Home » Eclipse Projects » GEF » Connections on top
Connections on top [message #249024] Wed, 20 May 2009 05:54 Go to next message
Aleksander Braula is currently offline Aleksander Braula
I have two container figures (Block) and some smaller figures (Process)
inside. I want to connect the smaller figures in different Blocks, but
when the connection reaches the border of the Block it disappears.
How can I force the Connections to be always on top ?
Alexander
Re: Connections on top [message #249178 is a reply to message #249024] Thu, 04 June 2009 02:00 Go to previous message
Alex Boyko is currently offline Alex Boyko
Add connections to a layer above the layer where you've placed the shapes.
There's a CONNECTION_LAYER defined on ScalableRootEditPart. Put your
connections in that layer. See logic and shapes example editors.
Alex
Previous Topic:Drawing outside a Figure's bounds
Next Topic:[Draw2D] Mouse Down in StackLayout - reaching "lower" pane
Current Time: Sat May 25 06:04:17 EDT 2013
Powered by FUDForum. Page generated in 0.01546 seconds
