipse.tigerstripe.workbench.optional.buckminster.inter nal.actor.InstallGeneratorActor "
name="tigerstripe.installGenerator">
</actor>
</extension>
</plugin>
--------------090804050805050506080900--
Previous Topic:IAM-based Maven actor and Maven plugin
Next Topic:Broken Suclipse buckminster headless ?
Current Time: Wed Jan 17 11:37:57 GMT 2018
Powered by FUDForum. Page generated in 0.02280 seconds
