Home » Eclipse Projects » DSDP - Target Management » RSE - Import Project/Copy
RSE - Import Project/Copy [message #25271] Wed, 30 July 2008 14:24 Go to next message
Nicky Hannaway is currently offline Nicky HannawayFriend
Hi there,
I currently have the RSE plugin installed on Eclipse ganymede. The
problem I am having is that when I try to import source code from the
remote hpux server to a project in eclipse (i.e. in the Project Explorer)
by using the Import option it tries to import it and as the import
progress indicator has just reached the end I get an error message saying
"import problems" (RSEF8070). I have no idea why this may be the case.
Also when I try and just drag a directory from the remote location into a
project in the Project explorer I get the error message "Message reported
from file system: channel is not opened" (RSEF1002).
The files I am trying to access remotely are mounted on a rational
clearcase vob and I have tried methods such as checking in/out before
import/copying.
I have no idea how to solve this problem and any help would be greatly
appreciated.
Nicky
Re: RSE - Import Project/Copy [message #25353 is a reply to message #25271] Thu, 31 July 2008 15:02 Go to previous messageGo to next message
David McKnight is currently offline David McKnightFriend
Hi Nicky,
Could you open a defect for this in bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management
Dave
"Nicky Hannaway" <nickyhannaway@googlemail.com> wrote in message
news:6e6bd1040efacce1d3ab16e581c8a0af$1@www.eclipse.org...
> Hi there,
> import/copying.
> appreciated.
> Thanks
> Nicky
Re: RSE - Import Project/Copy [message #25393 is a reply to message #25353] Fri, 01 August 2008 09:39 Go to previous message
No problem, just done that there. If you could hav a look at it and see
if what I've described it as is ok that would be great. The bug number is
242836.
Thanks Again
Nicky
Re: RSE - Import Project/Copy [message #576301 is a reply to message #25271] Thu, 31 July 2008 15:02 Go to previous message
Hi Nicky,
Dave
> Hi there,
> import/copying.
> appreciated.
> Thanks
> Nicky
Re: RSE - Import Project/Copy [message #576319 is a reply to message #25353] Fri, 01 August 2008 09:39 Go to previous message
242836.
Thanks Again
Nicky
Previous Topic:Source plugins for RSE
Next Topic:TCF roadmap?
Current Time: Sat Feb 24 04:54:17 GMT 2018
Powered by FUDForum. Page generated in 0.01623 seconds
