| Registering own IDocumentProvider for JavaScriptEditor [message #229384] |
Mon, 23 March 2009 02:36  |
Andrew Arapov Messages: 5 Registered: July 2009 |
Junior Member |
Hi!
I'm trying to register my own IDocumentProvider, which extends
StorageDocumentProvider.
My steps are:
1. I have my own IStorageEditorInput, which provides editing some string
without openning IFile
============================================================ ==================public
class SimpleEditorInput implements IStorageEditorInput {
private String inputString;
public SimpleEditorInput(String inputString) {
this.inputString = inputString;
public IStorage getStorage() throws CoreException {
return new IStorage() {
public InputStream getContents() throws CoreException {
return IOUtils.toInputStream(inputString);
public IPath getFullPath() {
return null;
public String getName() {
return SimpleEditorInput.this.getName();
public boolean isReadOnly() {
return false;
public Object getAdapter(Class adapter) {
return null;
public boolean exists() {
return true;
public ImageDescriptor getImageDescriptor() {
return ImageDescriptor.getMissingImageDescriptor();
return "JSEditor";
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return "JSEditor Tool Tip Text";
return null;
public void setInputString(String inputString) {
2. Next, I'm opennig JavaScriptEditor:
window.getActivePage().openEditor(new
SimpleEditorInput(TEST_JS_1),"org.eclipse.wst.jsdt.ui.CompilationUnitEditor ");
3. The problem is, that I'd like to process SAVE action. But default
provider for my EditorInput is StorageDocumentProvider, which
doSaveDocument method is empty:
protected void doSaveDocument(IProgressMonitor monitor, Object element,
IDocument document, boolean overwrite) throws CoreException {
So, I'm trying to register my own DocumentProvider:
public class StringStorageDocumentProvider extends StorageDocumentProvider
... here do something ...
by placing in my plugin.xml this block:
<extension
point="org.eclipse.ui.editors.documentProviders">
<provider
class="test.jseditor.StringStorageDocumentProvider"
inputTypes="test.jseditor.SimpleEditorInput"
id="test.jseditor.StringStorageDocumentProvider">
</provider>
</extension>
It works fine, when I'm using "org.eclipse.ui.DefaultTextEditor" - my
StringStorageDocumentProvider is generated in this case.
But when I'm using JavaScript editor
(org.eclipse.wst.jsdt.ui.CompilationUnitEditor) problem is still appears.
What do you think about this? May be it is bug/fault of JSDT plugin or
special restriction?
| Re: Registering own IDocumentProvider for JavaScriptEditor [message #229488 is a reply to message #229384] |
Wed, 25 March 2009 05:53   |
Junior Member |
Andrew Arapov wrote:
> Hi!
> My steps are:
> return null;
> return false;
> return null;
> return true;
> return "JSEditor";
> return null;
> return null;
> @Override
> <extension
> <provider
> </provider>
> </extension>
up
| Re: Registering own IDocumentProvider for JavaScriptEditor [message #229799 is a reply to message #229569] |
Mon, 30 March 2009 03:29  |
Junior Member |
> It's intentional, just as it is with the Java editor. The JSDT
> CompilationUnitEditor is hard-wired to use its own document
> provider, CompilationUnitDocumentProvider, to make sure that the
> partitioning setup in the IDocument is correct, as well as perform
> some additional setup for handling as-you-type validation results.
> As a workaround, you could open a file outside of the workspace, but
> you'll need to open a feature request to get this changed...and if
> you have suggestions on exactly how to change it, please let us know.
Hi! Thank you for reply.
I would like to suggest you simple create some external wrapper for
saveDocument method.
May be it could be something like:
if (saveWrapper == null) return;
saveWrapper.doSave(...);
I think it could be configured in plugin.xml...
FUDForum. Page generated in 0.01857 seconds
