Home » Eclipse Projects » GEF » fillPath() in ScaledGraphics
fillPath() in ScaledGraphics [message #243312] Sun, 01 June 2008 13:53 Go to next message
Originally posted by: andreas-scharf.gmx.de
Hi!
I'm playing around with GEF in conjunction with Batik. I wrote an adapter
(similiar to the one which exists in GMF) which adapts
an AWT Graphics to a draw2d graphics. The problem now is as follows: If I am
at zoom level 100% (e.g. in the logic example)
everything works fine - I can resize my figure which in reality is an svg.
But if I know switch the zoom to 75% (or 150% for instance)
I don't get an SWTGraphics but an ScaledGraphics to draw on in my figure.
Should be ok but if batik now calls fillPath(), I get an
exception because fillPath() is not implemented in ScaledGraphics. Is there
any reason why?
Andreas
Re: fillPath() in ScaledGraphics [message #243390 is a reply to message #243312] Wed, 04 June 2008 15:33 Go to previous message
Anthony Hunter is currently offline Anthony HunterFriend
Hi Andreas,
The exception simply indicates that this support is not implemented in the
ScaledGraphics in GEF. I would raise an enhancement request in Bugzilla.
Cheers...
Anthony
"Andreas Scharf" <andreas-scharf@gmx.de> wrote in message
news:g1u9jn$c7o$1@build.eclipse.org...
> Hi!
> am at zoom level 100% (e.g. in the logic example)
> there any reason why?
> Cheers,
> Andreas
Previous Topic:Showing GEF editor on a SWT composite
Next Topic:key listener problem in editor
Current Time: Sun Jun 24 14:51:41 GMT 2018
Powered by FUDForum. Page generated in 0.02049 seconds
