Re: SwtApplication vs AbstractApplication [message #23031 is a reply to message #22989] |
Tue, 17 March 2009 16:16 |
Christian Campo Messages: 597 Registered: July 2009 |
Velganesh Subramanian schrieb:
> I followed the steps mentioned in
> http://wiki.eclipse.org/Riena_Navigation to get started with Riena UI.
> When I dervied my Application class from AbstractApplication, I couldn't
> launch the application window. After exploring
> org.eclipse.riena.example.client, I switched the parent to
> SwtApplication and I could see the window. What is the essential
> difference between these two?
> Is the name 'NavigationNodeId' apt? 'id' generally refers a String and
> this, to me, is off the track. But there is already 'NavigationNode'. I
> am void of suggestions.
Hi the first answer is really simple. Ridgets and the some of the concepts in Riena are toolkit independant (independant
of SWT). AbstractApplication is a such a toolkit independant thing. You should not use it but rather use SwtApplication.
I am not sure I understand the second question. The navigation model is constructed like a tree. "Application" is the
root element, below is SubApplication, ModuleGroup, Module, SubModule. Each of them are implementations or subclasses of
NavigationNode. They also all have an Id. The Id is necessary so that you can navigation to another node. If you
navigate from "a" to "b", Riena will do everything that is necessary to get you there i.e. expand and close modules,
switch SubApplications. So you use the Id if you formulate a target for navigation. A concrete implementation of such a
point in the Navigation model is a subclass of NavigationNode.
Is that the answer to your question ???
If not please try again. And I try to help you
christian
Re: SwtApplication vs AbstractApplication [message #581281 is a reply to message #22989] |
christian
FUDForum. Page generated in 0.03286 seconds
