Home » Newcomers » Newcomers » 'Computing Source' has encountered a problem
'Computing Source' has encountered a problem [message #259590] Mon, 30 June 2008 12:42 Go to next message
Originally posted by: tweak.lavabit.com
Hi all
I am using Eclipse Ganymede with CDT.
I have one project where the complete project is indexed correctly.
Everything is recognized correctly (for autocomplete and syntax
highlighting).
However, when i hover the mouse over items that are in files which need to
be refreshed
( the ones when you open them that say: "Resource is out of sync with the
file system '/filepathandname'. -press F5 or select File > Refresh to
refresh the file )
, i get a
"'Computing Source' has encountered a problem. An internal error occurred
during: 'Computing Source'".
If i open up those files, press F5, then in the original file, the
hovering will work.
Is anybody else having this problem? Should i create a bug report for
this?
And is there anywhere a HowTo how to create a bug report ? :)
Re: 'Computing Source' has encountered a problem [message #259676 is a reply to message #259590] Tue, 01 July 2008 05:49 Go to previous messageGo to next message
Walter Harley is currently offline Walter HarleyFriend
"schmendrick" <tweak@lavabit.com> wrote in message
news:c64809eed5e2a15f98149de769d27af4$1@www.eclipse.org...
> [...] "'Computing Source' has encountered a problem. An internal error
> occurred during: 'Computing Source'". [...]
> this?
I'd suggest searching Bugzilla and/or posting to eclipse.tools.cdt, where
you'll find more people who are specifically versed in that component.
Probably fastest to search Bugzilla first. You can do that at
https://bugs.eclipse.org/bugs/query.cgi .
If you go to https://bugs.eclipse.org/bugs/ and click the "help with bug
reporting" link you should find what you need.
Re: 'Computing Source' has encountered a problem [message #259684 is a reply to message #259676] Tue, 01 July 2008 07:19 Go to previous message
Originally posted by: tweek.lavabit.com
ok, thank you
Previous Topic:Can't define a Tomcat v6.0 Server
Next Topic:Ctrl+H Search keybinding not working in Ganymede
Current Time: Wed Apr 25 07:14:32 GMT 2018
Powered by FUDForum. Page generated in 0.02976 seconds
